spode spode is offline
Car: 435xi n55 ewg
Default n55 JB4 EWG help - 10-15-2020, 06:35 PM
I recently installed the n55 jb4 EWG harness. Supporting mods are ******* FBO, but with oem FMIC.
No codes thrown from the harness installation, but I ran some logs and am not seeing the expected result. I was under the impression that without the EWG harness, the boost would be limited to about 14-15 psi, and with the harness installed, boost would reach higher.
In my logs, I can see that the boost is not reaching the target boost, and boost does not exceed ~14psi. Ran ~e26 mix to start, until I am more confident things are working properly.
I am fairly new to this, so any help on what I am doing wrong would be greatly appreciated.
https://***********/u/spode/map-5-ew...-6-12-18-19-23
