Log help n54 fbo e85 backend with 455 fp -
12-30-2016, 04:30 PM
how's it going guys? This is my first post here so don't be too hard on me. the car is running great but I feel like with everything I have done I should be hitting higher boost. the car is currently on map 7 with the jb4 e85 backend running e55. I just wanted to get some input on my current logs and also why I'm not hitting Target boost. any input would be greatly appreciated. The logs are 2nd 3rd and 4the gear pull.
Thanks,
Brad
If your still running OEM turbo's that is why your not hitting target.
You also gained 53 degrees IAT on that run. I would consider using meth to limit the IAT rise.
Thanks for the input. My turbos are currently stock thats the next thing I plan on doing here very soon most likely going single. I was planning on doing port injection along with the turbo upgrade so i was going to stay away from meth. If i increase my e85 mix will that help with the iat rise.
No it will not help.
What was the ambient temp during the run.....60 degrees?
Your FMIC is not doing the job it should be doing. Check for low ambient airflow through the coils.
