Car: E92 335i
10-11-2015, 06:23 PM
Originally Posted by Mr. T
Are you leaning on meth for fueling or iat suppression?
IAT suppression, plenty of octane with e50
If yall have questions shoot me an email, I most likely won't respond to PMs or posts on threads as I'm pretty busy.
Car: 335i N54 E92
10-11-2015, 06:29 PM
Spxxx
You can find in attached logs from my car using your E60 timing fueling E80 and fuel tune by myself... what u think about it?
thanks
335i, MHD E65 Custom flash, Intercooler, Chargerpipe, MM Performance inlets, LPFP Walbro 450, HPFP BMW review, full exhaust
Car: E92 335i
10-11-2015, 08:38 PM
Email me... Don't check here often enough.
Also post to *********** plz I see tens of logs a day
Car: 2008 BMW 535i
10-27-2015, 02:55 PM
Did you update these files two weeks ago?
09 E93 335i | Platinum Bronze | FBO AR Design Race*****DP: Stepped FMIC:ER CP: Turbosmart Kompact DVs | 4Bar| MMP Sil Inlets | Custom dual K&N Intake | NGK Iridium 5992 | BMS OCC | RB PCV | Fuel-It S2 LPFP | JB4G5: MHD S2 93, SPXXX E60 OMG Map | Alpina B3 | MFactory 3.46 LSD | 135locktop Dif. Lockdown | Koni FSD | Custom Exhaust: 2nd HiPerf*****+ 2nd o2 relo+ xbrace+ race muffs+twin 4"TiTips | Custom Coding | Super Cool Wife
Car: E92 335i
10-27-2015, 07:32 PM
Yeah toned them down, slowing down on the custom stuff due to work obligations but I'm hoping the maps act as a good starting place for people to build their own maps
10-27-2015, 09:22 PM
Still loving the e60 map here!
Do you have any pump maps?
~MHD Stage 2+~3.5 Bar Tmap~PR Ignition Kit~VTT Inlets~VTT Cast Valve Cover~VTT Dual CC~XClutch Twin Disk~BMS Short Shifter~ER Competition FMIC Kit w/ HKS SSQV~3"AR DP's~3" Custom exhaust~Fuel-It Stage 2 Bucket~
Car: 2009 BMW 335i xDrive E90 Sedan Auto Trans
Load To Torque Breakpoints -
10-31-2015, 07:24 AM
What is the benefit / intention of having the different load breakpoints on the 3 load to torque tables?
2009 335i AT xdrive E90 Sedan
Xhp Stage 2
BQ Tuning Custom 93 Octane Tune
FBO + Inlets
Car: 09 E92 SG
10-31-2015, 08:37 AM
You need to scale the load to torque tables in order to prevent torque limiters from kicking in.
10-31-2015, 12:21 PM
Thanks. I do understand that. But then why are the 3 L2T tables not scaled using the same breakpoints?
Xhp Stage 2
FBO + Inlets
Car: 09 E92 SG
10-31-2015, 01:33 PM
They should all be exactly the same. Mine are.
10-31-2015, 06:49 PM
@Fmonteiro444 I just downloaded the latest map from dropbox to see if something was changed recently. The 3 tables have different breakpoints.
Any insights? Please see below.
Xhp Stage 2
FBO + Inlets
Car: E92 335i
11-01-2015, 02:37 PM
Ooof good catch, the changes are in low load areas so it's unlikely to have much effect other than cruising but I will update those files. I remember doing some testing a long while back with adjusted breakpoints to help with around town shift smoothness and those tables made their way into this map =/
Car: 2008 AW e92 335i
11-01-2015, 07:16 PM
I recently purchased a 08/06 build E92 335i just because I got a killer deal on it and figured it would be fun to get back into the N54 world. I currently have a 2010 GrandSport Corvette LS3 car, M6, D1SC Procharged, custom fab'd plumbing all to 4", headers, X pipe, Corsa Extreme exhaust, ID1300 injectors with a dual inline Walbro setup with factory pump and boost-a-pump with a LS9 factory twin disk clutch and lightweight flywheel, tuned by Sam @AMP in the dallas/fort worth area on E85. With everything dialed in from logs and dyno tuned the car makes 791rwhp and has yet to break down on me and I'm extremely hard on that car and it just asks for more. I knew of someone that really needed to let go of his E92 335i and to be honest, I missed this platform alot. So I bought it so I dont have to drive the GrandSport and I can also have a little bit of fun with dialing in a N54 335i FBO car that has a wavtrac LSD, Brembo BBK front and rear, ******* dp's, 7" VRSF FMIC and chargepipe with lower chargepipe. Probably going to find some new "stealth" RB's and have those ordered asap! I have my old JB4 G5 ISO as well as my OBDII to USB cable for flash maps. Do I download lets say your I8A0S E30 bin flash only or should I intall the JB4 and let it take car of DME boost with option 4/2 and target boost on the JB4? OR should I just run your E30 map without the JB? Sorrry feel like a noobie asking these questions but have been messing with a completely different platform and just want this car to make 450rwhp RELIABLY.... Is that possible? And I have full access to E85 as well as a 465LpH Low pressure pump I took off my old car?
E92 A/W JB4 G5 ISO w/WEDGE PERFORMANCE FLASH+FBO+RB's+LSD+60% E85/93 mix 508whp 531 ft lb torque  11.73 @121mph on street tires with a 2.1 60'!!! NO METH!
Car: E92 335i
11-01-2015, 07:22 PM
I prefer running stacked with the JB4 for ease of changing boost, safety, meth control, and boost by gear limiting... Traction on these cars sucks straight line.
A lot of people prefer the standalone MHD option as it's a bit smoother (debatable) but IMO the JB4 stacked option is the way to go. Shoot me an email - spxtuning@gmail.com
11-05-2015, 09:09 PM
@spxxx How about the differences in the higher load rows - roughly the bottom 4 rows of the table. Are those different breakpoints intentional? If not, and if they should all be the same, which of the 3 load to torque tables is the "correct" one? Thanks again.
Xhp Stage 2
FBO + Inlets
11-06-2015, 11:57 AM
Are there non M boost versions of these maps available?
Car: 09 E92 SG
11-06-2015, 12:38 PM
See attached.
Car: n54 335
11-26-2015, 11:23 AM
are these uploaded via JB4 back-end flash on the MHD app even though i dont have jb4?
751WHP 688WTQ JP Works Kit Record
Car: E92 6MT N54
11-26-2015, 05:02 PM
You need the flasher and boost modules
Car: BMW E92 335i
01-02-2016, 08:37 AM
Hello I just flashed the e60 I8AOS map, but the SES light came on and won't clear. Any idea why? The other map worked fine and no SES.
Car: 2009 bmw 335i / alpine white
01-02-2016, 10:53 AM
Go to read DME codes and click on clear other module codes in MHD
Car: 08 335xi
01-02-2016, 01:27 PM
That's common on a lot of cars....it will probably go away after 2-3 drive cycles (usually about 30 miles of driving on my car).
09 335 - 6266
07 335i - 6870, E85 - SOLD
03-22-2016, 09:24 PM
do I need to purchase mboost if I load your e40/e60 map?
03-27-2016, 06:59 PM
so I tried downloading the e40 map and it says I need to purchase mboost?
Car: 08 335xi
03-27-2016, 07:02 PM
Here's a thought, click on the MHD store and purchase the M-boost module
09 335 - 6266
