VipinLJ VipinLJ is offline
Default JB4 on G20 330i - 03-18-2020, 09:29 AM
Hey guys
I am running a JB4 on my G20 330i (B46) with no other mods. It is on map 2 since I use 93AKI fuel. Before the JB4, I had a JB+. I did a few runs on the exact same road using the same methods and I was shocked to find out that both the jb+ and jb4 made the car react exactly the same (I have speedometer recordings of both runs showing there is absolutely no difference between JB+ and JB4 map 2). I was expecting a slight difference (JB4 map 2 being faster). Any idea why that could be? I don't have any logs yet because it's been raining and slippery here but I will post logs soon.
2020 BMW 330i xDrive - JB+ vs JB4 Map 2 - YouTube
Also, I have the JB4 mobile connect app. It shows the maximum boost recorded as 27.3-28.1, which is surprising. Is that an error or is it normal? I got the maximum boost values by double tapping the boost gauge to show the max saved value.
Current:
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
2016 BMW X3 xDrive28i
Default 03-18-2020, 05:17 PM
A few people I’ve spoken to say that level of boost is insane and possibly even dangerous for my car. Unfortunately I have no way of knowing how my car is behaving to it except that it sounds and drives fine.
Any insight will be appreciated.
Current:
Ke90 Ke90 is offline
B58_Dude
Car: M240i
Default 03-18-2020, 06:15 PM
Originally Posted by VipinLJ
A few people Iíve spoken to say that level of boost is insane and possibly even dangerous for my car. Unfortunately I have no way of knowing how my car is behaving to it except that it sounds and drives fine.
I would email technical support here is link.
https://burgertuning.com/pages/contact
Default 03-18-2020, 07:21 PM
Thank you very much! Let me reach out to them
Current:
Default 03-19-2020, 06:15 PM
There is no CSV here to offer any tuning help with.
Default 03-20-2020, 04:16 PM
Finally managed to get a decent log of Map 2 on JB4:
1. Fuel - 93AKI
2. Mods - None except for JB4
3. Map - 2
4. Traction off
5. 3rd gear starting at below 2000rpms upto redline at WOT
Max boost in this was above 20psi.
I have logs of the run where I hit more than 25psi boost but those logs are too long and might piss you guys off I'll post screenshots of the graph where boost hits those values beneath too. Just in case. Same firmware. Same map. Same fuel and other conditions.
The log file is after all the image files. Right at the bottom of the attachments.
File Type: csv 20200320_173752_runs(1) logging map 2.csv (15.6 KB, 72 views)
Current:
Default 03-21-2020, 10:58 AM
I have another log on the same map done today. The logging map doesn't show that high of a boost. But normal driving map shows very high boost values. I've also included a normal drive map.
Current:
JBoe JBoe is offline
Car: M240i
Default 03-22-2020, 01:27 AM
Be careful not to mistake boost levels that are captured during shifts or throttle closures. They'll show high as there is a spike during those times. Remember, the car uses the throttle to control boost. There is no BOV or ByPass Valve. We can't trust the max/peak boost meter, IMO.
I believe the reading under boost 2 shows manifold pressure, which is a better comparison and can help you weed out the erroneous spikes. Just fyi...
AFE Drop-in Filter
BMS Meth Kit (100% M1)
Muffler Delete
CA 91 Piss Gas...
(8oz Boostane 95ish Oct)
E85 (2Gal/Fill)
BEF (Race_WMI)
JB4 (Map 7 - Add 45... 19-20psi)
Default 03-22-2020, 08:17 AM
Thank you so much! I had no idea why my boost showed those spikes since Iím not very knowledgeable in this area. You explained it really well and Iím very grateful to you for that. I guess I can breath easier now knowing the reason for those spikes
Thank you very much once again.
Current:
Car: M240i
Default 03-22-2020, 09:46 PM
No worries... I haven't had a chance to open your logs on a PC (I don't have the app). When I do, I'll post up my thoughts.
AFE Drop-in Filter
Muffler Delete
CA 91 Piss Gas...
E85 (2Gal/Fill)
BEF (Race_WMI)
Default 03-23-2020, 10:47 AM
I got new logs on the latest firmware (v15). Iím attaching those in this post. Thank you very much once again!
Current:
Default 03-29-2020, 05:54 PM
I'm posting logs on map 0 (stock map), map 2 and 3 below. In case someone wants to review and/or compare
G20 330i B46
JB4 v15, no other mods
93aki fuel only
Current:
Car: M240i
Default 04-01-2020, 07:38 PM
G20 330i B46
93aki fuel only
Map 3 looks pretty good from what I can see. How does it feel? It's a big change over stock so it should feel like a night/day difference.
AFE Drop-in Filter
Muffler Delete
CA 91 Piss Gas...
E85 (2Gal/Fill)
BEF (Race_WMI)
Default 04-01-2020, 07:56 PM
Oh yes. There’s a noticeable difference between stock and map 2/3, especially when one is doing rolling pulls. The JB4 definitely wakes the B46/48 up.
I’ve gone back to map 2 since the JB4 firmware settings mention map 2 for 93 octane and map 3 for 93+ octane. I’ll be putting in a gallon or two of E85 to raise the octane rating and then run map 3. And maybe get a log then to see if things are fine.
Thank you very much for taking a look at the logs. I appreciate your input.
Current:
Turboh's Avatar
Turboh Turboh is offline
Car: 2017 BMW 340iX
Default 04-02-2020, 07:06 AM
Oh yes. Thereís a noticeable difference between stock and map 2/3, especially when one is doing rolling pulls. The JB4 definitely wakes the B46/48 up.
Iíve gone back to map 2 since the JB4 firmware settings mention map 2 for 93 octane and map 3 for 93+ octane. Iíll be putting in a gallon or two of E85 to raise the octane rating and then run map 3. And maybe get a log then to see if things are fine.
I have the identical car on 93 octane and drop in K&N.
I did look at your earlier log (...173 175 runs 1), and compared them to my runs....you can see them in my log review request a couple of days ago.
This what I noticed:
1. you are using an older firmware version 11...suggest you switch to version 15
2. your timing is very erratic...
3.your boost values are much higher....possibly resulting in erratic timing
4. trims are higher, but your IAT was lower...seems OK
5.AFR compares nicely and seems ok.
6. Map 2 target seems to be flat 4.0. Almost like a map 6 with 4.0 flat boost. The boost pressures seems to be too much.This may be due to the firmware version, though I have seen some difficulties with version 11 that did not make sense.
I plan to do map 0,1,2, runs and map 6-3, 3.5, and 4 flat. in the next week or so.
Will compare more later.
I would definitely install version 15, before any more runs.
Alex
2020 330iX auto sport w/M track handling, JB4 ; 93 octane; Honda S2000; Ninja Z1000.
Default 04-02-2020, 08:30 AM
Alex
Heya
I did update my firmware to v15. In the last few posts, the logs are all on v15.
And yes. I did compare your logs with mine and noticed that my boost was higher than yours (even the spikes). I messaged Ando about it and he said that could be because of various factors such as environment, fuel etc (I forgot what exactly he said but Iíll check and update). He said my logs looked fine.
I had another friend who is not on here go through my logs and he said the same thing you said
Do you have any settings for a map 6 that maybe I could try? I am a noob to this and I have no idea how to make a custom map.
Regards,
Vipin
Current:
Turboh's Avatar
Car: 2017 BMW 340iX
Default 04-02-2020, 08:55 AM
Alex
I see you shifted to V15. I did a quick comparison with your 3 runs against the ones I posted a couple of days ago, and for which I have not yet received any review.
It is very interesting to do the comparisons. This is what I noticed, compared to my runs:
1. Big timing drop on ign 1, map 0 and acceleration 51, ave boost 12.1, advance is in the 7s.
2. Map 2 and 3 runs target values show what was added. Mine does not. Mine shows a total target value, i.e. close to actual boos value. I have noticed this before on other firmware change overs. I have loaded and reloaded the firmware several times, so I think it should be OK. Still, it raises a question about mixing up different firmwares on the JB4. Others have had similar issues with firmware 11.
2. Map 2 and 3 timing seems to be on the low side compared to mine at roughly the same IAT.
3. Map 2 acceleration is about 58 and same as mine. Map 3 acceleration is 60 and much faster.
The biggest difference I noticed and would like an answer to is that your final boost average is 17.4 psi vs mine at 14.9 psi. IATs and acceleration we the same. You ignition advance was 4.2 and mine was 7.0. Your ignition variation and mine tend to be quite erratic...not smooth.
Stay in touch.
Alex
Default 04-02-2020, 09:33 AM
I’ve PMed you Alex
Current:
Turboh's Avatar
Car: 2017 BMW 340iX
Default 04-08-2020, 08:16 AM
Iíve PMed you Alex
See my email to you.
Here are my settings
Turboh's Avatar
Car: 2017 BMW 340iX
Default 04-08-2020, 08:18 AM
Missed one
Default 04-08-2020, 08:59 AM
Thank you very much! I’ll try those numbers and let you know how it goes. Damn covid isn’t helping much unfortunately.
Current:
Default 09-19-2020, 05:00 PM
Posting a log in 3rd for review. Any insight will be appreciated.
I'm also posting a log of a WOT and LC run from yesterday. I noticed a power drop when shifting from 1st to 2nd and 2nd to 3rd at the red line. Does the log show why that happened? There was a slight jerk when shifting and the car felt like it was cutting/losing power right when it shifted.
Current:
Default 09-20-2020, 08:40 AM
Late to the party but the log appears normal to me. Some throttle trimming down low to regulate boost to target but not so much that manifold boost ever drops below target.
Default 09-20-2020, 09:02 AM
Thank you very much. As long as there are no problems, I'm not worried. Car puts out lovely numbers. Best I got using dragy was 13.15s@104.78mph. Worst was 13.42s@103.5mph but that was with 4 full grown adults on board, shopping in the trunk and a 3/4 tank of fuel :D
Current:
Car: BMW G30 520i 2019
Default 09-19-2020, 08:49 PM
Try a run from 3rd gear @2500rpm, go wide open throttle (but don't activate the little switch at the end of the pedal travel (this will cause the transmission to drop down a gear), all the way up to recline and a shift into 4th.
Pulls from a standstill or 1st and second gear tend to give a big variance in results.
You probably want to drop your boost targets @ and below 2500 rpm to something a bit more conservative, lugging your engine at high boost and low rpm and high load is a recipe for disaster.
