(#1126)
Alonso Flores Alonso Flores is offline
Car: 330i series G20
Default 05-22-2020, 11:52 AM
Hi somebody help me about jb4 to n55 series 1, both tach does not match with the odometer numbering, i mean the tach to choice map 2 does not map with 2000 RPM
drwillb drwillb is online now
Car: 2012 n55 135i
Default 05-22-2020, 02:57 PM
Use steering wheel controls. Set it to 5-1 to calibrate for the 135 gauges.
2012 135i Mods: air scoops, CP, BMS filter, PS1, N20 TMAP, ADE FMIC, BMW PE, JB4, BMS BEF, 1M front body, full M3 suspension
Buzz@N55's Avatar
Buzz@N55 Buzz@N55 is offline
Car: BMW 335I 2012 E92 N55
Default 05-23-2020, 10:54 PM
I still need advice on which flash do I use for my car. I have a 09/2012 built 335i e92. Do I use the DME unlock version or the other based on that MHD you no longer need to do a bench flash? Also I have a DCT is there a file for this transmission or does this no apply? Thanks guys
Car: 2012 n55 135i
Default 05-24-2020, 05:28 AM
You want the 9E06 files. Bench unlock is no longer needed. iOS software just came out about a week ago so no Android device needed if you are an iPhone user. You will need the orange MHD WiFi adapter. Terry/BMS sells those.
I have a 6MT so can’t help with DCT other than to tell you that there is software to be uploaded for that.
Should be a very simple search
Buzz@N55's Avatar
Default 05-24-2020, 12:41 PM
I have a 6MT so canít help with DCT other than to tell you that there is software to be uploaded for that.
Maybe Terry know more about which file for DCT cars
Car: 2012 n55 135i
Default 05-25-2020, 07:19 AM
Please search. Knowledge will help you much in the tuning game.
You will need XHP software for the the DCT.
This is from post 1 of this thread:
Use Guide:
To load the flash first set the JB4 to map0 disabling it's CANbus. After loading remove the android device, select mode 4/2 in dash so your JB4 knows you're running a BEF, and then select your normal JB4 map. No other JB4 settings needed. NEVER select 3.5bar TMAP in MHD when flashing even if equipped with a 3.5bar TMAP sensor as the JB4 is already programmed to do that conversion.
PUMP: Suggested for most applications ranging from 91/93 octane up to E85 mixtures of around 40%.
E85: Suggested for E85 mixtures of 40% or more.
E85_PI: Suggested for E85 mixtures of 50% or more with the use of methanol injection or port injection.
E85_PI_ST: Same as above but optimized for larger single turbo use.
THR: Factory throttle mapping, some cars running xHP trans software have reported smoother performance with factory throttle maps.
Choyo_n55 Choyo_n55 is offline
Car: E90 335i n55
Default 05-25-2020, 11:27 AM
I see that in the first post there is new information, "Once installed and the JB4 is set to BEF mode (option 4/2 in dash) the boost targets on each map will change to higher boost absolute maps designed specifically for use with BEF maps. For example map1 goes up to 16psi peak, and map2 goes up to 19si peak. " Wasn't that when we have an n20 tmap sensor?
2011 e90 n55, vrsf down pipe,cp,fmic jb4,AT xhp stage3
emerson15 emerson15 is offline
Car: 135i DCT 11`
Default 05-27-2020, 05:33 PM
I am confused on which backend flash file to use. I have Dual Clutch Transmission 135i with the n55. do I use a file from the newest release on 10/3/19? or from the previous batch of files. I see and special dct file in the newest release but its a pump flash. I am running stage 2 lpfp with a E60 blend of e85 and 91. the car is 2011. Thanks for helping!
