renaudsk renaudsk is offline
Car: M135i LCI xDrive Full
Default Bleeding Procedure after Intercooler changed - 07-23-2020, 05:02 AM
Hi, I just changed my Intercooler for the BMS Phoenix.
I can't start the bleeding coolant process...
I tried to Start Ignition, push the gas pedal for 15 secondes but nothing is done. I also put the heater hot.
Do you know how to do this ?
And also I would like change my antifreeze coolant engine.
The easiest process is to disconnect an hose from the radiator ?
Thank you
BMW M3 S55 2014
Default 07-23-2020, 11:06 AM
You can close the post, I found answers
thank's
