MTHX MTHX is offline
Car: M5 F90
Default Question utilisation - 08-15-2020, 06:43 AM
Hi,,
For f90 M5
1- If I do not connect with the android application for example, does the JB4 keep the last MAP configured or fall on the MAP0
2- On my vehicle, to erase the codes, I am able to erase them without entering maintenance mode. Do I continue to do it like this or it is imperative to do it in maintenance mode?
3- If the jb4 fails, does the system keep the last MAP or the system drops to MAP0 and it's like a bypass
4-Do you think I can extend the wire which is connected to the board and which provides Bluetooth. Do you think I can make it 3 feet longer?
