FlooF FlooF is offline
Car: Genesis G70 3.3T
Default MAP 4 Logs and Issues with Low Fuel Pressure - 06-30-2020, 04:25 PM
Hey Terry,
Thanks for taking the time to look over these logs.
Stats:
G70 3.3
BMS Intakes
Straight Pipe CatBack Exhaust
JB4 - Map 3/4 - V15
E30 Blend - 4 Gallons of E85 with 10ish gallons of 93 from known gas station. (Tested and same issue after 2 separate fill-ups)
Issue:
Low Fuel Pressure alert on JB4 with hard judders, turbo's being deactivated and being set back to map 0. This happens on hard acceleration at high rpm, mainly after 60mph on map 3 or 4 after the install of new catback exhaust.
Is there something I can do to help with the low fuel pressure?
Default 06-30-2020, 04:26 PM
Logs did not attach. They are now.
Default 07-01-2020, 09:58 AM
Turn on fuel control to lean it out for starters. It's way too rich here.
Default 07-01-2020, 01:02 PM
Well... That seems to have solved the issue, not really sure how I managed to turn that off.
Attached are new logs, seeming to be a lot better.
Thank you for the assistance and all the help.
Default 07-01-2020, 02:35 PM
