Khateebovic's Avatar
Khateebovic Khateebovic is offline
Car: E92 335i
Default Boost leak - no codes (logs attached) - 11-25-2016, 06:08 PM
Hello fellas,
i have recently purchased a 335i and felt like the car is not giving the full power it is capable of. Few month later i installed the JB4 and had few test runs, the tune is amazing and the car is totally different, however i still believed that the car can do better.
So i hooked my laptop to the USB port and pulled some logs, surprisingly my boost was 5.5 ~ 6.2 maximum WITHOUT any codes thrown. So i decided to open this thread so you guys can help me figure our my problem.
JB4 Logs are attached, i tried various maps same result, even map 0.
Enrique09 Enrique09 is offline
Car: 2008 bmw 335i e90
Default 11-25-2016, 07:15 PM
If you have an aftermarket chargepipe/bov check to see if its still connected because my chargepipe disconnects couple of times every month
Russell @ BMS's Avatar
Car: 2009 335i AT
Default 11-25-2016, 09:23 PM
Low boost could be a boost leak... a large one in your case.... or a bad boost solenoid, cracked vacuum line, hung up WG etc. You can either have the intake system smoke tested for leaks or try the following:
I would start with a hand held vacuum gauge and see how much vacuum you have in each vacuum canister (located near the front of the engine bay on the right side). Engine should be running at idle in neutral. You should see 25 to 28 "Hg at the tanks.
Jwesty18 Jwesty18 is offline
Car: E92 335i 6spd
Default 11-26-2016, 01:29 AM
Im more concerned with the "my charge pipe comes off a couple times every month"
Car: E92 335i
Default 11-26-2016, 01:36 AM
I have the stock charge pipe, but the car used to be moded.
Russel, ill follow your test and post the result.
Car: E92 335i
Default 01-03-2017, 01:57 PM
Okay so finally i could find the issue, it was the wastegate actuator, replaced and the car took a whole new level!
However i have 2 things in concern, my boost is reaching 20.4, which is relatively high to what i have installed in the car and it's MAP5.
One more thing, at MAP0 which should be the bypass to stock, the boost numbers are still the same as MAP5, anything to worry about here? Logs attached.
Mods: DCI, JB4 G5, Supersprint Exhaust system without down pipe yet.
Car: E92 335i
Default 01-04-2017, 07:05 AM
Did another run with MAP2, still hitting the 20.7 boost..
Default 01-04-2017, 08:52 AM
Random boost spikes after the throttle closes is not hitting 20.7 of boost.
If you want tuning assistance, post a 3rd gear log from 2K to redline at WOT.
Car: E92 335i
Default 01-04-2017, 11:33 AM
Thanks steve.
I noticed im hitting 20s only when shifting, which according to what i read is normal.
However, shouldn't map 0 be a bypass map? Why its not happening? Ill try to do a better run and post it.
Car: E92 335i
Default 01-04-2017, 03:37 PM
Attached MAP5 WOT
Default 01-05-2017, 08:48 AM
You missed the 3rd gear portion of my description.
Lower FF to 80 and try again but log on map 1.
Car: E92 335i
Default 01-05-2017, 11:18 AM
I missed the redline part :3
I'll do a map 1 run, but why is the jb4 not bypassing at MAP0, any thought?
Car: E92 335i
Default 01-05-2017, 06:18 PM
Also steve, can you please tell wether my boost @18 is too high for my car or is it normal? And why the boost isnt changing through all the MAPs? Is there anything to worry about here?
Default 01-06-2017, 08:22 AM
If you want to run stock boost targets, run map 4.
Do as I suggested and lets see the log on map 1.
Car: E92 335i
Default 01-06-2017, 02:24 PM
Steve, i did some readings and just need to confirm how to change the FF to 80, i attached an image with highlighted values to change, is it correct? Sorry for inconvenience i'm still a rockie
Default 01-07-2017, 05:51 PM
You will only change the FF value. Leave DB alone at this time.
Car: E92 335i
Default 01-08-2017, 03:21 PM
I did as told, except changing the map. Totally forgot it!
I'll attach the logs, the boost got better now with 17.5 @ 6K in 3rd gear!
I'll do another run with MAP1 and post the results.
Car: E92 335i
Default 01-12-2017, 04:16 PM
I finally got to run on map 1 logs attached.
Car: E92 335i
Default 01-18-2017, 01:43 AM
Steve, any advise?
Default 01-18-2017, 10:33 AM
Logs need to be done in 3rd from 2K to redline at WOT.
Timing is poor, looks like you need more octane. E85 or meth an option?
Car: E92 335i
Default 01-19-2017, 05:35 AM
Ill do another run when i can
Im using octane 95.. meth or E85 isnt possible unfortunately.
Default 01-20-2017, 09:34 AM
Okay, then you are going to have to stick with map 1 and make the best of it.
I'd log 6-cyl timing and boost limit as needed to maintain good timing.
Car: E92 335i
Default 01-24-2017, 02:50 PM
I just saw your reply steve, what do you mean by log 6-cyl timing and boost limit?
Also, what could cause this issue? Why in MAP4 im still running the same boost at 15-16 PSI? is the wastegate actuator fix have to do anything with this?
Default 01-27-2017, 09:45 AM
Because you are running a flash that is targeting 15-16psi. Do you have menu 4 set to option 2?
Set 6-cyl timing to 5
You may want to read this as well...
http://www.n54tech.com/forums/showthread.php?t=21269
