(#1701)
Default 03-11-2011, 12:42 PM
You should be able to find some 100 - 104 unleaded. Sunaco GT260+ is a good 104 octane version, that goes for around $10/gallon. Just run the 93 until --- showing on miles left and add 2-3 gallons of the 104.
MeinBMW MeinBMW is offline
Car: 09' 335i
Default 03-11-2011, 01:05 PM
Will do Terry ... I'll post up my results tonight!
DocHarriers DocHarriers is offline
Default 03-11-2011, 01:39 PM
Late to the party, I know, but I've a few questions not answered on the first page and I'm considering actually making my purchase soon, now finances are working out.
The in-dash gauge stuff - is there a link to how to enable/disable that, what can be shown, etc? How is the live switching done? Is there a plan for a valet map, or can I do that myself in the custom map?
I'm happy to be told a page number to go read this one, too. I'm basically jsut after the "how it works" since the first post, and trying to avoid reading all 70 pages.
Default 03-11-2011, 01:45 PM
It's all in post 1. Including how to enable/disable the dash hijacking, select map 0 (stock map), etc.
DCTepper DCTepper is offline
Car: '07 SGM 335i
Default 03-11-2011, 01:46 PM
Most everything can be switched live on the fly. All of the gauge hi-jacking options are in the table on the first page (Speedo at 2). Valet map is called 'transport map' and is available (Speedo at 4). Take a look and let me know if you have more questions.
Car: 09' 335i
Here is the layout of the gauge controls ... it take a couple minutes of fiddling with it to figure out, but after that it's really easy
Map 0 is stock ... and Option 4/2 turns valet mode on (sets rev limit at 4500)
Excellent. I shall go back and read again then. Thank you!
TG284's Avatar
TG284 TG284 is offline
Dude, your bed is a car
Car: E92 335
Default 03-11-2011, 01:48 PM
See the text at the top of the img
Car: '07 SGM 335i
Default 03-11-2011, 01:52 PM
I knew I shouldn't have bothered replying because 3-4 others were going to reply at the exact same time!
NihonX NihonX is offline
Car: 1M
Default 03-11-2011, 04:04 PM
Can I get a discount on another one when I get my 1M?
chilam1019 chilam1019 is offline
Car: 2009 E60 535i
Default 03-12-2011, 02:54 AM
Terry:
i just installed the JB4. it works super great.
i have a question
what is Transport mode / 4500 rev limit ON and OFF?
e46m3to335i's Avatar
Car: 2015 F22 M235i
Default 03-12-2011, 04:45 AM
Originally Posted by chilam1019
Terry:
i have a question
Its like a vallet mode. It wont allow the car to go past 4500 rpm when it is enabled.
The search button works wonders and im pretty sure this question has been answered in this thread before.....
-Nick
DeadEye's Avatar
DeadEye DeadEye is offline
Default 03-12-2011, 05:04 AM
Slightly OT but have you got a delivery date?
Individual Velvet Blue Manual E90 335i M-Sport.
Default 03-12-2011, 11:31 AM
Terry:
i have a question
It's an OEM feature that hits a hard limiter at 4500rpm. Kinda scary if you WOT in to it so I don't suggest it. But it's there for your enjoyment.
dirtyballoonot dirtyballoonot is offline
Car: 2007 335i Sedan AT
Default 03-12-2011, 04:12 PM
Got my JB4, CAN Tool and BMS DCI last week. Did a baseline dyno today (267RWHP) and really wanted to throw the goodies on, but, none of my mechanically inclined buddies were free today, and I don't even own tools.
Next week I'll prob let the shop handle it (Titan Motorsports) and dyno it again. I'm pretty excited, but must admit all of the info/instructions seem to be scattered, and it might be a good idea to add a small card with the steering wheel controls/maps on it...
If I understand correctly MAP5 has to learn, so, should I do some blasts on the highway before I throw it back on the dyno?
SIDE NOTE: I freaked out when I got in the car after the dyno and had like 5 CEL's
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 03-12-2011, 04:44 PM
Yup do some 3rd full throttle and 4th gear full throttle blasts on the highway 3 or so times for the car to adapt on map 5, let it cool and throw it on the dyno. Let it cool between each run and make sure they got good fans in front of the car, this car like to get blasted by fans and air on a dyno.
2014 F10 535i N55 PWG
Default 03-12-2011, 04:45 PM
Why wouldn't I just punch it from the get go? WOT from start...That's how I drive everywhere, LOL
Default 03-12-2011, 04:51 PM
Everything you need should be in the first post. If you find anything missing let me know and we'll get to work on adding it.
Optimizing performance for the dyno and on the road are different things. Map 5 is meant for road optimization. You can run it on the dyno but don't expect anything special out of it.
Default 03-12-2011, 05:15 PM
Terry, sorry, I meant the instructions for everything, the DCI install, the CAN tool, the USB cable, the JB and all the codes/modes. You have the PDF's and the vids on the support page, but, the PDF mentions nothing about what to do when you have it installed. I was just suggesting that it might not be a bad idea to throw a copy of this OP in the box at a minimum, but a small cheat sheet for the glove box probably wouldn't hurt. I actually have no idea what the CAN tool/datalogging is used for, I just got the package because it seemed like a good deal, LOL
So, I wouldn't likely see much improvement on the dyno? It will still be pushing more boost, right? Should I dyno it at stage 1 then?
If I had to make a suggestion though an iPhone/Droid app would be sweet so I wouldn't have to drag my laptop out to the car, or iDrive intergration (I know both are probably stretches, but, that would rock)
Default 03-12-2011, 05:19 PM
You'll definitely see more performance with map5. Just advance warning that it is not meant to optimize dyno numbers. If it were, it wouldn't work as well as it does on the street.
Default 03-12-2011, 05:47 PM
i obviously care more about real world performance...maybe I'll do some pulls in 1 and 5...
Did I read that 5 is default?
Default 03-12-2011, 05:52 PM
1 is default. If time permits do two pulls on map 5, a pull on map 1, a pull on map 2, and then a stock baseline on map 0.
Default 03-12-2011, 06:04 PM
That shouldn't be a problem...any prepping, or a particular order to do them in? I think I'll want to use 5...if this is too much for the thread you can PM...
Any, logging you want or need?
Default 03-12-2011, 06:07 PM
If you are spending the money on dyno time never a bad idea to log as well. If you need any addl help just email me.
Default 03-12-2011, 06:28 PM
Did that...Thanks
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
