(#551)
BMW750i/\/\'s Avatar
BMW750i/\/\ BMW750i/\/\ is offline
Car: 2011 BMW 750i M package
Default 11-09-2021, 04:28 PM
Originally Posted by EFoss28
Any help would be appreciated. I have a 2011 550i 6spd manual.
BMW reman engine with 9k miles.
New in last 1500 miles OE NGK plugs, Bosch coils, air filters.
Only mods to the car are Meisterschaft exhaust with x Pipe and BMS throttle tuner.
The car had a drivetrain malfunction at the end of this log (5th gear).
I did have a code 102302 MAF air mass too high
I do have 2 step colder plugs, but haven't installed yet.
it looks like you boosted the highest when the error happened so this is just a guess but are you running the stock map sensors or the 3.5 ? If you're still on stocks then you may wanna look into upgrading them to 3.5 but you will also need to buy the adapter cables also to go with the 3.5 map sensors... like these --->>> https://www.google.com/amp/s/n63inta...r-pnp-adapters
EFoss28 EFoss28 is offline
Car: 2011 BMW 550i
Default 11-09-2021, 06:53 PM
Thanks for the response. I did order new MAF sensors. If that doesn't fix the issue I'll order the 3.5 bar MAP sensors. Thanks!
Default 11-10-2021, 09:05 PM
You're welcome... good luck ! I have had that warning many times myself ( usually happens when i set my jb4 to too much boost ) so I know how much it sucks...i recommend that the place you got the MAF sensors have a good return policy because the OEM ones are pretty pricey and more often then not are not the issue and speaking of sensors when it comes to BMW make sure you always buy oem sensors NOT the cheap chinese replicas , I learned that the hard way also ...
Car: 2011 BMW 550i
Default 11-16-2021, 09:58 PM
Just to follow up, the new MAF sensors allow me to now run on Map 1 and Map 2 without any drivetrain malfunctions. Need to do a few logs in 4th and post. Thanks again for the help.
Car: 2011 BMW 550i
Default 11-19-2021, 12:50 PM
Here is my datalog in 4th from the other day. It looks really lean around 3600.
Should probably do one in Map0 and Map1 too.
Any advice is greatly appreciated!
nextlevel6's Avatar
nextlevel6 nextlevel6 is offline
Car: n63 650i
Default n63 hybrid turbos - 04-27-2022, 03:55 PM
Anyone running hybrid turbos_pure.... looking for a lil advice on backend flashes and necessary components to optimize the performance. My setup is in my signature but im looking at pure stage 1 since i hear the bigger the turbo the more difficult it is to find someone that can or will dial it in properly if that is at all possible.
Any advice?
Jared Haynes
nextlevel6
'12 650i Msport
JB4
VRSF DP
ARM Front Facing Intakes
NGK 1 Step Colder SP
Dinan Coils & Intercoolers
