(#51)
Default 09-18-2018, 08:01 PM
It's bit5, default is off.
TideMD's Avatar
TideMD TideMD is offline
Car: 2016 M4
Default 09-18-2018, 08:40 PM
One thing that came to mind - are the default settings shown in the 2nd post of the S55 thread still valid, considering changes with the firmware since that post and the recent BEF implementation?
2016 F82 M4 / Sakhir Orange / Black extended leather / Opti-Coat Pro
NGK 1-step colder, 0.020" / BMC drop-in, carbon delete / Injen intake & CPs / AR Design catt'd down / AA mid
LCI rear light retrofit / AutoTecknic front splitters / Mode Carbon High Kick rear spoiler / 3D Design rear diffuser
Michelin Pilot Sport 4S 265/285 35-19 / BMS ceramic black exhaust tips / Macht Schnell spacers - 15mm(f), 12mm(r)
Soobieajax325 Soobieajax325 is offline
Car: M3
Default 09-19-2018, 03:01 AM
After i set FutureUseD #6 on; am i able to download the maps using the bluetooth kit?
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default 09-19-2018, 06:55 AM
Oic ok. So where it says enable logging of lfp trims2 and Afr2?
I produced this log after I set DB values to 50 but didn’t know how to lock the DB yet 😅
2009 N54 335i coupe, 6AT PD trans, Stage 3 XHP, Built Motor, 9.6:1 Comp Ratio, Ported Head, Trebilia Custom Flash, JB4, Mhd flasher, Ngk 97506 0.018” gapped, PI Kit 100% E85, Jb4 PI integration, Stage 2 Pure Turbos 25.6psi, 17.2 deg timing, TFT inlets, Stage 3 Fuel-it Fpr, FBO, 431rwkw Mainline Dyno Aus
2016 M4 Competition Pack, 7-sp DCT, Jb4 Map 6
25.0 psi, s55 ign e85 Bef, E70, M4 plugs gapped 0.020”, stock everything else, 374.9 rwkw Mainline Dyno Aus
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-19-2018, 07:18 AM
Did a longer log with DB locked. FF is rising to 66 now. Just right at the end, I not sure what I felt it was almost like a slight loss of traction or something and the log shows my rpm actually dropped to 6363rpm before it went bk up. Maybe it recovered the traction but I backed off just in case. Timing is right up there now though.
Default 09-19-2018, 08:16 AM
Looks normal to me.
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-19-2018, 08:42 AM
Tx Terry��
TideMD's Avatar
Car: 2016 M4
Default 09-19-2018, 11:36 AM
I updated the MHD app after their public release yesterday. Reflashed S55 RACE v13 and logged a pull to make sure everything was still looking good. Was running E40 mix of 93 octane and E85.
Only thing I noticed was a split second of power drop off in the mid to high RPM range.
File Type: csv 2018-09-19 - Map 5, E40 (JB4stg3, S55 RACEv13).csv (17.0 KB, 125 views)
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-19-2018, 12:50 PM
Looks normal to me.
Hi Terry, do u think looking at my logs with the current set up there is ample room to increase the boost to say 26psi or 27psi without changing anything else?
Car: M3
Default 09-19-2018, 11:06 PM
Anyone...??
Babyjoe1973 Babyjoe1973 is offline
Car: 135i and M3 E30 Evo III
Send a message via Skype™ to Babyjoe1973
Default 09-20-2018, 12:40 AM
did a log today! Lastest BEF and lastest Firmware. Car completly stock!
Please check!
Regards
Torben
BMW M3 F80 ZCP
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-20-2018, 06:34 AM
I did a log to see if it can handle 26.5psi 😀
Kingofqueenz788 Kingofqueenz788 is offline
Car: F80
Default 09-23-2018, 04:59 PM
How does the burble option work and this tune in general ? I am debating on either changing software or doing the mhd bef to my jb4
Default 09-23-2018, 06:03 PM
When loading the BEF you click off on the options to enable it, and your car makes odd exploding noises during deceleration.
Default 09-23-2018, 06:04 PM
So far seems good, I see IAT is colder too.
Car: F80
Default 09-23-2018, 07:31 PM
So after I load the s55 race bef what map is my jb4 supposed to be set at ? Also before I start to log can I just drive like I normally do on this race bef or do I need to tweek it ASAP is it going to be safe to go all out ?
Car: F80
Default 09-23-2018, 07:33 PM
I have my ** installed with my chargepipes and cold side pipe. No intakes yet or exhaust I still use the race bef rite
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-23-2018, 09:01 PM
Tx Terry. Yes it feels very very good. Really need slicks or nittos 😂
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-24-2018, 06:58 AM
Terry the burble options in mhd is separate from your jb4 toggle settings for exhaust flap fully open at all times etc, I presume?
And burble options are not detrimental to motor?
TideMD's Avatar
Car: 2016 M4
Default 09-24-2018, 10:34 PM
The burble settings are separate from the JB4 controls. The latest MHD release is nice in that you can set exhaust flaps closed in comfort/efficiency mode and always open in sport/sport+. Then, set the JB4 to allow OEM flap functionality and you can toggle from quiet driving when rolling by the neighbors' houses in the middle of the night, to instantly crazy loud with the press of a button.
That feature finally being release kept me from switching to a different flashing platform.
Also, the burbles are a little much for my taste on anything other than OEM setting. The OEM setting sounds sweet when set to 0.8-1.3 seconds or so duration.
Even the soft setting (one bump up from OEM) is pretty insane on my car as a daily driver. I tried medium once and had to pull over and re-flash because it was just too much for routine driving.
Default 09-25-2018, 04:42 PM
Anyone running straight E85 having issues with rough cold idle and/or stalling? I cranked up the fuel scalar up a bit for a customer and it seemed to improve his cold performance. Email me if you'd like to test the change.
TideMD's Avatar
Car: 2016 M4
Default 09-26-2018, 12:25 AM
Hey Terry,
I experienced this recently running E40 mix with the RACE v13 BEF - every cold start up was pretty bad. Unfortunately, had to refuel before I thought to log a cold start. The car idled super rough for the first 10-20 sec and trying to drive off without letting things smooth out made it bog down pretty hard, to the point of looking a little ridiculous pulling out of a parking garage.
It wasn’t an issue with E20 - E35 blends. Also haven’t noticed a problem with straight 93 fuel.
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-26-2018, 05:29 AM
Hi Terry, I’ve enabled the cold e85 start up bit when I first flashed the first e85 bef and it definitely improved my cold start and stop/start function. With this off it just stalls on the auto stop/start if enabled 😂
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-26-2018, 06:44 AM
Oh wow! I’ll take a look at my settings. Because my car is totally stock in exhaust it could prolly do with more burble in Sports mode ��
Should I be selecting the option Oem/Catted *** too?
Default 09-26-2018, 08:26 AM
The new flash change builds on that with a high fuel scalar in the cranking and idle areas. Let me know if it further helps!
