(#151)
Oilphase Oilphase is offline
Car: 335i sedan
Default 11-03-2013, 03:20 AM
Originally Posted by jacobniell
Is it just me or is this not for the IPhone as mentioned in the beginning?
still under process check post 146 to 150
(#152)
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 11-03-2013, 04:37 PM
Originally Posted by N54mike
Terry only uses the ground tx and rx lines. I'll take a look at the ble mini. You'll have to source the 5v from either the stock dme harness (on of the 5v sensor reference pins) or tap into the JB's 12v signal and regulate and filter it down to 5v.
Ahh. Thank you. Missed this reply somehow. I just found out that I may be able to a USB OTG setup as well since the BLE Mini has a usb serial interface.
I'll still need to wire in for power though.
(#153)
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 11-03-2013, 10:58 PM
how do you update this on a MAC? Just delete and reinstall the latest link?
When i go to the "About JB4 App" it shows 1.1.(1)
Is that the latest?
(#154)
Car: 2008 135i
Default 11-03-2013, 11:02 PM
Is that the latest?
When you drag the JB4 app into the Applications folder it should ask you to overwrite it. To be sure, goto the Applications folder and delete whatever JB4 version is there. Then just drag in the newest. I added a new text field to the "User Adjustment" page that shows the build version. 1.0.3 is the newest.
(#155)
Car: 2008 135i
Default 11-04-2013, 06:15 PM
First post is updated with a new video.
The iPhone can finally communicate with the JB4!! Been working on this for a bit so I'm excited to finally get some success. I'll release a beta once I make sure everything works all good and stuff.
The plan right now is to start with a few displays, code reading/deletion, and saving a log file.
(#156)
Cynical Cynical is offline
Default 11-04-2013, 09:17 PM
for some reason I can connect? osx 10.9
(#157)
jtrejo jtrejo is offline
Car: 535 2008
Default 11-04-2013, 09:20 PM
mine works perfect
(#158)
Default 11-04-2013, 09:23 PM
yea i had a selection error for the usb . works now
(#159)
Car: 2008 135i
Default 11-04-2013, 09:36 PM
Originally Posted by musc
Did some logging tonight. The green works good but it would be cool if when we hit the space bar again to stop it the text bar would turn red. Other than that things are still working good!
Glad to hear it. In the version I'm about to post, the red color is reserved for errors, green is logging, and white means not logging and just displaying a message of some kind. If it becomes absolutely necessary, we can throw in another color, but it's usually good practice to have certain colors reserved for certain events.
(#160)
Peter @ Pure's Avatar
Car: F20 M135i
Default 11-04-2013, 10:04 PM
Very very nice :-) as soon as you release let me know what hardware i need to buy. Keep up the good work.
(#161)
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 11-04-2013, 10:39 PM
Great work! The iPhone interface looks very promising!
335is DCT
(#162)
_ink's Avatar
Car: 335i DCT
Default 11-05-2013, 06:27 AM
Awesome thanks! So im doing it right.
OMG i cant wait for this!! Just recently, I got a code and because i live in an apartment its not always convenient to go up the elevator, get my laptop and come back down... This will eliminate all that!!
Interested in becoming an Aussie Beta Tester!
(#163)
Car: 335i sedan
Default 11-05-2013, 11:45 AM
That's good start looking forward to see the final app !!
(#164)
2Times's Avatar
2Times 2Times is offline
Car: 08 E92 335xi
Default 11-06-2013, 07:06 AM
Man you're smart. I wish I knew how to do this stuff, I'd offer to help
(#165)
musc's Avatar
Car: 335is DCT
Default 11-08-2013, 12:23 AM
I did do some more logging with the latest version and noted an error. I was plugged in and was driving around logging. I was still warming the car up so I decided to stop that log and start another. While I was logging the left lower text box said Logging started and was highlighted green. When I pressed the space bar, the logging stopped but the text bar didn't change and remained green with the same text. I could tell it was stopped because my RPMs weren't moving. I hit again to start a fresh log and it still stayed green and the logging resumed.
I decided to stop and restart it and the next time when I stopped it it changed to no color and said something like plotting 298 of 298 or something along those lines. Any reason why it may not be showing that it is stopped consistently? I usually just like to look over and see the green color for active and no color (or red, orange etc) for inactive. Thanks for all your hardwork on this! I think we should get Terry or Russell to make this a sticky. I am sure there are a lot of mac users out there that would use this.
335is DCT
(#166)
Car: 2008 135i
Default 11-08-2013, 08:59 AM
Ah. There might be a bug between stopping logging and updating the status bar. When you stop logging it should say all that "Plotting x of y" stuff in white. I'll look into it again. And yea, I'm glad I could give back to the community a bit, hopefully once everything is all finished they will sticky it.
I've been mainly working on the iPhone stuff the past few days so I haven't gotten a chance to mess with the OS X version much, but I'll be taking another look today.
As an update on the iPhone side, I have a decent speed display, boost gauge, rpm gauge, and gear gauge currently working. Also code reading and deletion is working. I'm not a graphic artist so it might not be the prettiest thing in the world, but it will work.
(#167)
MasterWang MasterWang is offline
Car: 2007 335i e92
Default 11-08-2013, 09:03 AM
Maybe some of us could help with the graphics?
(#168)
Trickcruiser's Avatar
Default 11-08-2013, 09:21 AM
Depending on what you need, I would be very happy to help you with graphics. I make my living in the design field.
(#169)
Car: 2007 335i e92
Default 11-08-2013, 09:25 AM
I don't make a living in the field yet, but am a graphic design major at KU.
Actually working on an iPhone application for a school project right now :D
(#170)
Car: 2008 135i
Default 11-08-2013, 09:39 AM
Some help with the graphics would be great.
Here is a list of graphic pieces and sizes if needed (dimensions are in pixels):
icon - 1024x1024
Gauges - Big enough so the text is easy to read
Connect button
Disconnect button
Read Codes button
Delete Codes button
Close button
Here are links to screenshots of what I have so far.
Image 1
Image 2
The design is still very early.
(#171)
Default 11-08-2013, 09:56 AM
The N54 community is very refreshing to me! You just don't see people helping each other out like this all the time anymore.
Wang,
Please let me know if your going to tackle this. My time is a bit limited so I do not want to duplicate efforts. If you do not have time, I will start putting something together in the next few days as time allows.
(#172)
alexim's Avatar
alexim alexim is offline
Car: 1M
Default 11-08-2013, 10:19 AM
Cannot thank you enough for this... OS X and iOS apps are a huge help for us Mac users.. Too bad my car is in the shop for now... Will test and donate soon as I get the car back.. Thanks again!!!
(#173)
Car: 2008 135i
Default 11-11-2013, 07:10 PM
You're welcome.
Everyone please check the updated notes in the first post pertaining to firmware updates.
(#174)
Car: 2008 135i
Default 11-11-2013, 07:28 PM
BLE Mini and plug for JB4 wire with a cheap diy enclosure (I'm still looking for a nice enclosure, but this works for now).
BLE Mini end and USB end side-by-side.
Eventually I'll get a list of parts for a kit so you can either buy the stuff yourselves or through me. The diy will be straightforward but essentially, cut the usb end off about 7 inches before the plug, strip some wires, solder a few points, done. Then you can switch from your the adapter to the usb end on the fly.
(#175)
psmitty95's Avatar
psmitty95 psmitty95 is offline
Car: 09 335i xDrive 6spd
Default 11-13-2013, 05:32 PM
If this gets made into a working iphone/ipad app that can log and clear/read codes that would be amazing
< Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion
Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning
More Pictures: Build Thread /// Dyno Soon to Come
Closed Thread
