Car: 09' 335i Sedan
02-26-2011, 02:49 PM
Originally Posted by mikeyt13
I follow the jb4 files and it just ends up in an empty one. Cant figure it out
Use the "search" feature in windows and find it that way.
02-26-2011, 07:11 PM
Originally Posted by Orlin
Do I need this? or should I just wait for the next update?
I would do it. Makes gauge hijack so much easier to read.
Car: 335I
02-26-2011, 09:21 PM
i wish i could ever understand whats "gauge hijack" !!
Car: 2009 335i AT
02-26-2011, 09:29 PM
"gauge hijack" is when you request the JB4 to change the normal display functions of your fuel and oil gauges to read other variables; such as boost or engine timing under certain conditions, such as throttle greater than 50%, for example.
Car: 335I
02-26-2011, 10:09 PM
thanks
az335iat ,but my question ,would u have enough time to look at those variables when ur racing / playing around?!
02-26-2011, 10:12 PM
The boost gauge on dash is the best thing since sliced bread. I personally also use timing on dash all the time when tuning.
02-26-2011, 11:08 PM
Love that boost on fuel but my vote goes for slice bread
Car: 335I
02-26-2011, 11:12 PM
well i do appreciate sliced bread but unfortunately i dont know how to use /enable gauge hijaking ,i couldnt find enough info on how to do this on first page.
Any 1 have can throw a slice of info to young student like myself?
02-26-2011, 11:14 PM
It's all in the first post. Steering wheel controls guide is an attachment with the directions right on top of it.
Car: 335I
02-26-2011, 11:19 PM
terry i can see that clearly ,but let me explain this the way it should be explained to a beginner like myself:
"use the in dash controls to enable / disable gauge hijaking ,for example option 2 ,1 will let u use the petrol meter to read "Boost on Fuel" information ,so the petrol needle will tell ur boost info instead of petrol info"
my question ,whats the "timing on Fuel"? ,how can i interpret this reading?
02-27-2011, 03:25 AM
The JB4 is defaulted to 335/535 USA mode. If you have a 135 or metric 335/535, you will pick the appropriate option to recalibrate the gauge read outs. Once selected the gauges will all center themselves at midpoint to let you visually verify if you've selected the proper mode.
Hey Terry, would you use this so it's easier to see which options are set with the jb4 or for things like boost gauge hijack or both? I don't have the JB4 yet but will look to buy it next month so just wan't to check before I order.
Car: UK 140i-M Sport Auto
02-27-2011, 05:51 AM
HELP, how long does it take to upload the new firmware 022111 to the JB4, Mine has been doing it for 25minutes, and it still says "loading hex"....
Car: 335xi Sport
02-27-2011, 07:21 AM
bazbar...should only take about 2 minutes....something like 430 blocks of data?
2013 335i M-Sport - 6MT - Not too many mods.....Yet !
Metric Speedo Calibration issue -
02-27-2011, 09:35 AM
Hi Terry,
I can confirm that the custom firmware you gave me fixed the calibration with the 135i speedo.
02-27-2011, 12:30 PM
Yes that is on my "to fix" list!
Terry you need to look at the one-click thing I mentioned.
You just need your own MS Website and in Visual Studio, you just publish the app to the web site. The first time we install, we go to a URL, from then on, the software checks for updated when it launches.
Like the BT software
Individual Velvet Blue Manual E90 335i M-Sport.
Velocity Challenged
Car: 2007 335i AT
02-27-2011, 05:05 PM
T, looking forward to you porting autotune over to map3
Any chance you can add an option to have the blinkers flash a few times if it sees a knock related timing drop? Or maybe an option to kick it down to map 0/4? I figure once the map adapts you really should not see a timing drop unless there is something wrong.
02-27-2011, 05:17 PM
Timing drops are fundamental to the autotuning concept. But the idea is to identify and limit them vs. running too hot of a map and having them come up several times per gear run after run.
02-27-2011, 05:50 PM
Don't we get timing drops even at stock boost levels?
11 335d M-sport JBD 12.3 @ 110.48
12 LEAF 106 MPGe
08 335i Sedan 11.11 @ 129.43
08 335i Coupe JB3 2.0 11.33 @ 132.77
60-130mph: 6.95 seconds
02-27-2011, 06:04 PM
Of course. But the more drops the better the indicator that you don't have enough octane to support the power levels you're producing.
02-27-2011, 09:07 PM
Terry, once you gather data, is there an auto-tuning map that works with progressive meth on the horizon? Loving map 3 + CMGS now but auto tune would be nice.
02-27-2011, 09:25 PM
Yes once more data is collected that will be on the horizon.
Car: 07 E90 335i
02-27-2011, 10:45 PM
Anything in the works for a launch control feature? Still struggling to get much traction in 1st gear.
Car: E92 335i
02-28-2011, 12:36 AM
Terry - what is it exactly that we need to look for in the timing?
BT cable favor request -
02-28-2011, 10:08 AM
Has anybody here who has the JB4 (set in map zero) tried to adjust condition based service using the Barvarian Technic software?
My BT software worked before the JB4 but it will not reset CBS now. I can not communicate with the modules. Will somebody pelase see if you can adjust something harmless your cabin filter status? Or change your spark plugs by 1 percent and see if it will adjust the values?
02-28-2011, 10:40 AM
If you're doing your own tuning, which we don't suggest, you'll want to look for frequent sharp drops over 4800rpm but before the shift, that are not DTC or throttle related. Those indicate an increase in knock sensor activity and that you're potentially too hot for your octane.
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests)
