(#3226)
alawadhi3000 alawadhi3000 is offline
Car: Genesis G70 3.3T Sport
Default 05-18-2020, 05:10 AM
Grab a run on map2 for comparison.
Map2 run in a hot weather (about 35C/95F).
ValkyrieMedic ValkyrieMedic is offline
Car: 2019 Stinger GT2 AWD
Default Connection of Fuel-it Sensor to JB4 question - 05-19-2020, 03:21 AM
On the main web page for the kit it says to connect the sensor to the #4 on the JB4 harness and Select WMI page option 2/3 input to enable.
On the installation pdf it advises: Pin locations All others = Pin 16
Within the JB4 app on the ethanol/E85 settings set “signal scaling” to 100, check off “JB4 15/16 FlexFuel Input”. and also.....*hint* If your pin location is occupied and you are not running a meth FSB, insert the white wire in to the same pin location the orange meth FSB wire would typically be installed in, typically pin 2 or pin 3. You will then need to change your JB4 FlexFuel Input accordingly in the JB4 software or mobile app to “JB4 2/3 FlexFuel Input”.
I currently don't have WMI, but may add it in the future, so I want to leave the appropriate spot open for the FSB connection. I do already have the Fuel Wires, EWG wires and blue-tooth connections up and running.
Can someone clarify what position I should connect the Fuel-it sensor to on the JB4 if I plan on adding WMI in the future and what settings / changes I should make within the app.
Default 05-19-2020, 08:16 AM
I like the way this looks more on the data end. But I know that is just part of the equation if map 3 feels faster behind the wheel.
For the Kia it's spot #4, so there won't be a future conflict with WMI or CPI.
Default 05-19-2020, 01:33 PM
Thanks, is map 3 safe to run from time to time?
sipes1946 sipes1946 is offline
Default 05-19-2020, 02:12 PM
just installed a new JB4 with bluetooth module on my 2019 Stinger GT2
install was fine--located and connected the 2 fuel wires...did I find the right 2 red wires?!?!
updates to the newest stable firmware version
everything went well--until---
connected OBDII connector and the car wouldn't start- disconnected and reconnected
car started hard with check engine light and several system failures
read codes: 0698 and 2122 (clear them but they return)
only ran car on MAP0 and MAP1---reset and restarted app and car---check engine light cleared as well as any other dash failure codes--the OBDII codes persist
was able to drive home from the office using Map1--I logged (see attached for details)
http://prntscr.com/sk00em
those two codes (0689/2122)_ did not appear...is all well?
Default 05-19-2020, 04:37 PM
Good first step is photos of the install to cehck for anything out of place.
Default 05-19-2020, 04:46 PM
in response to me?
did my log look good? I guess that would tell the story
Default 05-19-2020, 05:12 PM
Originally Posted by sipes1946
in response to me?
Log is short, seems OK. But codes are not normal. Might be easier to email them in, terry@burgertuning.com
Default 05-19-2020, 05:15 PM
I emailed you the log and the screen capture of it...I can run a longer log tomorrow if needed
Default 05-19-2020, 11:16 PM
Thanks Terry!
Peter_Stinger_GT2 Peter_Stinger_GT2 is offline
Car: 2019 Kia Stinger GT2
Default E85 Question (Terry) - 05-20-2020, 11:32 AM
Just a quick question, and I did search E85 on this site before asking, and it surprisingly found no results for the search phrase E85. Been running 100 Octane Unleaded Race Fuel about once a month, however that gets very expensive. I have seen both in the forums and Facebook Groups where people are mixing 4 to 5 gallons of E85 and topping off with 93 Octane. I am also seeing some people saying that E85 will obliterate your fuel system. But when I read the latest maps it clearly advertises 30% E85 mix is acceptable for Map 4 as an example. I stopped by the only Gas station in the state which sells E85 and filled up 4 five gallon gas cans, but I just wanted to confirm that this can be put in to my Stinger GT2 (with upgraded plugs, exhaust, FMIC, and Intakes)? Plan was to bring the car to the gas station, put the 5 gallons of E85 in and top off the remaining with 93 octane. Just want to make sure that is OK to do? The other users right on it obliterating the fuel system? Please advise and thanks very much
Default 05-20-2020, 01:17 PM
Not seen any issues running 5-6 gallons of E85 rest pump gas, in our longer term testing, nor heard of any from many customers running it. Some countries have E25 mandated by law so everything is more or less E85 compatible these days.
Default 05-20-2020, 01:35 PM
Thanks very much Terry! Definitely gives me some peace of mind. Having the M45il plugs, MBRP ***-back exhaust, K&N Typhoon intakes, and the front mount intercooler on its way from your shop, should I be able to do this 5-6 gallon E85 mix and utilize Map 5? If you think so, I will send along a log of the results. Recommendation?
Default 05-20-2020, 02:56 PM
Map5 might be a bit much, I'd start with map3.
Default 05-21-2020, 10:50 AM
One last question Terry. You sell the Fuel-It FLEX FUEL KIT for KIA 3.3L -- Bluetooth & 5V on your site. Is there a great benefit to using this product that I wouldn't get if I did not have this "Fuel-It" product? I know I can run the ethanol mix without it, but I wanted to know if there were a major enough benefit to having this product whilst running the car with the ethanol mix? Thanks
Default 05-21-2020, 01:58 PM
For most users not a huge benefit, just something fun to have, especially if you like to change fuel mixture soften and want the JB4 to adjust accordingly.
Jaymorz Jaymorz is offline
Car: Stinger GT2
Default 05-23-2020, 12:13 PM
Hi Terry,
I purchased the JB4 unit w/ fuel wires & Bluetooth connect 6 months ago and I am finally getting around to installing it tomorrow.
I just purchased the app and saw the firmware available for download. Should I go with the Alpha firmware or start with the stable? or Beta?
Default 05-23-2020, 12:44 PM
Originally Posted by Jaymorz
Hi Terry,
I'd just load v17 the latest alpha.
With the latest BETA app map switch mode2 can be selected now.
Default 05-24-2020, 05:25 PM
Hey Terry! Hope you're Enjoying your Memorial Day Weekend. Our last exchange you confirmed 5 gallons of E85 and remainder 93 Octane. I mentioned trying Map 5, and said to start at Map 3. I have attached some logs with this E85 mix. Some runs were Map 3 and I believe I did one run in Map 4, and I may have messed one of the four logs up, with cars coming up on me, so try to ignore that one. Could you please let me know how it looks? Want to make sure the car is responding well to this fuel mix. Usually do 100 Octane Unleaded Race Gas, but its insanely expensive. Really appreciate your time and feedback. Thanks Terry!
20200524_1611_runs(1).csv
20200524_1737_runs(3).csv
Default 05-24-2020, 05:59 PM
Already reviewed via email.
Steven TMAN Steven TMAN is offline
Car: Kia Stinger GT
Default 05-27-2020, 09:17 AM
So my Stinger GT is having an issue in Comfort mode. If I gas it to pass someone who doesn't want to be passed (they speed up), I am hitting a wall at 90-ish. The car feels like it's hitting fuel cut. I can turn the knob to Sport mode and it will instantly pull right back into hauling ass to no end.
GT1 RWD with BMS intakes and Densos. I may have to drop back to older firmware but not sure. I try to keep it updated.
I posted a log from when this happened last. Any insight will be greatly appreciated.
Default 05-27-2020, 09:40 AM
What timestamp/run did you experience it? Boost and pedal input all line up here from what I can see.
stock_stinger stock_stinger is offline
Car: 2019 STINGER
Default 05-27-2020, 09:47 AM
Sounds like just suffering comfort throttle response/sensitivity
