kevlarblue kevlarblue is offline
Default Running Rough at Startup - 09-24-2018, 02:48 PM
Hi, I'm new. I have a 2009 335i, 70K miles and I just installed a jb4 on Saturday. Yes, I did replace my plugs and coils at the same time. My test drive on Saturday went great and I was very happy with the results.
Until Sunday morning when I started the car after sitting overnight; the SES light came on and the engine was running extremely rough, almost unbearable. I read the codes through the jb4 mobile app and got:
2E18 Ignition, Normal 2STEP/NLS code
29CD Misfirings, cylinder 1
I looked at both codes in the fault code manual and they are associated with cylinder 1. Again, I did replace the plugs and coils when I installed the jb4.
After about 15 minutes of driving the engine started running normally, the codes cleared after I deleted them and the rest of the day was uneventful. Until today when I started it from cold and got the same rough engine operation and codes.
Do I have a bad coil? Or am I looking at something more serious?
I attached 2 logs that were captured during the rough operations. The first at idle speed, the second one during a slow acceleration. Any help or advice for a newbie is appreciated. Thank you.
Haynpunch's Avatar
Car: 07 E90 335i
Default 09-24-2018, 03:21 PM
Try swapping the misfiring coil/plugs to another cylinder clear codes see if misfire moves to that cylinder
What brand plugs are you running? Gapped properly?
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Default 09-24-2018, 03:32 PM
I bought the OEM Bosch plugs and coils, the gap was set when they came, I didn't change that.
I'll try the swap to cylinder 2 later in the week and see what that does.
Dave @ BMS/Fuel-It! Dave @ BMS/Fuel-It! is online now
Default 09-24-2018, 10:50 PM
Easiest would be to swap that cyl 1 coil- see if it follows.
Pull the plug to after the car sits overnight, see if itís wet with gas- if yes you probably have a leaking fuel injector on at least cyl1
Haynpunch's Avatar
Car: 07 E90 335i
Default 09-24-2018, 11:43 PM
OEM Bosch are hit or miss, most go with NGK 95770 gapped to .022 but to each their own
http://www.burgertuning.com/N54_BMW_...t_adapter.html
07 E90 AT - xHP
FBO
Hybrids
Default 09-25-2018, 02:53 PM
I ran oem plugs on my prior xi @ 600 awhp for months.
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 09-26-2018, 08:57 AM
Prepare for new injectors
09 335 - 6266
07 335i - 6870, E85 - SOLD
Default 09-29-2018, 11:21 AM
Donít scare him LOL
But yeah, I suspect wet plugs
sdbradley510 sdbradley510 is offline
Car: 08 BMW 335I Convertible
Default 10-17-2020, 06:06 PM
I have an 08 335I with 151K miles. I'm getting a 2E1B and a 29D0 cylinder 4 misfire code.
I was having a misfire on 6 but only after hitting 6500 rpms in 4th gear, so I replaced the coil because I just recently replaced the coils with some cheap ones from Amazon (Bosch but I think they're knock offs l... lesson learned there). After replacing the ignition coil on 6, I went ahead and installed a MHD backend flash to go with my JB4. After the flash, I started getting the codes. Is it possible that I did something with the flash.
A little more background:
I recently replaced fuel injectors in 4, 5, and 6 because the mosfets blew and took out the injectors. While I was at it, I replaced all the coils with new ones. I know they're cheap because I already had to replace cylinder 3's coil back with the old one because I was getting misfires with that cylinder.
My question is, should I flash back to stock first or replace the coil in cylinder 4 first. Do you think a setting in flash could've caused this? Or is it more likely that another POS coil needs to be replaced.
Thanks for the help...
