hi rpm's Avatar
hi rpm hi rpm is offline
Car: 2013 335i xDrive Coupe
Default Axles, manual vs automatic - 09-24-2020, 01:15 PM
Are manual axles compatible with automatic cars, specifically 2013 E92 335i xDrive? I'm looking at GKNs because they're OE but cheaper than BMW, and I can't find the rear left auto axle anywhere. ECS calls the manual "compatible" but they don't ask if your car is manual or auto.
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 09-28-2020, 10:51 AM
RealOEM shows the front axles the same and the rear different (I don't know what is different though):
you can find this info on getbmwparts.com
Manual
33207604603 Manual
LR
33207604604 Manual
RR
Auto
33207604591 Auto
LR
33207604592 Auto
RR
2013 BMW 335xi F30 N55 PWG
Summer '20 install: Speedtech BW 8374/PI & Tune by Trebila
hi rpm's Avatar
Default 09-28-2020, 11:23 AM
Originally Posted by zole2112
RealOEM shows the front axles the same and the rear different (I don't know what is different though...
Thanks, I've also seen different part numbers for them, I'm just wondering about compatibility. Based on searching the manuals may be heavier duty but still fit, which would be fine with me (better actually). Of course I want to know for sure before buying.
Default 09-29-2020, 10:15 AM
Yes I see the same, and I see some websites such as ECStuning etc that show one of the part numbers as an exact fit without distinguishing between auto or manual trans. My '13 335 xdrive is an n55, F30 with pwg and I have found websites multiple times that show a part as compatible when it wasn't so I make sure to do my homework and research until I'm confident I'm getting the correct part.
