(#51)
junotramm junotramm is offline
Car: Bmw
Default 05-18-2014, 08:26 AM
quick question, if any e85 and meth not an option, which least octane race fuel i can use to get 450whp with 2014 235i?
Default 05-18-2014, 09:24 AM
I'm not sure if or how much more than 415whp can be made on any octane with the OEM turbo. We'll continue working on that front. 450whp OEM turbo are N54 numbers though...
Car: Bmw
Default 05-19-2014, 02:39 AM
wow 415whp is seem enough for me, even more... so with premium fuel with larger turbo will be around 460whp?
jose135in55 jose135in55 is offline
Car: bmw 135i
Default 05-21-2014, 09:47 PM
hi terry can you check this logs i do this on map 7 vtt stage2
Car: F06 N55 640i Gran Coupe
Default 05-22-2014, 01:40 AM
What fuel are u using?
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS DP n FULL Custom Exhaust
Custom BC forge 18/17 set up
Peter @ Pure's Avatar
Car: F20 M135i
Default 05-22-2014, 04:11 AM
I see high iat, not enough boost and crappy timings. I guess you need more octane?
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Default 05-22-2014, 04:57 AM
Oh I thought he is running way too rich with 11plus APR?
Default 05-22-2014, 08:28 AM
What mods, fuel, etc?
Car: bmw 135i
Default 05-22-2014, 11:22 AM
Hi Terry jb4 5.3v air intake fmic chargepipe oil catch can meth kit Vargas turbó stage 2 fuel 91 octane
Default 05-22-2014, 11:24 AM
IAT is not dropping... Sure meth is flowing?
Car: bmw 135i
Default 05-23-2014, 07:09 PM
hi terry send map again
Default 05-24-2014, 07:09 PM
Without a back end flash we can't raise the timing max advance points. So if you can't make any more boost and timing is maxed out currently, you're out of ways to make more power.
Hi Terry, when will the backend flash be ready for our larger n55? Anyway to make more power? Quite use to the power now & really need more...
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 05-25-2014, 06:00 AM
i think you should've bought 650i instead
N55 - Doc race 6266.
1slowN55 1slowN55 is offline
Default 05-25-2014, 05:21 PM
I fairly certain you won't have a backend flash for a very very very very very.... very long time. Flash isnt compatible with your care..
2011 N55 335i E92
PURE STAGE 2 FBO
JB4+BMS MHD BEF E50
FX500 Clutch
Default 05-25-2014, 11:53 PM
Car: bmw 135i
Default 05-26-2014, 06:24 PM
sorry terry can you check my logs please
frefer82 frefer82 is offline
Car: 2011 135i N55 DCT
Default 06-18-2014, 08:53 AM
sorry guys can i install this kit on a 435i????
Default 06-18-2014, 08:56 AM
IAT is up there but timing on map 6 looks OK.
Default 07-04-2014, 06:21 PM
Install the Vargas turbo on our 2011 135i DCT and I finally had a chance to do a little testing. Added back end flash and settings to the first post. On 93 octane only or with a small E85 mix you can try map 2. Which will basically run the flash only boost curve of ~18psi tapering to ~12psi. With a meth kit installed map 6 can be tested out.
I'll get ours on the dyno next week to see what we can do on pump and then on meth.
Default 07-04-2014, 08:46 PM
Is this the stage 1? How does it feel with the turbo? Does the top end change make it a worth wild Upgrade.. im getting mine shipped soon will i be able to run map 6 without a backend flash and some 100 octane or e85
2011 N55 335i E92
PURE STAGE 2 FBO
JB4+BMS MHD BEF E50
FX500 Clutch
Default 07-04-2014, 11:00 PM
No it's the same Vargas N55 turbo we had on our 2011 335. We moved it over as we need the 335 stock for product certifications.
keyap keyap is offline
Car: N55 135i
Default 07-12-2014, 01:04 AM
Any updates / dyno numbers yet Terry?
Default 07-14-2014, 07:34 AM
Hi there friends.
mi car is a 2011 135i and want to install the vargas turbo and the car have the next modes, what else do i need to install the kit here in cololmbia i dont have E85 fuel.
JB4 ISO
CPE charge pipe
AR ******* down *****
ER race intercooler
burger tuning METH kit
Injen intake
AA catbak
like say before here in colombia we dont have E85 but i can find sunoco its not cheaper but i can find to race.
all help can be great thanks, for the time
j23a45m's Avatar
j23a45m j23a45m is offline
Car: 2011 E90 335i
Default 07-14-2014, 07:37 AM
Originally Posted by frefer82
Hi there friends.
JB4 ISO
CPE charge pipe
ER race intercooler
Injen intake
AA catbak
Flex fuel wire so the car won't run lean when you're taking advantage of E85
2011 BSM 335i E90 MTECH 6MT • BMS Intake • Vishnu c@t less DP • Cyba Scoops • LUX V4 H8 • 6000K Headlight/Fog light Morimoto • Euro headlight switch • ACS roof wing • 35% tint • Black Grilles • Misc coding • JB4 Stage 2 • AA charge pipe • Vrsf 7" FMIC • M3 cluster •
Default 07-14-2014, 07:58 AM
but here in colombia we dont have E85 fuels.
