(#276)
JB4U's Avatar
JB4U JB4U is offline
Car: 15' 320i ZSP
Default 05-29-2020, 07:29 AM
Why won't you get the Bluetooth (JB Connect) kit?
Its great and very easy to install/connect.
The 'cold' air intakes will not reduce your IAT, probably the opposite.
I use the SprintFilter drop in. BMC, AFE and KN also make one.
Default 05-29-2020, 09:07 AM
Originally Posted by G&G Classics
Another Map 2 log from tonight. Pulled hard all the way through.
Then on the way back (after hard driving ie HEAT) the problem came back. Wasn't able to log...
Maybe need a new cold-air intake filter kit? Any drop-in upgrades for stock airbox?
Anyone know how to get the JB4 iPhone app to work with OTG to lightning cable? Been logging with my Surface Pro kind of a pain...
Interesting so must be heat related on yours.. On the OTG should work, you can contact JB4 mobile for support on that if needed!
G&G Classics G&G Classics is offline
Car: '19 Alfa Giulia Sport RWD
Default 05-29-2020, 09:39 AM
Miami is brutal during the summers... intercooler upgrade I guess is my only real solution.
Default 05-29-2020, 09:41 AM
I will look into those drop-in upgrades... Thank you.
I don't want to have to take apart my JB4 again and f***something up
JB4U's Avatar
Car: 15' 320i ZSP
Default 05-29-2020, 02:44 PM
Its an easy 10 min job, can be done without disconnecting.
I'm In Aventura so same heat, no issues with multiple consecutive 0-100 mph runs. Obviously it feels better when the ambient temp is cooler.
Default 05-29-2020, 03:17 PM
@terry@BMS uploaded the link for me to download the new firmware. Just updated my JB4 and so far all is good
I'll try to get another log in tonight...
ManuPR42 ManuPR42 is offline
Car: Alfa Romeo Giulia
Default Hello! - 06-10-2020, 04:59 PM
Hello people! Here is the latest log I have from running the V5 and the JB4app Beta..... I'm running on Map 1 testing it and then Map 2, I talked to Terry about some rattling noise my car makes on Map 1 & 2 and I think it's from the waste-gate actuator, and it only happens as I can recall when the day is HOT... The rattles begins around 2k rpm and goes until WOT, when the day is HOT...
This log was about 1 hour ago and it's not that hot here. Do you have any idea if what I can hear is the waste gate actuator or have any idea what it could be? I don't have an audio for that, but happens when running MAP 1 & 2, when running Map 0 it doesn't present the condition.
bhvrdr bhvrdr is offline
Default 06-18-2020, 04:17 AM
Terry can we get the gauge for post intercooler air temps instead of pre intercooler? According to this post it appears to be pid 77, 0
Add Virtual Gauges | Alfa Romeo Giulia Forum
Mike
Default 06-18-2020, 09:10 AM
Mike
Sure but I don't have a car handy right now so will be difficult to test. Drop me an email and I can add it to firmware and you can see if it works!
Note according to the notes I think that is intercooler water temp, not charge air temp. But we can still try it.
JustinTiSportCarbon JustinTiSportCarbon is offline
Car: 2019 Alfa Romeo Giulia Ti Sport Carbon
Default RDNA/E85 Questions - 06-23-2020, 09:13 AM
Hey guys, new to the forumn here but have been reading for some time. Have a few questions regarding JB4 tuning. I currently have the RDNA Type 3 conversion, and I was wondering if the JB4 tuning will play well with this as far as still providing the benefits of the maps in race mode? I know the general consensus is that the ECU is in "N" mode on the Giulia 2.0 when in "R" and wanted to know if this meant I would be reverted back to stock tune when switching into race on my car. Also, when running Map 2 on the JB4 is anything between 93 pump and an E30 blend acceptable? Has anyone ran pump E85?
2019 Giulia Ti Sport Carbon
-Cone filter and shield
-Custom quad tip straightpipe muffler/resonator delete
-RDNA Type 3 Conversion
2019 Giulia Nero Edizione
-Stock for now
Default 06-23-2020, 09:16 AM
The JB4 reads it's gear/speed data from the ECU so whatever changes you made won't affect the JB4 tuning.
You can't run more than 30% E85 currently, but yes 93-E30 can be used on map1 or map2.
Default 06-23-2020, 09:39 AM
Awesome, that will be perfect then. Is there any benefit proven from E30 over straight 93? Have people seen or quantified gains or is it more of a timing safeguard at the increased boost levels?
-Stock for now
Default 06-24-2020, 04:30 AM
I don't see any timing retard at all on 93 octane on this car so saw no benefit from e30. If you have good quality 93 youre probably great. If California 91 octane you may want to log to see if it will help. Jb4 logging is awesome for that
Default 06-24-2020, 07:12 AM
Awesome, we definitely have good 93 here in TX in my experience.
-Stock for now
Default 06-24-2020, 09:12 AM
Perfect. Dont forget to get a dragy and get some before and after acceleration runs. Its fun seeing the improvement
Mike
m4rkus34 m4rkus34 is offline
Car: Giulia Ti
Default 07-12-2020, 12:48 PM
Photo of JB4 box placed on driver side. Fits nicely here.
Hi Terry I just bought the unit for my TI and had a couple questions and will post runs later.
I have my positioned similar to yours here and have it zip tied to the metal line to the left of the coolant tank but also resting on the frame below. What do you have yours zipped to in the picture?
The unit seems to get quite hot pretty quick but I'm not sure whether it's picking up heatsoak from that line or if it's just ambient engine air heating up the metal case. Is it somewhat heat resistant so the board will not get damaged? I was thinking of repositioning next to the airbox like in the install guide but didn't know if it was necessary.
Do I need to shut off the engine or be at idle to switch maps?
Thanks for the help
Breakthecycle2 Breakthecycle2 is offline
Car: Alfa Romeo Guilia
Default 07-12-2020, 05:08 PM
Terry, Im continuing to have issues here. Im on the previous version of Beta 5 ( I forget the name) . Map 2 and a custom map 6 someone posted earlier. Im getting 0299 errors all day. I have posted screenshots and theres no less than 20 errors within a 45 minute drive and one other one you can see. Logs are also attached. Id like to get to the bottom of this because this is unusable as is for me.
Edit: The logs seem to be large to post here.
Default 07-12-2020, 08:45 PM
P0299 is an under boost fault, it means your boost is too low. Assuming there are no obvious hardware issues like a boost leak or loose wastegate, lower the JB4 target as needed via map6 until you are not throwing the fault.
Default 07-13-2020, 07:18 AM
Happens on Map 2 as well though.
Giulia101 Giulia101 is offline
Car: 2018 giulia Ti Sport
Default 07-13-2020, 04:53 PM
Might sound like a stupid question...
I have a 2018 giulia with a recently installed JB4. From what I understand, I should be using Map 3 on Beta Version 5 for “best” results?
Default 07-13-2020, 04:59 PM
Map2 is more aggressive than map1... What happens on map1?
Default 07-13-2020, 05:00 PM
Start with map1 and if it's running well then give map2 a whirl!
Default 07-13-2020, 05:26 PM
Will do, thanks.
Car: Giulia Ti
Default 07-13-2020, 07:02 PM
Thanks for the help
Terry, I think the box was just super hot after installing it during afternoon sun. I went for a few runs and it was not as hot. Still would like to know if you can switch maps while parked/idle. Also, same question as above, I want to be using map2 in beta v5 and not map3 correct? I thought you revised it or something because of the errors but maybe that was corrected with beta v5. Here are my files, 93oct, 83degF, map 0 & 2 (no errors so far):
Default 07-14-2020, 05:43 PM
Im still getting the 0299 error.
