(#476)
beetle6986 beetle6986 is offline
Car: e90 335xi
Default 04-12-2020, 11:05 AM
Yes that is the current N63 tuning path.
Start with JB4 map1 or map2, when you want more move in to a flash map with JB4 map6, and then if you want even more you can add in the 3.5bar TMAP sensors which the JB4 supports.
I have a 2013 X5 50i. Can you help clarify a couple things. If I buy a JB4 stage 1, I can run map 1 or map 2. Map 2 gains are around 40HP and 40TQ?
Also, is there any recommendation for a flash tune to run with the jb4 to get a little more out of it? Are there OTS flash tunes I can use like I have from MHD for my n54?
I'm not looking for anything crazy or unreliable. I was hoping to get around 75HP and 75TQ out of this thing with a tune.
08 335xi - 6MT. JB4 ISO, map7, MHD E85 BEF, E50, DCI, VRSF p1p3s, VRSF FMIC.
04 Cobra - Intake, Borla/Bassani exhaust, FMIC, pulley, tune.
tremag2001 tremag2001 is offline
Car: 2012 BMW 550xi
Default 04-21-2020, 03:21 PM
I installed a BMS stage 1 to JB4 upgrade with BCM 3 years ago and can't find the wiring diagram with pin connections. Can someone please post a link or email?
PPMKing PPMKing is offline
Car: 2013 BMW 550 xDrive
Default N63 Firmware - 04-22-2020, 07:40 AM
Can I use the JB4 N63TU with a N63 engine if I update it with the N63 firmware?
Default 04-22-2020, 05:24 PM
Depends on the vintage. Newer N63TU systems are PWG v2 and would not be N63 compatible.
Default 04-22-2020, 06:08 PM
Thanks for the reply.
If I buy the current JB4 for a 2013 550 (N63), can I buy the mobile wireless option or I have to use the BMS wired connection?
///Monst3r ///Monst3r is offline
Car: 07 335i
Default 04-24-2020, 08:52 PM
Just sold my 2012 650i and picked up a 2015 550i. Will I have to independently sell my fairly new JB4 and pick up another one or can it be swapped out for credit towards a new one?
07 e92 MT 335i- JP works TS TM 6466 1.0 a/r, custom 4in fmic, vrsf cp, tail bov, custom catch cans, external pcv mod, adv O2's, phoenix intake manifold,fuel it port injection, bms meth kit dual cm10, Motiv twin disk, 450/540 in tanks/ 6an return and regulator, stoptech drilled and slotted rotors & pads,15in drag setup , ST coilovers,berk full exhaust ,jb4 g5, mhd
2012 650i- D0wn pip3s, jb4, custom drop in filters, carbon filter delete
ColeRandall10 ColeRandall10 is offline
Car: 2012 BMW 550XI
Default 2012 BMW 550XI - 04-28-2020, 11:05 AM
Been trying to learn how to read the logs.. but would rather get some better insight.. somethings wrong and I can稚 figure out what is wrong..
Cars in map 1 JB4 on 91... has n63 intakes, turbosmart bov, vrsf ******* *********, E85 fuel pump, x-HP transmission tune, n63 oil sport cooler valve
Wht550Jersey Wht550Jersey is offline
Car: 11 550i
Default 05-20-2020, 02:22 AM
You ever figure out what痴 going on Cole?
Krossfitkev Krossfitkev is offline
Car: 2012 bmw 550i
Default Drivetrain malfunction at wot - 05-23-2020, 06:19 AM
Ok guys, I知 new to this, and I want to figure some things out. I have a 2012 550i, and I知 getting a drivetrain malfunction. Looked at the code and it says air mass flow too high? So I知 guessing I have to change my tmap sensors correct? But I知 also looking at the boost I知 running on map 2 and it only hit 16 max. I have Arm car less *********, Megan axle back exhaust, and diy front mount intakes. I data logged it so that you guys can see and let me know where am I going wrong.
Default 05-23-2020, 08:07 AM
Yes for MAF code change the MAF sensors.
Boost looks normal to me.
Car: 2012 bmw 550i
Default 05-23-2020, 08:23 AM
Thank you for the quick response, I will try to get that done today, if not soon. How would I be able to push around 20 pounds of boost. That is what I’m aiming for
Default 05-23-2020, 01:01 PM
N63 life so you have limited options. Look in to a flash tuner to get you clsoer and use the JB4 for fine tuning, logging, boost by gear, and safety.
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
Copyright ゥ 2007 - 2020, N54tech.com
