Car: 2009 335i xdrive
jb4 slow acceleration 2d2e always comes on!!! -
11-25-2016, 07:31 PM
hey guys new to the forum I think I'm in the right spot...
little background I have an 09 335xi with 115k on it automatic. I have chargepipe and bov, muffler delete, DCI, jb4 v32.5 and oil catch can
problem Is ONLY at low throttle going up hill or on the interstate at a slow rate I get the SES 2d2e every time betweed 45 and 60mph and its driving me insane I cant find any boost/vac leaks. my canisters are holding vac.... can anyone shed some light? mostly I see people getting this code only at WOT mine is again only at low throttle (this happens because the wife drives it and she drives it like a prius sometimes)
11-25-2016, 07:32 PM
Maybe a menu10 or menu12 setting change will help.
11-25-2016, 07:44 PM
I changed the setting to default yesterday with the steering wheel controls and just hooked up the computer it said under user adjustments that my wastegate position was at 59 so I set it to 24 and hit save, will that save it correctly during all maps or is that only for map 6?
11-25-2016, 07:48 PM
also it only is around -2000 rpm and boost is usually around 4 or 5 psi
11-25-2016, 08:00 PM
Maybe capture it in a JB4 log. Uncheck log WOT only to record it.
11-25-2016, 08:04 PM
will do Terry thanks a bunch ill get a log loaded tomorrow
got logs -
11-25-2016, 08:30 PM
the first log is at low throttle unfortunately the ses didn't come on but It almost never does when the oil is above 160 the second is at wot
Car: 2009 335i AT
11-25-2016, 08:44 PM
Try to catch it in log when the ses light is activated. If your running 5 psi boost under light load then in dash items 11 or 12 is probably too high.
11-25-2016, 08:47 PM
yeah ill be doing a log in the morning usually it only happens when the oil is under 160 and jb4 is not active....should my 11 or 12 be lower to lower psi? am I making too much psi cuz I always get an underboost code instead of over
my menu 11 and 12 is at default 1k and 2400
Car: 2009 335i AT
11-25-2016, 09:09 PM
Also check the vacuum line from the intake manifold to the diverter valves for cracks or leaks.
11-25-2016, 09:14 PM
I did have that leaking before just put in a vrsf charge pipe and hks all sealed up
\ should I try going lower with menu 11 and 12?
Car: 2009 335i AT
11-25-2016, 09:27 PM
Try to get a log of the event.... else we are just guessing at the conditions. You can log in Map 4 with OEM like boost levels..... even while hot.
11-25-2016, 09:29 PM
Will get in the am thanks guys
mornig log -
11-26-2016, 08:04 AM
code came on in dme could see it in jb4 program just didn't set SES??
11-26-2016, 10:50 AM
If its a shadow fault rather than an active (reduced power mode) fault best bet would be to turn on auto clear I think. But looking at the log something to try would be lowering menu12 by say 200 or 400rpm.
11-26-2016, 11:15 AM
Thanks terry I'll give that a shot and run another log tonight
codes gone!!! love it -
11-26-2016, 04:43 PM
looks like I had had some funky numbers for menu 10 and 11 almost like they were swapped not sure how... but then took Terrys advice dropped menu 12 to 2200 and car runs way better and boost target is much closer to actual.
attached last two logs I took
THANKS TERRY!
11-26-2016, 05:00 PM
OK good, hopefully that does it. If not try auto clear menu 1/3.
11-26-2016, 05:02 PM
right on terry will do, the logs look good to me is there anything you could inout or do things look pretty good to you?
Car: N54
Same Problem..... -
03-17-2018, 06:58 AM
Hi All. I've got very similar issues.
Our N54 does not want acceleration at all. The Car has absolutely no Power and when i WOT it just Dies... Im also getting a Weird Exhaust Sound coming from the motor. As if the Wastegates are staying open. Almost sounds like a Golf1 with a Cone filter but its Choking. We have checked eveything and im at my wits end.
I Have attached a log for you. Please Advise. I think it could be the HPFP
03-19-2018, 06:35 AM
You'll need to start your own thread with a log as there is no log attached.
