blackdm's Avatar
blackdm blackdm is offline
Car: F82 M4
Default Seeks tuner solutions for JB4 and BM3 to work together - 08-21-2019, 09:42 PM
I am looking for a Tuner to help me adjust my JB4. Now I am using Bm3 flansh and want to use JB4 for date log. Now it looks normal together with map0, but the afr data of map4 and map6 will reach 10.x-11.x. Hope the friend who has ability can help me, have reward。
17 F82 M4 dct/ BM3 Custom flash/ BMS JB4 ISO /200 mesh exhaust Top section / BP Racing Metal Chargepipes and J-Pipe / CSF ColdFront / NGK Racing 0.2 / BMS Methanol injection / 763M / Cup2 /Phoenix Racing Intercooler/ EVENTURI INTAKE
Default 08-22-2019, 11:03 AM
Post a log so we can take a look! What fuel are you using?
blackdm's Avatar
Car: F82 M4
Default 08-23-2019, 08:05 AM
After the methanol injection is started, the 4-block air-fuel ratio will be too concentrated. Gear 3 starts with turbine pressure zigzags. No methanol injection, everything is fine but the ignition is low.
blackdm's Avatar
Car: F82 M4
Default 08-23-2019, 01:58 PM
hey.bro.please see my log
Default 08-25-2019, 07:45 PM
The issue is fuel trims falling too far negative while on WMI?
The issue is they are already low without WMI. I think the fuel scalar in your flash needs to be reduced. The JB4 is already set to openloop=0 meaning it is having no influence on fuel trims.
blackdm's Avatar
Car: F82 M4
Default 08-25-2019, 09:32 PM
thanks,I will contact BM3 flash to modify this problem. Is progressive injection only available under map8?
Default 09-12-2019, 11:27 AM
You can set to to flow on all maps by setting meth trigger = 1, but only map8 has the fully progressive safety.
