(#1626)
Jameshawk101 Jameshawk101 is offline
Slo335
Car: 2009 e92 335i 6MT M-Sport
Default 10-23-2015, 04:23 AM
Originally Posted by Mr. T
Time to buy a new DME
Good one, I flashed back to stock and all is good.
Mr. T Mr. T is offline
Default 10-23-2015, 04:25 AM
Really? Lucky man lol, I've heard horror stories of people forgetting to deactivate their jb4 when flashing and frying the DME. Happened to one of my friends actually.
Slo335
Default 10-23-2015, 04:29 AM
Yeah same here I thought I was screwed. The car runs fine though.
benben benben is offline
Car: bmw e92 335i msport
Default 10-23-2015, 02:57 PM
I have downloaded the mhd installer and have the correct cables to load it onto my car, will a jb4 backend flash work with my spec:
N54 335i
JB4 g4
Bms dci
******* dp's
Ams cooler
Bms methanol kit
Ben
Default 10-23-2015, 03:30 PM
N54 335i
JB4 g4
Bms dci
******* dp's
Ams cooler
Bms methanol kit
Ben
You need to upgrade to the G5ISO
N54 | Build Thread
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 10-24-2015, 06:50 AM
Any MHD backend for those of us running inlets? I had seen that something was in the works but haven't seen anything about it again since.
You'll need a custom tune. Inlets allow more airflow compared to stock, so your WGDC Adder will need to be lowered significantly compared to those without inlets.
DV135i's Avatar
DV135i DV135i is offline
Default 10-24-2015, 11:31 AM
I'm running a jb4 with the mhd backend flash, and installing my 3.5bar map sensor today. Do I need to check the box on the mhd flash and change settings in the jb4? Or do I just put 1 next to N20 TMAP in the jb4 settings and leave the mhd box unchecked?
justa335i's Avatar
justa335i justa335i is offline
Car: 07 E92 335i
Default 10-24-2015, 11:53 AM
so i run a backend flash and what...? is it some magical one size fits all??
2007 E92 335i 6MT
New Jersey
N54-Tuning 3'' Downp!pes, Vrsf 5'' Intercooler, Vrsf Charge Pipe, Tial-Q BOV, Vrsf Lower Charge Pipe, Act HDSD Clutch, JB4 G5 ISO, BMS Intakes, Custom Axle Back w/ 3" Tips
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 10-24-2015, 01:01 PM
Do NOT check the box on the flash. Just change the settings in JB4 only.
335is DCT
DV135i's Avatar
Default 10-24-2015, 03:48 PM
ok, thanks!
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-26-2015, 01:29 AM
Adjustments should be done for the boost control, so in the jb4 map/settings, not the backend flash.
There are several backends depending on things like fuel, then you can modulate the jb4 boost curve by changing maps based on your needs.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-26-2015, 01:33 AM
If you forget to change the jb4 to map 0 and fail at flashing, then unplugging the jb4 and disconnecting a while the battery minus pole will let you establish back the connection to the DME.
Anytyme's Avatar
Anytyme Anytyme is offline
Car: 2011 335I
Default 10-26-2015, 04:20 AM
Any plans on supporting 2011 335i's N55? I only see up to 2010 335i and 335is for 11
LsWhat LsWhat is offline
Car: 2008 335xi
Default 10-26-2015, 09:06 AM
So I have a modified mhd bms e85 flash I want to put in, I plan on running 21+ psi, will I need the m boost? To flash a custom flash with this. The car also has a 3.5 bar but the jb4 takes care of that correct?
ksmyth's Avatar
ksmyth ksmyth is offline
Car: 335xi
Default 10-26-2015, 11:37 AM
I've noted that my setup will produce over 8 psi of boost prior to the engine hitting 160F. Is this a function of MHD changing targets? If so, what is the upper limit of boost at low oil temps and is there a way to lower it via the JB4? I've seen values as high as 12 psi accidentally while still below 160F. I'd like to avoid that if possible. I'm using map 7 on the JB4 and have the E85 backend flash.
09 335xi - 6AT - JB4 - hot side inlets - *** - MHD Flash - 7" IC - Fuel-It TBI
tc535i tc535i is offline
Car: 95 M3, 01 330i, 07 335i
Default 10-26-2015, 11:47 AM
I'm guessing this could be related to a menu 12 setting, I've been having a similar problem and Trebila noticed my pwm could be causing an issue. In this log it's sitting at 79 with no issues, then suddenly drops to 27 and I start boosting over target.
http://***********/u/tc535i/cold-surg...zoom=1167-1294
ksmyth's Avatar
Car: 335xi
Default 10-26-2015, 12:19 PM
have you cured it by adjusting your menu 12 settings?
Default 10-26-2015, 12:33 PM
Not yet, still playing around with settings. There's several of us with this problem, hopefull this narrows it down
ksmyth's Avatar
Car: 335xi
Default 10-26-2015, 02:14 PM
I am sure mine is at 2800. I assume you are working your way down to 2400? or going up?
Default 10-26-2015, 02:17 PM
I've just had the suggestion to work with 12, so at this point I'm set at 2800 and trying to reproduce the odd response. Just driven the car once, nothing yet.
Default 10-26-2015, 02:23 PM
You'd need to evaluate the JB4 target in this situation to determine why its happening.
ksmyth's Avatar
Car: 335xi
Default 10-26-2015, 06:54 PM
Thanks Terry. Which targets are we talking about? Here are my settings.
ksmyth's Avatar
Car: 335xi
Default 10-26-2015, 07:00 PM
trying again...
Default 10-26-2015, 07:10 PM
trying again...
He means targeted boost vs actual, in a log.
ksmyth's Avatar
Car: 335xi
Default 10-26-2015, 08:44 PM
Ah. Got it. I'll do that tomorrow when the car has cooled off.
