(#726)
Default 06-25-2020, 07:42 PM
Both logs look like v5 firmware?
YanoNardoM5 YanoNardoM5 is offline
Car: 2018 BMW M5 Individual Nardo Grey
Default 06-26-2020, 07:54 AM
I uploaded the file correctly last night. I must if thought it wrote it. Where do I go to set these settings: duty bias to 50, pid gain to 20, FF to 50?
Default 06-26-2020, 08:39 AM
On the user adjustment page!
Default 06-26-2020, 05:24 PM
Does the duty bias need to be 50 for all the rpm range? I notice on the lower rpm it ranges from 10-40 from 1500-4000
Default 06-28-2020, 09:21 PM
Hi Terry,
Updated firm ware. This log is stage 2 w/ewg plugged in and 92 octane w/6oz of Bootsane.
On my first run, I may have hit rev limiter as I forgot to shift. How’s it looking? I’m still getting used to shift points. TIA
It definitely got faster too. Here is my dragy run:
dragy by Justin J, on Flickr
Default 07-01-2020, 08:30 AM
For those who have been getting a false alarm 120719 fault on v7 BETA firmware, I posted an update V8_TEST2 that may have a fix. Let me know!
Default 07-01-2020, 08:32 AM
Originally Posted by YanoNardoM5
Hi Terry,
The data side looks OK, but I think more octane would help. I'd lower FF to 45 to smooth out throttle a bit and double up on the boostane.
adolzero adolzero is offline
Car: m5
Default 07-09-2020, 09:40 AM
newbie here to ask 2 question and hope to get quick answer; 1)when use jb4 app to swtich from different map,can it be done when car is moving?or need to be on idle or switch to diagnosis mode? 2) if i dont connect ewg connector,how shall i seal them in the engine bay?can i simple connect the female port to male pin connector?will it cause shortcut to jb4?just want to make sure i dont do stupid things and sorry for these silly questions:)
Default 07-09-2020, 09:52 AM
Map changes can be made on the fly while driving or even while racing. On EWG just plug in to each other to keep dust out.
Default 07-10-2020, 08:51 PM
Originally Posted by WakeOfDeath
Crazy slower than my friend's X4M lol he's doing 7.64
does he have jb4 too?
Yeah it was driver error too and adaption. I got it down to 7.44 and my best run was 7.09. It’s definitely getting faster the longer and more comfortable I feel behind the wheel.
I just need more open Mexico roads lol
Car: m5
Default 07-11-2020, 01:18 AM
@terry,i am running map1 with akrapovic exhaust and gruppem intake,just help me to check if things are ok(not sure if boost can reach 25psi as showed on map1) dont want to overrun on the motor before i know it better
Default 07-13-2020, 10:00 AM
Would need CSV on that front!
Default 07-13-2020, 10:01 AM
But our other friend has tons of bugs/issues with his JB4 in his M8 Comp with Full ********* and Intakes and can't get anywhere below stock times.
Not aware of any unresolved problems out there, what's his name or email?
Car: m5
Default 07-13-2020, 10:19 AM
sir,file attached
Default 07-13-2020, 11:30 AM
sir,file attached
Update to v8 firmware, duty bias to 50 across the board, and grab another log!
Car: m5
Default 07-13-2020, 08:22 PM
here it is, sir. V8test2 file downloaded, update and change user adjustment settings duty bias all to 50, use Map1. car runs good and seems the log captured 0-60, 2.8x not bad at all.
i am running akrapovic evo, gm intake and all else are stock. fuel quality here is not ideal but ok (definate not better than 93) i quickly go through the csv and this time boost at around 21 max?
i just want to have map1 to be default for daily drive so a rather conservative /normal tune is ok.. really want to focus longevity...
so do you think i shall use v8test map1 (with duty bias 50) on going or you have different inputs?
many thx Terry
Default 07-13-2020, 08:30 PM
Are EWG connectors installed on the car?
Car: m5
Default 07-13-2020, 08:45 PM
no, i didnt since manul intro mentioned they might throw codes. i only connect twap...kindly suggest..thx;i attached another log which is a bit long recording,hope to have your view
Default 07-14-2020, 09:58 AM
OK without those we're going to be more limited on the tuning. If you're happy with how it's running then keep on trucking. If you want more performance attach them and log map1.
Car: m5
Default 07-14-2020, 10:29 AM
thx,in my case do you suggest to go back to v5 or v8 test duty bias 50? what does duty bias work on in different rpm?
Default 07-14-2020, 11:16 AM
The duty bias settings only have an effect if EWG connectors are installed. I'd leave it on v8.
Car: m5
Default 07-14-2020, 11:28 AM
thx i will put my car on v8 then,tmap only is good and shall i say max boost 25psi when i do launch control and it shall be no problem for a daily drive on map1?
Default 07-14-2020, 01:08 PM
Boost safety I'd set to 26 or 28psi to keep it out of the way, it's a safety system, not your boost target.
Map1 with or without EWG is suitable for all conditions and fuels generally.
Down4it's Avatar
Down4it Down4it is offline
Default 07-14-2020, 05:31 PM
Hey Terry, I'm on V5 firmware, updating to latest V8 firmware do i need to adjust anything to run maps 1 or 2?
MDM MDM is offline
Car: M5
Default 07-15-2020, 09:07 PM
What does the FF stand for in FF/Wastegate Adaptation under user settings?
