Hyphnx Hyphnx is offline
Default New JB4 Install, hazards staying on. - 01-20-2022, 01:16 PM
Hello all,
I just recently installed the JB4 with the MHD Back End flash. After flashing I was getting the Fuel Sensor error code so I replaced that but now the hazards stay lit on the dash at all times. If I do a pull it no longer goes in Map 4 but the Hazard Lights do not go away even at idle. If I get on the gas a little the lights will go away but come right back as soon as I let off the throttle.
VoIPNerd's Avatar
VoIPNerd VoIPNerd is offline
Car: 2011 335is
Default 01-21-2022, 06:55 AM
Sounds like you set your shift light too low. What is your steering wheel menu 3 set to?
2011 335is E93 with DCT
JB4 G5 ISO * BMS DCI * VRSF 7.5" Competition FMIC * VRSF dp's * VRSF Chargepipe * VRSF Inlets * Turbosmart Raceport BOV * Fuel-it Stage 2 Bucketless LPFP * Fuel-it Flex fuel kit * Fuel-it CPI kit * RB Turbo External PCV w/ plugged headports and Mishimoto OCC * NGK 2-Step Colder Plugs * MHD E85 BEF
Default 01-21-2022, 07:03 AM
6200
I am going to set the JB4 to map 0 and then flash MHD back to stock then enable JB4 and flash BEF. Might have done it out of order
Default 01-30-2022, 10:26 AM
Sounds like menu3 to me also....
Default 01-30-2022, 12:29 PM
Menu 3 is set to 6200. I haven't touched that since I installed JB4.
VoIPNerd's Avatar
Car: 2011 335is
Default 01-31-2022, 07:04 AM
I think MHD has a setting for shift light as well. Maybe you overrode the JB4 setting when doing the backend flash?
