Go Back   N54Tech.com - International Turbo Racing Discussion > Model-Specific Engine Tuning & Modification Discussion > N55
Reload this Page Increasing the max current (I) fault limit to prevent fuel pump warning
(#51)
Chris1337 Chris1337 is offline
Car: 335i n55
Default 10-28-2018, 02:52 PM
Can anyone do this or me remotely? Or maybe give me an idea of what i am doing wrong? I did it manually and nothing seems to happened. I am not getting 2AAE i am getting a current too high code maybe it is the same but i'm not sure. Anything helps
WeekendWarriorz WeekendWarriorz is offline
Car: 2012 135i N55 DCT
Default 11-03-2018, 06:48 PM
So does this prevent the ekp module from being burned out or just suppress the code on the car? My car has this come up (CC-ID 309), if it just suppresses the code I’ll leave it for now.
2012 BMW 135i DCT, Late E series. VRSF meowless, ARM chargepipe, VRSF 7.5in race FMIC, Fuel it! Stage 2 LPFP- Sold
inevitab1e's Avatar
Car: 2013 N55 135is
Default 11-03-2018, 07:26 PM
I believe it raises the voltage ceiling so the code is avoided.
2013 E82 135is N55 JB4-BEF FBO
Default 11-03-2018, 07:30 PM
Is there any negative effects to not coding it out? Like if I leave it the way it is will I blow my ekp with all the faults itís throwing
jts1981 jts1981 is offline
Car: Z435is
Default 11-15-2018, 08:19 AM
Originally Posted by deemarr 335i
Can someone do this for me im in nyc ?
Same. I need this done for my Walbro 525 pump. I have already upgraded the wire from fuel pump to ekp. Looking to program ekp for higher voltage and update to 25a fuse.
Can any one in the NYC/ Long Island area help?
Cyteone87 Cyteone87 is offline
Car: 2008 335i
Default 12-15-2018, 09:07 PM
I have read all the posts on here and still cant figure out what I need to do to adjust the max fuel pump current.
I used NCS expert to read the ekp module and get the nettodat and .trc files. Then opened the nettodat with NCS dummy. It is easy to find the Max fuel pump motor current on ncs dummy but I have no idea what I need to change to raise the current.
Can anyone help me out with this?
The car is a 2008 335i with a n54 and the module is a EKPM60_2.C03
Default 12-15-2018, 09:13 PM
If you try to pull too much current could fry the EKP and wind up stranded. What pumps are you guys triggering the warning with? A single Walbro?
Car: 2008 335i
Default 12-15-2018, 10:59 PM
I have a walbro 450 part of the stage 2 upgrade from fuel it. Everytime I turn off the car I get a fuel pump warning on Idrive and the car on a lift icon in cluster.
My understanding is that these pumps pull more current and that sets off the warning. Recoding the fuel pump module to accept more max current should make the warning go away but either way the pump is pulling more current than the the OEM one.
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 12-17-2018, 11:43 AM
I have a stage 2 with a single Walbo 450, I haven't ever triggered a code yet. Maybe F difference vs E?
2013 BMW 335xi F30 N55 PWG
Injen CAI/ER CP/VRSF C-less DPipe/Active A FMIC/JB4 v3 - Map 7/e50/Custom tuned exhaust/stock turbo/Resonator Delete/MHD & JB4 e85 BEF/Stage 2 LPFP Walbro 450
Summer '20 install: Speedtech BW 8374/PI & Tune by Trebila
tcabill tcabill is offline
Car: 2012 535 M Sport
Default 12-29-2018, 06:44 AM
I'm running the Walbro 450 High Pressure (F90000274) and I do get the code occasionally when running >E40. Would like to find a way to code this out on an F chassis N55.
2012 535i M-Sport, VRSF Chargepipe, BAVAUTO Hi Perf Coils, NGK 95770 plugs (colder),GFB DV+, VRSF 3.5" **, Wagner FMIC, MHD Map E30 2+, Walbro 450 with 3/8" fuel lines from tank to HPFP with inline Ethanol sensor (all self fabricated).
afranke afranke is offline
Car: 2013 ActiveHybrid 3
Default 01-04-2019, 10:36 PM
I have the FuelIt Stage 2 which I assume is a Wal 450 of some description. I've gotten it with stock tune on 93 octane, and with a tune on 93 octane.
FEDE/E92 FEDE/E92 is offline
Default 04-18-2019, 01:43 PM
Will the file by OP work on a n54 or other changes need to be made?
andrews013's Avatar
andrews013 andrews013 is offline
Car: 2013 E92 335i xDrive
Default 03-03-2020, 12:56 PM
Reviving this thread.
I just did the coding change and my trims dropped significantly for some reason. It seems like the hpfp is holding on a little better at low RPM as well.
Also, no more little "!" after flooring it.
2013 E92 335i XDrive
JB4, MHD E85 BEF, EOS PI, Fuel-it Stage 2 LPFP, XHP Stage 3, XDelete Sport, 3.5 Bar TMAP, VRSF 7 HD IC, GFB DV+, VRSF D/P, VRSF CP, PE Mod, ST V1 Suspension.
houtan houtan is offline
Default 08-26-2020, 02:20 PM
So I replaced my 450 with a 535 and now i am getting this error. No biggie as i knew about this thread.
My issue is, if i try to follow the OP instructions, the C13 file in the first post does not load into NCSDUMMY. Is it a TRC or MAN file? Would appreciate any tips from anyone who has done this recently.
OK, got the EKP IMAX and Nettodat file loaded in the first page. I am not a rookie at ncsexpert but i am not expert as well. It was not very intuitive to get where i am at though lol.
So the OP says to check wert_200 for all six parameters. Problem is, when i load up the nettodat the option it adds is r61_stereo_pkr, which is weird. But the data matches what is posted later on as an option to copy and paste. Picture of what i am seeing is attached.
NM, i think i figured it out. Basically, follow post 6. Grab the file in post one and put it in your Datem/E89 folder and put the NETTODAT.MAN file in post 6 in your work folder then follow the steps. I havent started my car yet because it's late but the file loaded. Will post back if what it didnt work.
andrews013's Avatar
Default 08-31-2020, 07:08 AM
If I remember correctly, I had to enter the values manually. Not sure about the r61_stereo_pkr.
Default 08-31-2020, 02:04 PM
Thanks. I actually didnít have to change anything. Just loaded the file like I described at the end of my post and it worked. Thanks for the info op.
codingbmws codingbmws is offline
Default 09-19-2020, 05:25 PM
Can this be done to an n54 with upgraded fuel pump and running ekpm3? On the original post it only says n55 ekpm3. If it can be done, do I use the same manipulated ekpm3 file in the 1st page?
Default 10-05-2020, 05:13 PM
Anyone?
