Car: BMW 2009 335i xdrive
05-26-2017, 04:41 AM
Originally Posted by 500hp500tq
Just flashed the BMS/MHD_ST_e85_PI flash, no difference.
SEL codes are 2A2C 2A2B fuel mixture control /2
Also uninstalled the Meth FSB. Not sure what I could have did to cause this.
Both precatalytic oxygen sensors have failed. Grab some lifetime warranty ones from FCP Euro.
|E92 335i xDrive| |JB4+MHD BEF| |VM Single Turbo Kit + PTE 6466| |Built Auto Trans| |xHP Trans Flash| |Stage 4-Triple Walbro 450s, fpr + return| |EOS Intake with Port Injection| |AD-ENG FMIC + AD-ENG OCC| |RB PCV Kit| |PR Ignition kit| |Built N54: Darton Sleeved, Manley I-Beam Rods+ARP Rod Bolts, JE 9.5:1 Pistons, JE Wrist Pins, VAC coated main & rod bearings + ARP Head Studs| |Keyed crankshaft snout, crank hub, timing & oil pump sprockets + VTT crank-bolt capture| |ADV Oxygen Sensors|
05-26-2017, 05:27 AM
Are you in Atlanta?
Seems like they both wouldn't fail at the sametime? and since they were working before I unwired the Meth FSB and installed the BMW AIC.
|2008 135i N54 | VRSF FBO| Motiv Port Injection | BMS PI Controller| AD-E ST Kit 6062 | JB4 G5 ISO 13.0 | BMS ST/MHD E85 Flash | 60% e70 | Fuel-It Stage3 LPFP | Spec2+/SMFW |3.5 TMAP | NLS
"stock"
Car: 07 BMW 335i
06-07-2017, 06:00 PM
Hey Terry, was reading in another forum about you discussing new integrations to the new JB4 PI controller. What is the main intent of the secondary fuel pump control? Would it be something that can control the meth pump so we can run meth along with E85 PI or am I totally off?
Car: 335i DCT
06-10-2017, 06:40 PM
I've been away for a while... is it poss to run meth in conjunction with PI?
I can't seem to find install instructions on this?
The Backyard Mechanic
Car: BMW 1 Series M
06-10-2017, 06:46 PM
Only with the aic controller
Car: 335i DCT
06-10-2017, 06:47 PM
Yep, that's what i'm currently using mate.
Car: BMW 1 Series M
06-10-2017, 06:50 PM
Get a bigger ic and never use meth again
Car: 335i DCT
06-10-2017, 06:51 PM
lol, thanks for that.
06-11-2017, 10:17 AM
Yes, you leave the orange trigger wire in spot #2 and the FSB controls meth as normal.
06-11-2017, 10:19 AM
False.
With the BMS PI controller AND WMI you simply need to decide whether you want the JB4 to read PI flow or WMI flow as it can't currently read both. You can run PI without having the JB4 read PI flow.
We're working on logic to allow both to be read simultaneously. There is no reason for anyone with a JB4 to ever run a split second controller.
Car: BMW 1 Series M
06-11-2017, 10:31 AM
False.
So yoiu have to remove the pi safety feature to run meth
I was led to believe we need to have the wire connected to make pi work and to read flow to see if the pi is working or not
So with the new logic your working on we dont have to have the pi flow trlgger wire to read flow when it gets released as you can read it by software instead of the trigger wire
06-11-2017, 11:09 AM
You remove one of the PI safety features IF you need the WMI flow measure active, which you won't, if only using WMI for cooling. But to run a SplitSecond controller instead of the BMS PI controller means no PI safety at all.
06-11-2017, 11:12 AM
Pin 14, 15, or 16 (depending on your platform) is used for receiving the response signal be it meth, PI, or ethanol sensor. You can only run 1 of those options.
If E85/fuel is your primary fuel source via port injection, then monitor the injector duty cycle.
If meth is your primary fuel source, then monitor the meth signal.
If you are having issues with meth or PI, you can always switch that signal wire as needed for troubleshooting.
06-11-2017, 11:23 AM
Soon we'll have the extra DME input enabled for this too. Programming is in the works.
Car: BMW 1 Series M
06-11-2017, 03:07 PM
Thanks for the clarification
We need a major update to the first few pages explaining all the latest advancements, if i would have know this in the first place i would have not sold my meth kit as i was told that you cant run both
Car: 335i coupe
06-11-2017, 06:07 PM
So soon we'll be able to receive a response signal from say PI and E sensor at the same time?
Car: 335i DCT
06-12-2017, 06:38 AM
Thanks Terry.
Just to point of, i'm on your original AIC6 installation - this will still work, right?
Reading through the PI installation again (it's been 2 years) and my meth kit is still installed. I don't see any mention to remove pin #2? So it should still be there? What exactly do i need to do here? (apologies if this is a stupid question).
06-12-2017, 08:34 PM
You already can...you just can't receive the PI and E-sensor signal if running meth.
Thanks Terry.
If running AIC6, nothing as you can not monitor the injector signal with the AIC6...if wanting to run the BMS controller and monitor the PI signal, remove the meth signal wire from pin 15 and insert the PI signal wire.
Car: 335i DCT
06-13-2017, 01:37 AM
Cheers Steve.
I gues my Q was more about the wiring config to get it to work, rather than signal monitoring.
I tried priming the meth system using menu option 7/5 with the meth nozzle in a bottle to test. No meth and I can't here that pump.
Do I need to wait for this new programming to be released for both PI and meth to work together?
Car: F20 M135i
06-14-2017, 05:47 AM
With our latest batch of PI controllers we added an extra output for a secondary pump, as another option. But both the Hobbs switch and JB4 external output are also workable.
Is that the blue wire on the PI controller? Can I use it on S55 as trigger for 2nd pump?
Car: 07 BMW 335i
06-14-2017, 02:33 PM
Bump on my question:
Hey Terry, was reading in another forum about you discussing integrations to the new JB4 PI controller. What is the main intent of the secondary fuel pump control?
06-14-2017, 05:34 PM
Cheers Steve.
What is your meth safety setting set to?
No, that is not for the secondary pump.
Orange wire is supposed to send a 12 volt signal to the relay to turn on the secondary pump when PI is activated. It is still in testing and has not been verified yet.
Car: 07 BMW 335i
06-14-2017, 06:00 PM
So this was basically added to eliminate the relay on the LPFP kits?
06-15-2017, 08:05 PM
No, you still need a relay. You can not run 20 amps through a 22 gauge wire from the port injection controller. it replaces the Hobb's switch and instead of triggering the relay with the ground, you're triggering it with the 12v source (orange wire).
Car: 335i DCT
06-16-2017, 10:09 PM
Hey Steve, my meth settings are:
Meth Safety: 2
Meth Trigger: 1
