(#1076)
artsoasis artsoasis is offline
Car: 335iS
Default 02-23-2017, 06:55 AM
Originally Posted by Sikh335xi
BMS is no longer providing the maps, if you bought your AIC from Fuel-It they might be able to provide you with the maps but they will want your order number to verify you bought your controller from them. Are you planning to run the AIC integrated with JB4?
Yes, I plan on running my JB4 integrated with PI from AIC6
jakesjb4 jakesjb4 is offline
Car: 2008 335xi
Default 02-23-2017, 04:39 PM
If you have E85 access it's a great way to go... Costs more, but it's worth it.
So I have upgraded turbos, intake relocation, VTT silicone outlets, ER chargepipe and tial BOV, ******* DP, cobb exhaust, and a JB4.. My next ideal step is to get this PI kit correct? Or is there something else I'm missing. Also, I don't have to run e85 all the time with this right? Say if i run out of gas and only have a 93 oct. pump near me, I could switch the jb4 map to let my engine know? Thanks in advance.. Let me know if you would rather me email you haha. Thank you again!
Car: 2008 335xi
Default 03-07-2017, 08:56 AM
enrita's Avatar
enrita enrita is offline
Default 03-07-2017, 09:39 AM
where are the newest maps for the AIC6?
Default 03-07-2017, 09:59 AM
We no longer support the AIC6... Fuel-IT may have maps posted as I know they still offer it.
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 03-18-2017, 09:15 PM
Great to see that the early adopters that jumped on with your PI & AIC6 integration, and helped test with you aren't supported anymore!
Pohjoisen Poika Pohjoisen Poika is offline
Car: E82 135i M-performance
Default 04-14-2017, 03:27 AM
If I adjust all AFR Bias to 0. Is PI totally off or is it still ad little bit fuel?
135i N54 mt, JB4 G5 iso, vrsf fmic, vrsf cp+tial, VTT GC, Stage 3 lpfp, Fuel-it PI, Martellius custom exhaust, Quaife lsd, Ngk plugks, Rb pcv, Bms occ, VTT inlets, BMS dci, spec stage 2+ clutch, smfw, Tribila tuned
Default 04-14-2017, 08:51 AM
On the N54, I believe it is still adding fuel. You'd have to verify with Terry as I don't see any updates in the firmware notes with regards to that.
Default 04-16-2017, 02:14 PM
Working on updated JB4 firmware to automatically take in to account various ethanol mixtures for port injection mapping. The same logic will also be tied in to our virtual flex fuel sensor logic once complete.
So if you've got port injection and a flex fuel sensor, drop me an email, to help test out the new stuff. Thanks!
1///M's Avatar
1///M 1///M is offline
Car: BMW 1M
Default 04-16-2017, 02:40 PM
fantastic work terry...hopefully my o2 issue will be resolved and I will test for sure
RHD Top Mount ST
idratherbesurfing's Avatar
idratherbesurfing idratherbesurfing is offline
Car: 06 STI
Default 05-09-2017, 02:29 AM
Guys I'm using the jb4 and mhd stack. I'm using the BMS port injection controller as well. My port injection will not fire. It seems like it's just a setup issue as the wiring is done completely right. Menu 8 is at zero, meth trigger settings are 1. Any other suggestions?
DILUSI's Avatar
DILUSI DILUSI is offline
Car: e92 335i N54 2007
Default 05-09-2017, 02:58 AM
I have similar setup but used the Nitrous trigger to enable the PI
BMW E92 335i N54 6AT, Single Turbo to be decided. Turbosmart BOV / Spearco FMIC / Wagner Down *****, Stg3 LPFP and Fuel-IT PI kit, Aquamist PWM Meth trunk mounted, single 0.7mm nozzle spraying 60% meth, JB4 G5 + FSB + N20 Sensor + JB4 BT Connect, MHD JB4 Backend Flash, Fuel = e60 + 60% Meth, M3 Rear Subframe Complete swap + custom prop, front m3 wishbones, KWv3 Suspension, M3 brakes front rear, H&N ARB / 19" M359 Reps + Michelin Super Sports tuned by TREBILA
Car: 06 STI
Default 05-09-2017, 03:05 AM
Oh, so should I be disabling meth and engaging the nitrous?
Car: 06 STI
Default 05-09-2017, 03:24 AM
Actually I take that back my nitrous settings are all correct
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 05-09-2017, 12:40 PM
We are using the nitrous trigger to enable the stage 3 fuel pump.
For meth settings, we set scaling to 100, safety to 0, and meth trigger to 0 but we can not get PI to work.
Terry, any advice on where to go from here?
Car: 09 E92 SG
Default 05-09-2017, 01:17 PM
Terry,
In this log it looks like the last two Fuel Bias settings were set to 0. Would this cause the PI not to flow at all?
phv628's Avatar
phv628 phv628 is offline
Car: BMW 2009 335i xdrive
Default 05-10-2017, 07:49 AM
You guys should switch to using the Hobb's switch to activate the secondary pump. I have the meth flow set to 100 and no nitrous trigger enabled. You'll see a reading under the meth column if the port is being activated.
I have an extra Hobb's switch from Fuel IT for purchase if you decide to go that route.
|E92 335i xDrive| |JB4+MHD BEF| |VM Single Turbo Kit + PTE 6466| |Built Auto Trans| |xHP Trans Flash| |Stage 4-Triple Walbro 450s, fpr + return| |EOS Intake with Port Injection| |AD-ENG FMIC + AD-ENG OCC| |RB PCV Kit| |PR Ignition kit| |Built N54: Darton Sleeved, Manley I-Beam Rods+ARP Rod Bolts, JE 9.5:1 Pistons, JE Wrist Pins, VAC coated main & rod bearings + ARP Head Studs| |Keyed crankshaft snout, crank hub, timing & oil pump sprockets + VTT crank-bolt capture| |ADV Oxygen Sensors|
Default 05-10-2017, 07:52 AM
With our latest batch of PI controllers we added an extra output for a secondary pump, as another option. But both the Hobbs switch and JB4 external output are also workable.
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 05-10-2017, 08:55 AM
If one has an earlier production JB4 PI controller can this secondary output be added with a some hardware changes?
EDIT: I am installing my PI controller now and notice there is a blue wire without a pin and the instructions say nothing about it, is that the LPFP trigger?
Evan
N54 Powered M5 Wagon:
Zahak's Avatar
Zahak Zahak is offline
Car: BMW 335i
Question 05-21-2017, 03:01 PM
Dear Terry,
I succeeded to flash JB4 MHD Backend map (JB4_MHD_I8A0S_HYBRID_E85_PI.bin from 12/13/16 JB4 MHD Map Release) as you said. Then I updated my JB4 to Ver32.8 by "G5_ISO_32_6b.hex" file.
I have non JB4 integrated Port Injection (AIC1), Is it compatible with my back-end flash and JB4 firmware version?!
BMW E90 N54 2008 6AT, RB Turbo, JB4 G5 ISO 32, TFT Inlets, VVT Silicon N54 charge pipe outlet, Larger Inter cooler, BMS Port Injection, Methanol Injection, Evolution of Speed N54 intake manifold, Down Pipe, Charge Pipe, Blow Off, N20 TMAP, Remus Exhaust, BMS Oil catch can, K&N Filters, Alpina B3 TCU Flash, Fuel-It Stage3, Anti-Lag
500hp500tq 500hp500tq is offline
Default 05-25-2017, 05:16 PM
Just guys, just installed PI with BMS controller.
AFRs are both stuck at 20, car has rough idle.
|2008 135i N54 | VRSF FBO| Motiv Port Injection | BMS PI Controller| AD-E ST Kit 6062 | JB4 G5 ISO 13.0 | BMS ST/MHD E85 Flash | 60% e70 | Fuel-It Stage3 LPFP | Spec2+/SMFW |3.5 TMAP | NLS
"stock"
Car: F06 N55 640i Gran Coupe
Default 05-25-2017, 05:37 PM
Check for cel code, reset adaptation.
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS DP n FULL Custom Exhaust
Custom BC forge 18/17 set up
Default 05-25-2017, 05:52 PM
Just flashed the BMS/MHD_ST_e85_PI flash, no difference.
SEL codes are 2A2C 2A2B fuel mixture control /2
Also uninstalled the Meth FSB. Not sure what I could have did to cause this.
"stock"
rac rac is offline
Car: 2008 135i 6MT
Default 05-25-2017, 05:53 PM
Terry,
Can you please describe what inputs other than LPFP pressure compensation, rpm, and user defined rpm variable the Jb4 is taking as inputs for PI volume?
Does the jb4 assume a simple relationship b/w boost & rpm or does it take in other data as well?
Default 05-25-2017, 07:29 PM
Varies by firmware. But intake temp, boost, low fuel pressure, engine speed, pedal position, throttle position, boost rate of gain, are the main factors off the top of my head. It's all plotted out within logs under "fuel enrichment" so you can watch it change as other parameters change if you're interested in how it's mapped out.
