jwagman1 jwagman1 is offline
Car: 2015 M3 F80
Default Log Review Please? - 08-20-2020, 09:53 AM
Hey guys!
New to the JB4. I ran a data log today after installing VRSF intake and resetting the ECU.
Can you you review my log and let me know if you see anything odd? Does it look good?
2015 M3 S55 25%E85 with 75%CA91 octane. MAP 1.
Will be installing down ***** and chargepipes this weekend, so i want to make sure everything is running fine before i move to MAP 2.
Data log attached.
I APPRECIATE YOUR ASSISTANCE!
Default 08-26-2020, 03:52 PM
Short run but looks fine to me! Go for it on map2.
Car: 2015 M3 F80
Default 08-26-2020, 04:22 PM
Terry,
Thanks for looking at that!. Here is my stage 2 if you dont mind taking a peak. This has a lot more WOTs in it. From my novice look, it appears good. 2nd file even hit 28psi (is that the map max?)
Default 08-28-2020, 02:53 PM
Looks good to me! Hit around 27psi peak post shift. Factory target 22psi, so as expected.
