Car: 2007 335i e92 Coupe
New Sticky Request: Smoking N54 Troubleshooting -
10-22-2015, 07:06 PM
Terry,
It's alarming the rate at which these "Smoking N54" threads are popping up now. It seems like I see a new one every day. Can we get a sticky going to help these guys out in their troubleshooting? I feel like we're seeing the beginning of a huge refurbishment era for this engine.
Car: 09 335I Coupe
10-22-2015, 07:28 PM
Please!
09 335I, E92 6MT, JB4 G5 ISO, BMS flash, AMS FMIC, Active Autowerks exhaust, BMS DCI, BMS OCC, BMS DP's, BMS clutch valve, Forge DV's, M3 control arms, sway bar and SteveAZ Walbro FP.
Car: 08 E92 335i
10-22-2015, 08:23 PM
x3
10-23-2015, 10:57 AM
Your original post was pretty concise on this matter. From PCV valve to valve stem seals to bent rod.
10-23-2015, 12:18 PM
Thanks. I'd just like a central location to compile different root causes and the final countermeasures and to identify a common troubleshooting process to begin eliminating variables.
Another good data sample would be each persons mods/tunes/hardware etc. Smoking is a symptom of a million different issues and it literally took me a year to finally narrow it down along with trying to conduct a proper FEMA. Also, multiple issues can be working together to produce the same effect so you have to be prepared to acknowledge that just replacing one part may not completely fix your problem.
Car: 08 E92 335i
10-23-2015, 01:21 PM
Yeah it seems like it stems from all stock people like me, with 70k miles, all the way to people who are FBO+meth with 20k miles.. Large spectrum so maybe we could narrow it down and each person put what they've done to diagnose and fix it... The only reason I dont think mine is valve seal related is because it doesn't even slow down or go away once the car warms up.. But mines a bit more then most of you, my car is basically not able to be driven because of it..
10-23-2015, 02:09 PM
Just make list of Rob Beck quotes because he knows everything.
Car: 2007 BMW 335i
10-23-2015, 11:08 PM
If everyone followed my stringent maintenance/modification guideline there would be no smoking N54's.
07 335i sleeper - PT5858 single turbo - stock exhaust - stock wheels
10-24-2015, 12:28 AM
Where is said guideline ?
Car: 09 335I Coupe
10-24-2015, 10:21 AM
My car has less than 38,000 miles, has never seen snow almost never seen rain, kept in a heated garage, never been over 3000 miles for an oil change, new brake and tranny fluid and now new valve cover and pcv valve and yet let's out enough smoke approaching stop lights to have, on two seperate occasions, rednecks in rotten pick ups let me know that my car is burning up.
It's been modified for maybe 15k and with the exception of two days at the 1/4 track is usually driven on weekends to the cottage with two children in the back.
I would say that any support this community can provide, to the less knowledgeable, and "few" that are having these smoking issues would be greatly appreciated. Just my $.02.
Car: 2007 BMW 335i
10-24-2015, 08:50 PM
10-26-2015, 05:38 AM
LOL!!
