1slowN55 1slowN55 is offline
Default 05-08-2014, 06:56 PM
Without a back end flash we can't raise the timing max advance points. So if you can't make any more boost and timing is maxed out currently, you're out of ways to make more power.
I ordered a turbo recently and waiting on its arrival.. regarding the backend flash do I email you once im ready and my turbo installed?
2011 N55 335i E92
PURE STAGE 2 FBO
JB4+BMS MHD BEF E50
FX500 Clutch
Default 05-08-2014, 07:11 PM
Cobb has limited model support. But load their Stage0 map and assuming that loads you should be OK. Just let me know the DME version then and we can email you the appropriate file.
jose135in55 jose135in55 is offline
Car: bmw 135i
Default 05-08-2014, 07:32 PM
Hi terry so to let me know for example me if dont have the back end flash but i have all the stuff and Vargas turbo upgrade how many hp can make certainly
Nugs Nugs is offline
Car: 2011 135i
Default 05-08-2014, 11:03 PM
Originally Posted by Nugs
So potentially I could fill with E60ish and run a custom map6 and just change the JB4 to map 2 or 5 if I need to fill up with normal pump fuel?
Hi Terry can you confirm if this is the case or would I also need to change flashes when I change fuels.
Car: F06 N55 640i Gran Coupe
Default 05-09-2014, 06:09 AM
Hi Terry, what do I need in order to be able to load the backend flash n other stuff eg. 3.5bar sensor or any other wire or software or hardware to make more power?
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS DP n FULL Custom Exhaust
Custom BC forge 18/17 set up
Peter @ Pure's Avatar
Car: F20 M135i
Default 05-09-2014, 07:11 AM
You need E series n55 car and be lucky
There is no backend flash for F series cars.
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Car: F20 M135i
Default 05-09-2014, 08:39 AM
Modified my dyno post with the whp numbers i got from the shop.
peter@pureturbos.eu
pureturbos.eu
Default 05-09-2014, 08:42 AM
I think they support most 2011 and early 2012 models. That's it.
The 3.5 bar sensor is not required but can be handy. Our E series N55 ISO firmware supports it. No F series support yet but we'll add it in a few weeks.
Default 05-09-2014, 03:12 PM
Alright, I think now can't do much but to try to stay do some butt dyno. Thanks guys.
stanlalee's Avatar
stanlalee stanlalee is offline
Car: 2007 E92 335i 6sp
Default 05-10-2014, 06:42 AM
Originally Posted by Hellraiserharris
I didn't think the n55 had high pressure pumps any more. I know the dealer told me when I bought my new 435 it did not have a high pressure pump. Because of all the problems associated with them on the n54 motors.
ALL direct injection engines operate with fuel pressures in the 100-170 bar range (about 1500-2500 psi) at the rail so there is a high pressure fuel pump.
Car: 2011 135i
Default 05-11-2014, 06:23 PM
Hi Terry can you confirm if this is the case or would I also need to change flashes when I change fuels?
Curious if this is the case as I would love this flexibility.
Also is the backend flash help out with DCT shifting?
I was getting some slurring of shifts with JB4 only.
Default 05-11-2014, 07:42 PM
Normally the flash map has to match the fuel/octane used to get the most out of the octane. You could run a weak boost curve on the E85 flash if you wanted though.
Car: bmw 135i
Default 05-11-2014, 10:44 PM
hi terry afr 10.5 is ok...? this is in map 6, i use methanol this time
meth tab on 0 and flow scale in 60 is ok..?
i got the 3.5tmap sensor what do i need to install
Default 05-12-2014, 08:15 AM
If the AFR is that rich you're probably running negative fuel trims. Try setting CPS1500 to 50 to offset the open loop as a function of meth flow.
On the 3.5 bar after installing set AFR1500 to 1 to enable it. Then everything works as normal. Only the JB4 can read up to 30psi instead of 21psi.
Car: bmw 135i
Default 05-13-2014, 11:52 PM
The iso could be the 5.3 version or have to be 5.2
Default 05-14-2014, 02:52 PM
The latest one. The older ones don't have 3.5bar support.
Car: bmw 135i
Default 05-14-2014, 09:45 PM
but for large turbo is 5.2 v or could be 5.3v for largeturbo and for 3.5tmap sensor
j23a45m's Avatar
j23a45m j23a45m is offline
Car: 2011 E90 335i
Default 05-15-2014, 12:52 AM
use 5.3 it has the latest support period!
2011 BSM 335i E90 MTECH 6MT BMS Intake Vishnu c@t less DP Cyba Scoops LUX V4 H8 6000K Headlight/Fog light Morimoto Euro headlight switch ACS roof wing 35% tint Black Grilles Misc coding JB4 Stage 2 AA charge pipe Vrsf 7" FMIC M3 cluster
Car: F20 M135i
Default 05-15-2014, 10:42 PM
Would it be possible to have same map3 meth safety/functionality in map6?
This way the people with larger turbos and meth can set boost levels that work with their car and still have the integrated map3 safety?
Tnx!
peter@pureturbos.eu
pureturbos.eu
Default 05-16-2014, 10:11 AM
Tnx!
Years ago it was setup that way where the additive would add on to map 6 values as a function of methanol flow but back then it caused more harm than good.
What I'll do is add option FUB = 4 to the N55_ISO firmware. Which will trigger the boost additive on map 6 as well as map 3. So you'll setup a map 6 boost curve suitable without meth, then enter an additive that is added on top of that curve as a function of methanol flow.
If anyone wants to test it just email me for the firmware.
Car: F20 M135i
Default 05-16-2014, 03:20 PM
Mail sent
peter@pureturbos.eu
pureturbos.eu
Default 05-17-2014, 01:56 PM
Firmware is on the way! I've ported it over to the F and E series ISO firmware, and will make the same changes to the F series integrated firmware for those using Stage1 type turbos.
Default 05-17-2014, 02:46 PM
Great! I suppose is this for the back end flash firmware?
Default 05-17-2014, 02:50 PM
This is JB4 firmware and has nothing to do with the back end flash available for 2011 E series models only.
Thumbs up 05-17-2014, 03:01 PM
Oh sorry my mistake, thanks for the super fast respond seem like u r 24hrs on the alert mode
