(#676)
cmcacmca75 cmcacmca75 is offline
Car: 2013 535i xDrive
Default 02-20-2020, 07:53 AM
Thanks Terry and I emailed you for a copy of that flash.
Side note, I reloaded the PWG -T7 flash that you emailed me before, and my findings are that it in fact does begin to move WGDC off of 0 at boost 5 PSI. The flash that is on this website for download (-T1) moves my WGDC no sooner that 8.8 PSI boost.
here is a section of the -T7 log
drwillb drwillb is offline
Car: 2012 n55 135i
Default 02-20-2020, 10:24 AM
I've been complaining about pre-boost for a while. It seems to spike up to max DC and then crash DC and boost after it causes overboost. Seems there should be a way to soften it some to eliminate the yo-yo efftect.
This screeenshot and .csv are from this past December, when I was finally able to tame most of the crash but you can still see there's a spike in DC followed by a boost crash and then lag trying to get all factors back in order. That's the best I've ever gotten it and I probably have another 80 logs after that, trying to improve on it. No matter what I've adjusted, I always get the 100% DC spike.
2012 135i Mods: air scoops, CP, BMS filter, PS1, N20 TMAP, ADE FMIC, BMW PE, JB4, BMS BEF, 1M front body, full M3 suspension
Owned so far: 88 M3 x 2, 95 325is, 95 M3 x 2, 06 Mini Cooper S, 08 335 xi, 09 Z4 35i, 01 M3, 12 135i
Default 02-20-2020, 11:06 AM
E chassis runs ISO so nothing in common with the F chassis integrated tuning discussion above.
As to your question I don't really understand it. WGDC goes to 100% during spool up mode. In E chassis firmware the spool up window is fixed at around 3psi below target but we can always make it adjustable.
Default 02-20-2020, 11:07 AM
No email received. For logs I can't look at photos of data, sorry. Only the CSV.
Default 02-20-2020, 11:13 AM
I forwarded the email again just now.
Also attached the CSV of this mornings run, showing WGDC moving at 5PSI.
Default 02-20-2020, 11:18 AM
Looks as expected. With integrated firmware < ~2psi is DWP logic, > ~5psi is PID loop logic.
Car: 2012 n55 135i
Default 02-20-2020, 11:30 AM
Terry, I would love to have the spool up adjustable!!
thank you.
Default 02-20-2020, 11:45 AM
Yes, but I think that with the PS2 my base DMW flash and JB4 are both assuming a stock spool up.
JB4 WGDC is reacting in -T7 properly to the 5 PSI, but the DMW flash is spooling slower, because it Duty Cycle calculation are for stock not my PS2.
I am hoping the I can be additive to DME duty in the lower RPMs. At 3800 RPMs I hit 5 PSI. That 5 PSI boost would hit at a more reasonable lower level if we can create a higher duty that the DME is putting out during spool time.
Hopefully INT_14 will help with this larger Turbo.
Thanks again Terry.
Default 05-24-2020, 04:11 PM
Ok, problem related to over machined turbo outlet. Got replacement and now acting like every other ps2. Thank you Pure!. Car spools quickly now and hitting high 23psi. 0-60 dropped considerably to 3.64 sec. Not bad for a family car. Running now N55_F_PWG_INT_14.HEX (BETA) and E40 with E85 BEF.
All past issue I had were related to the turbo and is now fixed with the replacement.
Phat135's Avatar
Phat135 Phat135 is offline
Car: 2012 135i
Default 06-19-2020, 12:20 PM
Can someone enlighten me in how I would go about tuning an external wastegate setup from speedtech? Do I need a boost controller of some sort? Are dyno tuning options available to me through mhd?
dfahmy dfahmy is offline
Car: F30 328i
Default 06-20-2020, 02:17 AM
Hi, i have a 2013 f30 pwg n55 and I was wondering if you guys have a single turbo firmware for it so that the jb4 can control a Mac solenoid but not control anything else ?
2013 F30 335i ~ Eisenmann race exhaust, AFE Magnum cold air intake, Bigboost Stage 3.4 turbo, Forged internals, Wagner evo 2 FMIC, Dual CM5 meth, MMP PI, Fuel it stage 3 LPFP
kyloo kyloo is offline
Car: BMW 135i
Default 08-24-2020, 01:46 AM
Hi Terry please take a look here
car is running a hybrid turbo, logged on map 2... boost is coming in very late and laggy with bad throttle closure early on
