DME: Dead Mother Effer... -
09-03-2013, 01:00 PM
Driving last night on the interstate and get SES light. Read codes...
...clear codes and move on
Drive a few more miles, go to pass at half throttle, and it happens. - SES light
- Shudder, loss of power
- Engine runs VERY rough, shakey
- Pull over, read codes....
Car is now at my indy being looked at. It runs but just barely, feels like its going to stall at any second. Didnt drive it any more except to get on/off flatbed.
I've read all the DME threads/repair threads etc. Hoping my indy can fix the diode on the DME if it is just a diode. I'm just over 80k miles, so no emissions warranty work for me.
Any other advice from those of you who have dealt with this before? - Is there anything I can do if i have to get a new DME to make the car better? If i'm purchasing something anyways I'd like to get something out of it if possible.
- Is there any evidence that mods lead to or accelerate DME failure? My guess is no since it happens on stock cars all the time.
- If my indy cant fix, does anyone know a place in Atlanta that can fix? Or maybe a mail-in service?
- If i have to replace the DME, i assume I'll lose the coding mods i have except for the Alpina TCU?
Mods: JB4 G5 ISO, BMS ***, VRSF 7" FMIC, Alpina B3 TCU Flash, cosmetic stuff
Car: 09 E90
09-03-2013, 01:18 PM
Pm member Roy Cormier over at E 90 Post. He repaired his DME successfully. I think he had several misfires as well.
Bravest N54 Owner Award
Car: BMW 335xi
I didn't know the DMEs just broke like that  What model year is your car?
I really doubt the JB4 and TCU flash could have caused it.
Sounds simple but did you check your JB4 connections? What if one of the subconnectors came loose?
 2007 E90 335xi 6AT Premium Pkg | JB4 G5 ISO | Cheap custom exhaust: OBX ********* ***, Secondary *** Delete w/ Magnaflow Xpipe | WedgePerformance Backend Flash ("PUMP") | DCI | BMS Cowl Filters | Alpina TCU Software | M3 flappy paddles retrofit | NGK "one step colder"  Soon: custom oil cooler retrofit, VRSF 7" FMIC
09-03-2013, 01:52 PM
its a 2007. I've had it for almost 3 years with no trouble but apparently the DMEs on these guys just go sometimes.
Good idea on checking the JB4 connections. I doubt thats it but worth a shot.
My indy says there is an open fuel injector recall on my car, so he's talking to BMW to see how to proceed with that.
Super Demigod
09-03-2013, 02:00 PM
I think there is an SIB for faulty DMEs in a certain production date range.
Prodigal Son
Car: 535xi
09-03-2013, 02:05 PM
So far, I have seen this with 07 335i's only. I wonder if its the first wave or just an 07 thing.
Current Ride:  Still picking one
09-03-2013, 03:01 PM
indy says theyre getting signal to all six injectors, but it comes and goes with fuel pressure. Maybe HPFP went? Weird if that threw a 30BA code.
Car: e92 n54 xi
09-03-2013, 03:06 PM
"I think" it might be an MSD80 issue...thus the reason for the MSD81 update in the LCI's which is the '09+ N54 models.
Car: 335
09-03-2013, 04:27 PM
Change out the injector MOSFET...Looks pretty simple to see which one is dead...Roy Cormier is the pioneer
Car: 09 E90
09-03-2013, 05:55 PM
I mentioned this to the OP after his original post and I guess it just went ignored.
09-03-2013, 06:00 PM
Didnt go ignored. I sent Ray's thread to my indy before i posted this thread. Great stuff. I'm PMing him tonight
Prodigal Son
Car: 535xi
09-03-2013, 08:56 PM
Its a simple but intimidating fix.
Car: N54 335i
08-19-2015, 10:59 PM
Bumping this up this tonight this basically happened to me. 07 as well.
Did the Roy Cormier solution fix your problem?
Car: 2007 BMW 335i
08-19-2015, 11:40 PM
Basically. I posted about fixing this problem when it happened to me. I dropped my DME off with a friend who was use to soldering on things like our DME but for rockets and stuff like that. Anyways he had all 6 mosfets replaced in under an hour. Originally I took it to a computer/radio repair shop and several hours later they called telling me they couldnt figure out how to get the old ones off.
07 335i sleeper - PT5858 single turbo - stock exhaust - stock wheels
Car: N54 335i
08-20-2015, 12:46 AM
Ahh alright thanks. Hoping I can find someone on E90post that's willing to do it without costing an arm and a leg.
Car: 2008 135i
08-20-2015, 01:29 AM
My buddy had the same issue. I replaced the mosfets for him and it was back to 100%. If you were local, I'd fix it for you.
2008 135i 4L80E Swap - 807 WHP VM 6466 Single Turbo Kit | JB4 | BMS Flash via MHD | Fuel-It Stage 3 | BMS Port Injection | E85
Car: N54 335i
08-20-2015, 01:31 AM
PM'd.
Car: 2008 535i
08-20-2015, 05:10 AM
DME's are covered under federal 8/80 warranty incase anyone was under on mileage.
2008 535i RB Turbos, ER Charge pipe, Tial BOV, 2.3 gal BMS Meth 75/25, Dual nozzle CM10 and CM7, BMS Race Flash, 3" Down Pipe, JB4 ISO G5, N20 Map Sensor, BMS OCC, BMS PCV Valve, JB4 Mobile App, 12.3 @ 116 mph
Car: 2007 335i
This happened to me -
08-20-2015, 08:12 AM
My 2007 MSD80 DME died. I was at 83k miles and BMW wouldn't cover under emissions warranty.
I ordered the 6 resistors and took it to a TV repair shop. They took the old ones off and soldered on the new. TV repair shop charged $35. All in was <$50. Most expensive part was a rental car for a week.
This was 20k miles ago and no issues since.
I bought the resistors from Digi-Key. www.digi-key.com. Part #FDB14N30TMCT-ND
http://www.digikey.com/product-searc...DB14N30TMCT-ND
You need 6 but I got 7 in case repair guy botched one. $1.37/each
Oh snap... Just noticed you are in Atlanta. I used Rapid TV Repair in Marietta right by Dobbins Air Force Base - 678-439-9637. It took maybe 15 minutes when I went by. Can not recommend him enough.
2007 n54 e90 sedan (1/07 date), JB4 G5 ISO - Map 3, BMS DCI, BMS Trunk Tank Meth Kit - two nozzle - CM7/CM10, BMS OCC, MHD Trebilia Flash, e60 (5 gallons of 93 and 11 gallons E85), Stage 2 from Fuel-It, VRSF 7" FMIC, N54tuning.com V1 DP, ER Charge Pipe w/Tial BOV, NGK Iridium (one-step colder) plugs, N20 TMAP Sensor, RB turbo inlets, VTT outlets
Car: N54 335i
08-21-2015, 12:29 AM
Going to call up some shops tomorrow. Hope I have some luck.
Car: 08 335i 6MT Coupe
08-21-2015, 08:32 AM
I paid an engineering student at my local university $20 to solder them on. :D
2008 E92 335i Coupe 6MT | Apex Arc-8 18x9.5 | MHD: Stage 2 93oct | CP-e Charge Pipe | Active Autowerke BOV | DCI | VRSF C*****S D*******S | VRSF 5" FMIC | Cyba Air Scoops | BMW PE Mod
