(#1151)
Thomas92 Thomas92 is offline
Car: 2011 e90 335xi
Default 08-19-2020, 11:29 AM
You can contact MHD for the updated xdf and disable the code in TunerPro, or I can send you either the xdf and you can do it yourself or the bef im using (pump 98G0B). Just pm me your email if you want it.
2011 e90 335xi 6mt
Pure Turbos Stage 2 | PT Inlet | GFB DV+
Wagner Tuning Catted DP | Performance Evo2 FMIC
Performance Exhaust
BMS Intake | JB4+BEF | WMI | Masata CP
MovIt Front BK | H&R coilovers
qvr qvr is offline
Car: N55 135i DCT
Default 09-02-2020, 05:19 AM
Please help. After I have opened the 98GOB.xdf file in TunerPro and let's say I want to deactivate 321F DMTL, what is the correct way to do that?
Car: 2011 e90 335xi
Default 09-02-2020, 05:29 AM
Load the correct xdf and bin you want to change, open the 321F code and change the value to 128 i believe (i think it is mentioned there) for deactivation of the code, reflash and enjoy CELless ride.
2011 e90 335xi 6mt
Performance Exhaust
qvr qvr is offline
Car: N55 135i DCT
Default 09-02-2020, 05:41 AM
Thank you.
sjsu335i's Avatar
sjsu335i sjsu335i is offline
Car: 2013 335i N55
Default 09-12-2020, 08:06 PM
Installed jb4 with bef, log files attached.
Default 09-15-2020, 01:56 PM
Seems fine but not much full throttle to look at!
manhoso113 manhoso113 is offline
Car: x1
Default 09-24-2020, 08:50 AM
Will there ever be a 9E60B Pump_THR for us?
I have the xhp mod and the shifting is a bit wonky often.
andrews013's Avatar
andrews013 andrews013 is offline
Car: 2013 E92 335i xDrive
Default 09-24-2020, 09:11 AM
Email Terry. I've been running a 9E06B PUMP and E85 THR for 7ish months now. Not sure why they're not included with the download.
2013 E92 335i XDrive
JB4, MHD E85 BEF, EOS PI, Fuel-it Stage 2 LPFP, XHP Stage 3, XDelete Sport, 3.5 Bar TMAP, VRSF 7 HD IC, GFB DV+, VRSF D/P, VRSF CP, PE Mod, ST V1 Suspension.
Default 09-24-2020, 03:58 PM
I'll see what we can do!
E30_Crazy E30_Crazy is offline
Car: '14 X1 35i, '87 325i MTech1
Default 09-30-2020, 01:59 AM
Is the Pump flash safe to use with 89 and/or 90 oct? Been beating my head in trying to chase superknock codes since moving to Alaska.
tellreded tellreded is online now
Car: 2011 335ix
Default 10-09-2020, 09:10 AM
Hey @terry. So I've had a weird experience with mhd and the bed with jb4. I loaded the 98g0b_stock map for mhd that you provided and when on map 1 or 2 (or any for that matter)on the jb4, it's trying to get 17 or more psi. It's also not actuating the wastegate properly so I sit at 100% wgdc with no boost until about 2500 to 3000 rpm. Then all of a sudden I get whiplash and go sideways with full boost. I've also been getting half power code with a low boost (2775 cel number) code that comes up if I let the rpm sit over 1900 for a minute. After flashing to 98g0b_pump_thr, the issues have gone away completely. Do you know what might have caused this? Because I miss getting whiplash and I want that power back, but I want to get it properly. (I have BMS intake, bms chargepipe, gfb DV+, 94 Oct, stock fmic, stock dp, stock turbo, stock pwg, mhd, jb4, xhp)
