Turbo Lover
Car: 300zx TT, 1M
01-21-2011, 06:46 PM
Hmm, project black box......
Enginerd
Car: 2009 135i
01-21-2011, 06:52 PM
Haha.... Perhaps the name oversells the merits of the actual project.
--2009 BMW 135i--2016 Nissan Titan XD (Turbo Cummins ISV)--2016 VW Tiguan 2.0Tsi --1988 Beechcraft Bonanza--Suzuki GSX-R 1000--Honda CBR-600RR--
JB4 G5 ISO | MHD | E85 | Fuel-It S3 LPFP / PI | MFactory S3+ Clutch / SMFW / LSD / Mounts | Diff Lock | UUC Tranny Mounts | DwnPipes / Exhaust / FMIC | Chargepipe / Tial | KW V3s | HR Sways | HPA full M3 Suspension | BMS DCI / Oil Cooler Valve / Cowl Filters / 4bar / 2Step / OCC | RB PCV | Stri Gauges | Pole Position 225/265 | Installing: DR 6466ST
01-21-2011, 09:34 PM
Terry, whats the status of availability to enable "Max Cool" feature?
///135i LeMans - Riss Racing OCC, Shadowline Grills, Magnaflow Axle-Back, JB4, ETS FMIC, BMW DCI, BMW Perf Side Skirts, E93 M3 Front Sway
Flickr
01-21-2011, 09:44 PM
I've been slacking a bit with that working on other features. It hasn't moved beyond the "we found the right can commands" phase yet.
Velocity Challenged
Car: 2007 335i AT
01-21-2011, 10:01 PM
You're such a slacker T...
01-21-2011, 10:30 PM
Terry I think it's time to clone yourself to produce half a dozen Terry's with your work load.
Maybe you can add that to the CAN system.
01-21-2011, 10:52 PM
I have the number to Re-pet somewhere around here.....
Flickr
01-22-2011, 02:48 PM
Hey Terry, not sure if it's been brought up or not already since there's about a million pages on this post already but how about getting some rev matched down shifts out of the JB4? I'm assuming that since we can have gear dependant boost then the JB4 must have access to what gear the tranny is in and then match the engine accordingly...
01-22-2011, 02:53 PM
It is possible but not on the radar right now. Would require a lot of safety testing.
Turbo Lover
Car: 300zx TT, 1M
01-22-2011, 03:07 PM
379Z style
370Z style! That would be awesome.
Car: 335 coupe
01-22-2011, 03:26 PM
Does it only assume first and second gear by the wheel speed?
01-22-2011, 03:41 PM
It comes from the DME itself.
01-22-2011, 03:46 PM
Ok cool, just wanted to plant the seed you know... Lolz, yea I was thinking 370Z style, kinda novelty bit still cool and I would use it... I know it'd prolly take time to perfect but in simple terms it seems easy enough, DME gear sensor and a predetermined engine speed based on DME speed info, prolly be an extensive amount of calculations that my simple mind can't fathom......
Car: 335 coupe
01-22-2011, 07:09 PM
Do you think there's some sort of strain gauge in the shifter or is the DME assuming it by wheel speed?
01-22-2011, 07:11 PM
It's pretty spot on with manuals, even goes to 0 during the shift. Must be a sensor.
Car: 335 coupe
01-22-2011, 07:12 PM
Neato.
01-22-2011, 09:02 PM
Yea that's what I guessed, lol, took my car for a spin a few mins ago for the first time since installing the JBfour and saw the gear field change while monitoring my run, oh yeah thanks for the awesome product Terry, I noticed a HUGE increase in butt dyno horsey powers, lol.
Car: 335I
01-22-2011, 10:07 PM
guys may i throw an amateur Q :whats CAN? what is it used for?
Car: E90 335xi 6MT
01-23-2011, 12:21 AM
Terry,
I have a fully stock 335xi (other than JB4 of course!) at 5200 ft elevation. If I planning on running around a 50/50 mix of 91 octane & 100 octane (around ~95-96-ish octane) for either a couple of drag strip passes or dyno pulls, which map would you recommend? Should I stay on Map 1 (car is still stock), or should I bump it up to Map 2 due to the higher knock threshold using higher octane fuel (around 95-96 octane or so)? Thanks in advance!
P.S. The partial throttle boost onset really is MUCH smoother than it ever was on the JB3... I was truly shocked that it was actually so readily noticeable. Very nice
Car: 2007 335i coupe
01-23-2011, 08:40 AM
Controller–area network (CAN or CAN-bus) is a vehicle bus standard designed to allow microcontrollers and devices to communicate with each other within a vehicle without a host computer.
CAN is a message based protocol, designed specifically for automotive applications but now also used in other areas such as industrial automation and medical equipment.
Wikipedia makes everyone smarter
It's pretty much your car's computer system. It controls your displays. It takes input from the driver via buttons, switches, etc. It does all kinds of stuff but I'm sure Terry could give you a much more elegant answer.
Ma need more protein !
Car: 2009 335i x drive
01-23-2011, 09:55 AM
Just curious if anyone has come across this issue.
Ran map 6 on 93 octane for about a mile...got a SES light..im assuming this is because its not running race fuel....activated the code clearing and went back to map 2 alls well. Just curious
2009 335 xdrive - Muff Delete, JB4 (ALPHA), DCIs, V701 GM, CF Splitters, +mas
Car: 2010 335i
01-23-2011, 11:02 AM
I've ran map 6 and logged a couple runs and I didn't get any codes.
What did you have the boost settings at?
01-23-2011, 11:28 AM
Map 6 is for doing custom mapping. If you don't know how to do custom mapping (including reading any codes you generate) I strongly suggest not touching map 6.
01-23-2011, 11:29 AM
It's just a communication standard the vehicle modules use to communicate with each other. Giving the JB4 the same module allows it to "join the club" and get all the dirt and gossip on the other modules including the DME.
Car: 135i and M3 E30 Evo III
01-23-2011, 11:30 AM
One thing is top urgent for the MAP 6 users! Look at your timing!!!!
Babyjoe
