Car: F06 N55 640i Gran Coupe
Default 06-17-2015, 02:28 AM
Will do. We're still in the early phases. We sent a few tuners out to start collecting some data but it may take a few weeks for us to finalize the connections being used and firmware.
I'm *really* excited about the boost solenoids. This opens up the tuning to seriously more power especially on meth.
Terry, can u send a set to Singapore Boss. Today I just bolt on my bigger turbo & seem like the adjustment on the meth additive already can affect a lot on the early boost & extra Tq, I can log them thru jb4 mobile easily. There are also a lot of user in the asia, I'm going to test on my timing tonight or tomo....
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS DP n FULL Custom Exhaust
Custom BC forge 18/17 set up
lfelunden's Avatar
Car: 335i e92
Default 06-17-2015, 02:43 AM
Any info on these turbos ?
lfelunden's Avatar
Car: 335i e92
Default 06-24-2015, 11:46 AM
When will we be able to order this?
Default 06-26-2015, 04:36 AM
+12345. Waiting...........
I think the M3 & M4 guys are much luckily than us, Terry started with M5 & M6 way earlier than them but ended we are still stuck at the present stage. Lol..... Just need to wait.....
lfelunden's Avatar
Car: 335i e92
Default 06-26-2015, 05:14 PM
I'm sure he is finalizing the last steps to cover overall needs for everyone - from at stock M5 upto FBO and turbos + meth.
I think most people want boost and fuel control to work in configuration with each other to make this a plug and play tune with minor testing/adaption.
Default 06-26-2015, 05:16 PM
I understand you guys are in a rush to get it. And we're excited to offer it. I ordered in some samples of the circuit board for the boost module which I expect in next week. If all goes to plan we can move in to public BETA shortly after.
lfelunden's Avatar
Car: 335i e92
Default 06-26-2015, 05:28 PM
Would be meet to have within 2 weeks! Vacation!
Did you test the fuel pressure? I saw an old post for the N63 where you did this. I mean, if boost control is sweet with then I guess that is not needed! GL on letting all go after the plan.
Default 06-26-2015, 05:43 PM
We don't have the sensors installed on our M5 but I know it's compatible with the board and can code it up. I'll code it up just for you. Have fun reaching the sensors though. It's a real chore. The FF harnesses are $35 each on our site. You'll need two of them.
Default 06-27-2015, 08:37 AM
Wow coming along very well, T pls allocate some for Singapore Boss too.
Here we are waiting for it too, can start to count down now......��
lfelunden's Avatar
Car: 335i e92
Default 06-28-2015, 01:40 PM
Well, can I say anything else than - YOU the man
TTM5 TTM5 is offline
Car: M5
Default 06-29-2015, 10:15 AM
Terry, can u please explain how much more power we can expect on 93 with this jb4 over stage1 assuming no clutch upgrades?
Default 06-29-2015, 10:18 AM
On that, its too early to say. Anywhere from 0 to a lot.
lfelunden's Avatar
Car: 335i e92
Default 06-30-2015, 02:06 AM
Any news on when this is ready to be shipped? I'm off to vacation next friday
allmotor_2000 allmotor_2000 is offline
Car: 2014 F10 M5 CP Frozen Grey
Default 06-30-2015, 08:10 AM
JB4 by itself doesn't generate more power (other than RPM controlled boost) correct - its the BCM that uncorks things ?
Default 06-30-2015, 12:02 PM
Right. The JB4 itself only allows better logging and diagnostics, and mapping on engine speed, pedal input, gear, etc. But not more power.
Default 06-30-2015, 05:21 PM
Huh? How about to control the boost solenoids? Doesn't that increase power on the new JB4?
Default 06-30-2015, 05:25 PM
Adding in the boost control module along with the JB4 opens up a lot more power potential than JB4 only or Stage1.
Default 06-30-2015, 05:33 PM
Sound more right on what we are all waiting for 👍👍👍
Car: M5
Default 06-30-2015, 08:19 PM
What is the reasoning for this on pump gas?
Default 06-30-2015, 08:27 PM
More boost means more power. And with the JB4's CANbus you can monitor knock, AFR, etc, and ensure those gains are applied safely for whatever fuel you're using.
Default 07-01-2015, 04:59 AM
Lol..... The next question will be when can we enjoy it? Lol......
Car: M5
Default 07-01-2015, 07:08 AM
If Jb4 w/boost makes noticeably more power over my currently installed stage 1 on pump gas I will purchase it, otherwise no point.
Default 07-01-2015, 09:34 AM
Not much has happened in the last week on the development front. Waiting for the prototype BCM PCBs so I can solder a few up and continue development. Our development car has a nest of soldered up wires, diodes, resistors, and MOSFETs right now, acting as the BCM.
Default 07-01-2015, 10:54 AM
Can I borrow that version :-)
Default 07-01-2015, 04:55 PM
The PCBs showed up so I threw one together. I'll install it on our development car this week to verify it works as expected. We'll add some loom to the harness to clean it up a bit.
