(#126)
worm worm is offline
Car: Kia Stinger MY20
Default 04-01-2020, 04:13 PM
OK! But other than that it's correct! Thanks!
Default Please check... - 04-01-2020, 08:18 PM
Hi there,
I have installed my EWG connectors and updated my firmware version to V14...
I initially tried Map 2 with Duty Bias set to 40...
I look at the logs and you can see the ECU_PSI and BOOST2 are showing it's underboosting...
so, I updated Duty Bias to 45 and using Map2, I test again... This time, my car was coming on boost again!!! and it felt much better... But still slightly held back.
I tried Map5, as you can see it's holding boost pretty well constant and the car feels good.
My question... How do I check the fuel pressure?
Can you please have a look and see if I am reading everything correctly?
Default 04-01-2020, 09:29 PM
Give me some longer full throttle runs!
For FP_H just monitor it to ensure it stays above around 9 at WOT. When it dips towards 7 the JB4 goes to map0, at around 5-6 you'll get misfires/stuttering.
Default 04-02-2020, 03:47 AM
LOL It's kinda hard right now to do big power runs! Lockdown...
Cops are looking to get people...
Eveything looks ok so far though right?
whytiptoe whytiptoe is offline
Car: 2019 Kia Stinger GT2
Default 04-02-2020, 06:42 AM
If you get pulled over while you are reaching to hand them your info just sneeze on your stuff and start to cough a little.
Default 04-02-2020, 08:34 AM
Seems fine to me! Runs should always ONLY be done on save private tracks.
atr1 atr1 is offline
Car: Stinger GT
Default Yesterday, 10:58 AM
Hi Terry,
What is the general tuning strategy with these wires?
What do you look for in a log to decide what parameter to change next?
Let's assume you're on stock turbos and the goal is to be faster.
Default Yesterday, 11:08 AM
Most customers run the default settings. If there is an over boost situation or another car specific oddity then we try to address that.
jsbowling42 jsbowling42 is offline
Car: Q50 Red Sport
Default Logs - Yesterday, 05:26 PM
Here are some logs I took on my RS with e15 Mix at 94 octane with the new EWG. One is with the duty cycle set at 55 across the board and the other is 60. As my car typically underboost. How they look?
stock_stinger stock_stinger is offline
Car: 2019 STINGER
Default Yesterday, 07:07 PM
took the car for a drive, this is + meth now
