Default 02-06-2019, 01:35 PM
Found a bug in the firmware causing a false alarm IAT/boost sensor fault. Will add new firmware to the first post shortly that corrects it for anyone getting it.
Default 02-23-2019, 03:00 PM
JB4_ALFA_2:
1) Enabled CANbus engine allow the JB4 to now access the full suite of engine data including engine speed, ignition advance, air/fuel ratio, fuel trims, throttle & pedal position, engine temperatures, fuel pressure, and more. Requires OBDII cable to be attached to JB4. See install video below.
Default 02-23-2019, 11:06 PM
Awesome work Terry!!
Default 02-24-2019, 10:20 AM
A couple Alfa logs stock and JB4 map2.
Andy1gg Andy1gg is offline
Car: Alfa Romeo Guilia
Default 03-07-2019, 01:38 PM
Any Dyno numbers yet?
Default 03-07-2019, 04:26 PM
No dyno numbers yet.
Handsome_Rob Handsome_Rob is offline
Car: 535
Default Giulia 2.0 - 03-13-2019, 01:58 PM
Attached some logs from last night.
Default 03-13-2019, 06:14 PM
Thanks! Keep those logs rolling. Specially from different climates and fuels.
Car: 535
Default 03-14-2019, 06:59 AM
You got it! That was on standard, 'Bama 93 pump gas. RTR!
Car: 535
Default 03-17-2019, 10:14 AM
Air temp, 58f. Half tank of 93... Best 0-60 was a 4.8. I was traction limited on most of these logs when either getting to the top of first, or shifting to second. Also had slip issues in first when the boost really came on... for science...
Default 03-17-2019, 11:08 AM
Set 1st gear to 3psi to reduce boost down low by 3psi and see if that helps the launch!
Car: 535
Default 03-17-2019, 05:05 PM
Ok. Let me do some research on that one...
Jakobbermudez Jakobbermudez is offline
Car: Alfa Romeo Giulia
Default 03-17-2019, 05:42 PM
1st photo is from a dead stop and second is from a 30 roll
Macrox18 Macrox18 is offline
Default Jb4 Giulia - 03-18-2019, 07:34 AM
Hi Iím wanting to get the JB4 for my car and I was wondering if the software is finilized or are you still beta testing it. Also is the only parameter being affected by the jb4 the boost pressure? How about fuel and timing? If I remove it will the dealer see any trace when I take it in for service since it connects to the obd2
Default 03-18-2019, 09:12 AM
Boost, timing, and fueling are manipulated, and you can confirm everything is healthy by running your own data logs.
The hardware itself is finalized but we will be doing regular software updates to add more power and features as continued development dictates.
Car: 535
Default 03-18-2019, 01:52 PM
40-90...
Default 03-18-2019, 02:00 PM
Ok sounds good, did you run any dyno pulls yet to see the difference in hp and trq. And how about when I bring the car in for service?
Alpha Alpha is offline
Car: Alfa Romeo Giulia 2.0 Q4
Default 03-18-2019, 03:26 PM
I've been inspired to try a 0-60 run in my Q4 on Map 2.... I did cheat a bit because it's cold out
4.625 sec according to the app
Car: 535
Default 03-18-2019, 03:31 PM
Nice job, man! Traction has its benefits...
Default 03-18-2019, 03:59 PM
Coming from RWD manual transmission cars - that run felt like cheating
Car: 535
Default 03-18-2019, 04:33 PM
Nah... You're just evolving...
Default 03-18-2019, 07:09 PM
Looks good to me!
termOTB termOTB is offline
Car: 2018 Alfa Romeo Giulia Ti Sport
Default 03-20-2019, 08:55 PM
Hey just finished installing my jb4 a couple hours ago. I was kinda upset at first because i thought i ordered the wireless mobile kit but instead just the basic wire but itís all good now, just ordered the mobile kit and the ride just in map 1 is a lot of fun. One issue (or maybe good thing) i ran into and the main purpose of this post is that upon first start up i got a light telling me that start stop is unavailable and it has not gone away since. Any idea what might be causing this? I personally never use this function anyway but the light on the dash is a bit annoying. Thanks!
Car: 535
Default 03-21-2019, 01:45 PM
What firmware do you have?
Default 03-21-2019, 05:40 PM
Got any logs so we can take a look at firmware or anything unusual?
