Tue's Avatar
Tue Tue is offline
Car: M5
Default M5 F10 S63 - 01-15-2020, 12:14 PM
Hi!
I'm new here and don't know much about JB4.
I`ve just bought a M5 with JB4 back end flash including BCM + connection kit and Burger pressure *****.
I have spent a lot of hours looking around in this forum trying to find how the different maps work, but can't find it. Last owner made his own changes and put the car in map6 but dtc flashes up to about 180km/h with winter tires.
My questions is:
1: how does the different map work.
2: do i have an S63 or a S63tu engine(car is stock except from the above).
3: is it only possible to make changes in map6(as i understand map 1-5 is failsafe and i don't use any meth, only regular 98octan.
4: how many hp could i expect aprox.
5: where can i see what firmware i have, and where can i see the latest.
6: my start/stop doesn't work, can i unplug the obd from jb4 and plug in obdlink mx+ and activate it with bimmer code in ignition 2 and then put back the jb4.
I would be happy for answers.
//Tue.
Tue
Tue's Avatar
Tue Tue is offline
Car: M5
Default 01-16-2020, 04:37 AM
anyone???
Tue
Default 01-25-2020, 09:56 PM
What year X5M?
Tue's Avatar
Tue Tue is offline
Car: M5
Default 01-26-2020, 05:19 AM
Hi Terry!
It is a 2012 M5
Tue
Tue's Avatar
Tue Tue is offline
Car: M5
Default 01-26-2020, 09:52 AM
Found some more about the maps, as i understand, i can use map 1, 3 and maybe map 2.
I will try to send in some logs for you, its only about 6-7 degrees celsius here now and I've got winter tires on.
I`m not sure about map 5, it says its a //M-map, but not sure if i can use it?
will also send in a log of map 6, that previous owner made.
Map 7 and 8 are not for me as I'm only using pump gas and no meth?
In my phone it says that my firmware is 7/16//5, but when i look at first page it looks like the last software is V1_2_2 ???
Tue
Tue's Avatar
Tue Tue is offline
Car: M5
Default First logs - 02-03-2020, 08:07 AM
Hi!
I would like someone to look at my first logs.
Don't know if they are good, Have only 6degrees Celsius and winter tires on.
Pump gas 98okt.
I`ve just bought a M5 F10 with JB4 back end flash including BCM + connection kit and Burger pressure line. Installed by owner 2019. All stock except from above.
How many hp could i expect aprox?
My start/stop doesn't work, can i unplug the obd from jb4 and plug in obdlink mx+ and activate it with bimmer code in ignition 2 and then put back the jb4?
Tue
Tue's Avatar
Tue Tue is offline
Car: M5
Default 02-05-2020, 10:53 AM
Btw my settings, do they look okey, Not sure about if the passive delete should be on in the Ethanol setup?
I don't use ethanol only pump gas.
Tue
