Oldude Oldude is offline
Car: 2011 335i
Default JB4 Harness Trade? - 09-07-2019, 02:01 PM
Anyone out there who has made the mistake of ordering the wrong harness and wants to swap shoot me a pm. I bought a type b and need an a.
Default 09-09-2019, 10:08 AM
Did you purchase new?
Car: 2011 335i
Default 09-09-2019, 11:44 AM
No, unfortunately not. I bought it from a guy at work who was selling his car. It was the same year as mine so I assumed it would be the same harness. I’m upgrading to an n20 map anyways so I might as well just change the I take manifold map and swap harness connectors over. Looking at the wiring diagrams it seems pretty straight forward. 1-4, 2,3, 3-2, 4-1. Either that or I find someone to trade harnesses with. I can’t justify buying a new harness while being and electrician myself.
Snafu Snafu is offline
Car: F10 535i
Exclamation Harness - 11-18-2019, 08:10 AM
Gíday
I am very ashamed to admit to making two purchases of JB4 units having only recently acquiring the vehicle.
Firstly I brought one from friend of a friend which had same engine and being a F body.Upon attempting to install the unit I soon discovered my complete ignorance to the situation as the JB4 is for a EWG.In summery both the board and harness are incompatible with my model.
The next course of action I undertook without rest was to actually make known to myself what exactly my specifications in every detail as not to make such foolish mistakes.
Of coarse now Iím ready to purchase another JB4 however this time I know what I need.My car is as follows a 2010 535i F10 N55 8AT RWD RHD with 66 000 km
showing on odometer and is completely stock.Another friend of a friend with what I thought the same car had a JB4 for sale so yep I brought it.
Wow JB4 unit compatible no so with harness wrong connection type.
Question
Do the harnesses differ other than clip type
Question
Is wiring same
Request
If there is any wiring diagrams available for this I would very much
appreciate it
I can upload photos if required
In my defence everything here is upside down in Australia
Regards Snafu
Default 11-18-2019, 09:33 AM
You'd need a TypeA harness for your car, sort of rare in the F chassis PWG format. Best off selling that system and buying a new one for your specific application IMHO.
Car: F10 535i
Default 11-18-2019, 10:47 AM
G’day Terry
Is their a drawing please
Car: F10 535i
Default 11-18-2019, 10:51 AM
Not spending 350 US nearly double in AU dollars at the moment for a couple of wires
Default 11-18-2019, 11:08 AM
There is not a wiring diagram sorry. At a minimum you'd need 2x male and 2x female typeA connectors to replace your typeB connectors. Problem is you won't be able to purchase those connectors anywhere.
Car: F10 535i
Default 11-18-2019, 08:08 PM
Thank you
Well connectors fit on in reverse just don’t clip on
I should be able to simply reverse wiring on two of them the other two fit as they should
To your knowledge would this work
Thank you for your time I really appreciate it
Car: 2011 335i
Default 11-18-2019, 08:54 PM
I’m not entirely sure about your first question but I can’t tell you that I went to a junk yard and found the connectors I needed for both map sensors and simply reversed the order they went in. Instead of 1-2-3-4 like you currently have place them 4-3-2-1 in the new connector. To do this you simply put the clip side of both connectors facing upward and one for one the wires. It’s really simple to do. There are two clip on the side of the connectors that release a door, once that is up you can see a metal retaining tab on each pin. Press in down with a jewelers and then pull the wire Bentley our of the connector. Open the door on the new connector and press’s in place, close the door after the four wires are installed. Easy least. Hope this helps.
Car: F10 535i
Default Light at the end of the tunnel - 11-18-2019, 09:01 PM
Thank you
I have done exactly that itís what I thought I probably would be a simple reversal
Iíll connect it up and post my results
Thank you for your help i should be right now and appreciate your pm as a solution also
Regards Snafu
Phat135's Avatar
Phat135 Phat135 is offline
Car: 2012 135i
Default 05-06-2020, 05:00 AM
I have a type a and am In need of a type b. Anyone interested?
tikalize tikalize is offline
Car: e90
Default 10-11-2020, 03:50 PM
Hello, do you still have the A harness? I have a B harness i would like to swap.
Car: e90
Default 10-12-2020, 04:46 PM
Thanks i converted it myself. Sorry to wakeup a old thread.
