Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 09-26-2016, 01:53 PM
You're right. The M235 has a secondary Oil heat exchanger with coolant flowing through it. The 3 series doesn't have that, its purely air to oil.
Mike Levy
2021 Tanzanite Blue II M550i - Due at dealer 10/9
2018 Silver Equinox LT 2.0T
Peter @ Pure's Avatar
Car: F20 M135i
Default 09-26-2016, 02:00 PM
Originally Posted by rwalker
It's not doable from the top on an M235i because of this:
http://www.realoem.com/bmw/enUS/show...diagId=17_0907
The M135i looks like this:
http://www.realoem.com/bmw/enUS/show...diagId=17_0654
There's an extra oil-water heat exchanger (number 26 in first pic) that blocks access to the inlet, so you can only see the retaining nut from below. This is the same bugger that makes installation of the EWG wires a bloody knuckles affair.
The 335iGT looks like it has the same setup as the M135i...
Ah indeed. Didnt know about that difference. Tnx for explaining.
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Mike_L's Avatar
Anti-Social
Default 09-30-2016, 10:07 AM
Originally Posted by darkiedm4
I installed the inlet pipe from top of engine. This is doable on X-Drive too.
I see the bolt that holds the pipe, but theres a hose and sensor going to it also that isn't shown in the ETK. Looks to go to the top of the motor someplace?
Mike Levy
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 09-30-2016, 10:55 AM
Any reason the E-series N55 gets a full replacement inlet pipe, but the F-series is the cut and join type?
2016 F22 M240i | 8ZF
crobond crobond is offline
Car: M235i
Default Logs with inlet - 09-30-2016, 09:14 PM
I have install the inlet now on a stock n55 EWG turbo. I have here two logs. The first at 23.01 is with stock inlet and the second 5.40 is with pure inlet. For me looks same, but the car feels better when i accelerate.
keyap keyap is offline
Car: N55 135i
Default 10-01-2016, 02:23 AM
Possibly because the E's OEM pipe is quite restrictive for most of it's length. Only seen photos of the F but it looks like the restriction is at the end only.
[B]
Weehe Weehe is offline
Default 10-01-2016, 06:05 AM
We really need MAF delete option for E series so we can just slap a cone on the Pure inlet. Can't get better than that.
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 10-01-2016, 09:23 AM
Or at least route it with better piping.
2011 E92 335i Auto Sold
12.0 @ 125MPH JB4
Car: N55 135i
Default 10-01-2016, 11:12 AM
I think that if you request a new board chip from Terry / Steve (the one needed for the BMS PI controllers) and load the latest FW you'll find it's MAF delete
[B]
Default 10-01-2016, 11:20 AM
Yeah, I know they did it to Anytymes car. Just haven't released anything on it.
Newguy123's Avatar
Car: 12' 135i
Default 10-01-2016, 11:25 AM
would be pretty audible IMO too
18 Glacier white RS3
#PURETURBOS
#FUELIT
katsooba's Avatar
katsooba katsooba is offline
Car: 135i N55 DCT
Default 10-01-2016, 11:49 AM
would we need to buy a new jb4 for a MAF delete?
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" DP / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
Car: N55 135i
Default 10-01-2016, 01:17 PM
My understanding is it's a straight swop of 1 chip. I've got probably one of the first N55 boards from 2011 and, from what I understand, I could just swop a chip - no need for a new board.
Not sure of cost etc though
I think all new boards come with the new chip - if you have a look at the N55 install guide on the BMS site it now has a big red cross on the MAF page
[B]
Mike_L's Avatar
Anti-Social
Default 10-01-2016, 03:30 PM
Easy install? I'm deciding if I want to just throw it on or if I want to hold it until I upgrade the turbo (probably to a Stage 1, because a Stage 2 in NYC traffic is a waste).
Mike Levy
Car: M235i
Default 10-01-2016, 03:50 PM
Better wait and istall it with the turbo is mich easyer
Car: 2011 e92 335i
Default 10-01-2016, 04:58 PM
If you were to throw a filter right on the inlet would this need to be blocked off? I don't even know what it is.
12.0 @ 125MPH JB4
F30_SixSpeed F30_SixSpeed is offline
Car: 335i M Sport
Default 10-01-2016, 08:57 PM
Has anyone tested these on a FBO STOCK turbo? wondering if similar power gains are possible on the smaller stock turbo.
335i M Sport 6MT || PS2 Turbo, FBO, TTFS XDI-35 HPFP, BM3, KW, MP BBK, 550i clutch, OEM+
Car: 2011 e92 335i
Default 10-01-2016, 09:04 PM
Read the first page
12.0 @ 125MPH JB4
katsooba's Avatar
Car: 135i N55 DCT
Default 10-01-2016, 09:54 PM
Ths install guide is for the jb4 stage1 for thd n55
It doesnt say unplug the maf, it just says leave the maf as-is, meaning the dme still uses it
KevinC39 KevinC39 is offline
Car: 335i 6MT RWD
Default 10-01-2016, 10:34 PM
Looks like you're circling the hose for the pcv?
Car: N55 135i
Default 10-02-2016, 03:00 AM
Good point - wonder what the new top mount guys are doing? I'd assumed from a few comments I'd seen that they were MAF'less
[B]
Default 10-02-2016, 06:26 AM
Once we can go MAFless I plan to make a fitting for the pvc heater connection that can be welded on an aluminum tube. So would need a slight extension off the pure inlet with an aluminum tube, then the filter would be after that. N54 guys have had luck fitting the 335d air scoop which goes to the left side, directing air to the new filter location. But I think it only fits 335, not 135.
Element's Avatar
Car: BMW 135i N54
Default 10-02-2016, 11:57 PM
I get that, but the cutting and joining aspect is a bit inelegant.
Personally I'd far rather have a complete replacement part over hacking up and clamping OEM plastic parts to alu piping. I suspect the way in which they are joined also sacrifices a small degree of flow smoothness as well.
Mike_L's Avatar
Anti-Social
Default 10-03-2016, 12:02 AM
A complete pipe can't flex. Unlike the E series, the F intake is mounted to the car (the Es is mounted to the top of the motor). When the engine moves under load, there needs to be a way for the intake not to. The stock pipe has a flex section that would need to be replaced by a hump hose or something, which would hinder flow and create a failure point.
That's my explanation.
Mike Levy
Default 10-03-2016, 05:54 AM
A bit of results on the stock turbo. I just swapped out the inlet last night and didn't change anything tuning wise. In comparing a few old and new logs, looks like I have gained 0.2psi above 4500rpms. I normally shift at 5200 so dont have anything higher. As a note, I have the stock airbox with K&N drop in. I'll be trying the MAF delete and cone filter as above and see if I can hold more.
