emans247 emans247 is offline
Car: 2018 ES DCT
Default Stuffed Turbo Upgrade with JB4 1.6t Elantra Sport DCT - 01-20-2022, 10:02 PM
Hey guys! I'm looking to upgrade my stock turbo to a stuffed K03. I usually don't go over Map 2 and was wondering if this would work with the JB4 and how much power should I be expecting?
GETAMBUSHED GETAMBUSHED is offline
Car: 2021 Veloster N (MT)
Default 01-21-2022, 07:34 AM
You need an ECU tune if you add a new turbo
Djfourmonie Djfourmonie is offline
Car: 2020 Kia Forte GT
Default 02-19-2022, 02:15 AM
Not really, the rules are the same. Log Map 0 on pump gas. Your limitation is pump gas.
A proper back end flash will help because the modified turbo will make more torque especially in the midrange and high rpm the limiters need to be changed that is about it.
2020 Kia Forte GT
6 Speed Manual
JB4+Bluetooth Connect
Burger Motorsports Water Methanol (45/55 mix)
Whiteline Springs
13.77@103
Map 7, E30+WMI, Hoosier Drag Radials
E85 Station Locator (US Only)
Default 02-20-2022, 09:33 AM
For larger than factory turbos we always suggest a good base flash map an then using the JB4 for fine tuning, logging, safety systems, etc.
