We will use this thread for discussion and updates on our new Ranger JB4!
BMS data cable hard wired directions Click here
JB4 Map Guide:
Map0: Fully disable JB4
Map1: +3.5psi peak over stock, default map, suitable for all fuels.
Map2: +3.5psi peak, less top end taper, more aggressive version of map1.
Map3: +4psi peak, suggested for 93 octane or up to 30% E85 mixtures.
Map4: +6psi peak, suggested for 30% E85 mixtures and/or unleaded race fuel
Map5: +7psi peak, suggested for 30% E85 mixtures and/or unleaded race fuel
Map6: User adjustable by RPM map on user adjustment page, values are peak boost over stock by RPM under heavy throttle.
How to update firmware:
For firmware updates we suggest you turn off WiFi, change upload timeout to 25, and set your phone next to JB4 box under the hood.
Hit the dyno today for some tuning fun on a 2019 Ranger, ~93 octane fuel. Baseline was 267whp / 306wtq which was about what I expected given the larger heavier tires on it.
Stepped up through the various map profiles all the way up through map5 which peaked at around 319whp / 372wtq. Boost, timing, and air/fuel looked solid through the runs with minimal knock count observed. Overall, all good stuff!
Up next will be some dragy 1/4 mile and 0-60mph testing!
1/4 mile and 0-60mph times are in. I know we can get the tuned times better but this is a good start.
Map2 IIRC, have a RWD customer who recently posted a 5.7s running map3 with 30% E85.
I am reading that the SPD/aFe catted DP require a tune. Do one of the maps, for the Ranger manage the back pressure reduction? Should I not get a DP? Is one better than the other? Any guidance is appreciated.
I have not tested a DP on the Ranger.. If you get one record a JB4 log and we'll help you adjust for it if needed.
Hey Terry,
I installed the JB4 2 weeks weeks ago and started getting intermittent adaptive cruise and power train faults. I checked all connections after the first time and everything it seated, but I've had it happen twice since then.
Hey Terry,
What fault codes exactly?
When I read codes with the JB4 it doesn't find any, but when I start the truck it says precollision assist not available and power train malfunction/reduced power (shows wrench icon). I checked and I am using the latest firmware, item 3 sounds like what I'm experiencing.
Read the code using a generic OBDII reader then. And email me the details terry@burgertuning.com, may need the updated SENT chip for your board.
Posted beta firmware to the app that hopefully resolves the issue with JB4 logging randomly not working sometimes. If anyone had the issue load the update and let me know!
