guile guile is offline
Car: BMW M4
Default New to JB4 - S55 Blue Wire Question - 05-19-2020, 06:07 PM
Hi all
it looks like a great informative community you have here and I'm hoping to tap in to it please.
I have done numerous searches to check if this question has been asked before but did not get any conclusive results. apologies in advance and I'm prepared to get flamed if its an obvious answer.
I've just picked up this JB4 on the used market for my 2014 completely stock M4 and I'm trying to find out what the blue wire is for that is circled in the photo. I did read somewhere that its possibly for the bluetooth connection but then also read that you connect to one of the red wires for that.
thanks in advance
Richard
Default 05-21-2020, 12:16 AM
Blue wire most likely from an FSB.
Car: BMW M4
Default 05-21-2020, 02:54 AM
thanks for the reply mate, the person I bought it from said the wire was always like that and they just taped the end to prevent corrosion.
do you know if the JB4 came from the factory with that loose wire or someone has added for a failsafe box (presumably for water meth?)
the install instruction state the following but I can't see anything about the blue wire when I watch the video:
"Note some older JB4 mobile adapters have a separate blue wire which will need to be attached to the JB4 harness via a posi- tap, refer to the video on the JB4 Mobile adapter page for additional directions.
This video shows how to take apart the JB4 enclosure and plug in the adapter, and for those models that require it, how to attach the posi-tap to the loose blue wire: https://youtu.be/Q6NvtItTrUg"
Default 05-29-2020, 01:43 PM
If you open the shell up and see where the wire is going to we can tell you.
Either way, doesn't do affect anything right now.
Car: BMW M4
Default 06-05-2020, 03:25 AM
thanks mate, due to COVID and border restrictions I can't even get to my car at the moment but I'll check it when I get back. thanks again.
