ram00sa ram00sa is offline
Default Trims jumps to 50 - 11-29-2021, 08:07 AM
hello there i been noticing lately specially post shifts and sometimes during normal log that my AFR 2 reads 20, and i noticed trims jumps all the way to 50 suddenly
fuel used 95ron (91 oct ) i use to have X98 race fuel from VP in the tank about 4 liters per half a tank
i tried to use MHD only flash and putting the jb4 into 4-4 to see if the problem is with the jb4 or electrical problem that could cause the jb4 to read weird values, ( could be a 3 year old battery ? )
i just put new spark plugs NGK at 0.019
running on 19t tdo4 turbo
please let me know if there is anything i missed
Default 11-29-2021, 08:35 AM
also there is a weird jb4 readings
Car: Evo VIII
Default 11-29-2021, 11:32 AM
Reset User adjustment settings back to default settings for hybrid turbos and reset adaptions. Then get a log in map 2
Default 11-29-2021, 02:01 PM
When you log....
To properly evaluate the tuning, we'll need a full throttle JB4 log from 40-90mph on a safe private track.
You only need to upload one log at a time...trying to do a bunch of different scenarios for input only confuses things and nobody wants to try and sort all of that out.
Default 11-29-2021, 04:21 PM
Map 2 as requested.
Default 11-30-2021, 06:14 AM
Any idea what trims value usess to calculate the numbers.because trims max out first then AFR Follows then bank 2 4 5 6 misfire
Car: 2008 E93
Default 11-30-2021, 10:32 PM
Originally Posted by ram00sa
Map 2 as requested.
Not default settings.
Default 12-01-2021, 09:18 AM
The only thing not defaulted is the duty bias . It cannot maintain boost if so
Car: 2008 E93
Default 12-02-2021, 01:09 PM
You need to check again.
All settings.
PID gain of 60 is surely going to affect things.
Default is 25.
Default 12-03-2021, 10:43 AM
Sure I will do it . Expect boost not to be on target tho. And try to focus on the trims rather than anything else
Default 12-03-2021, 11:41 AM
I tried to replicate the problem in a single gear pull I couldn't in the limited time I had.
Here is a multi gear pull showing the trims raising at the end of 3th or 4th gear
Please disregard the under boost. It's mostly likely seloind issue or Turbo waste gate bad even tho turbo are new . China quality
Is it injectors or injectors seal LPFP or HPFP or battery or bad jb4
Car: 2008 E93
Default 12-03-2021, 09:18 PM
Have you tried resetting adaptations ?
Any codes for 02s by chance ?
Shadow codes ?
Default 12-04-2021, 07:53 AM
Alot of times it happens and no codes come up. Never had a o2 sensor code. But most of the time it goes map 4 for being to lean or trim varience And sometimes I got one or two or Al of bank 2 cyl missfire
Car: 2008 E93
Default 12-05-2021, 11:13 AM
Have you checked intake manifold gaskets ?
That can cause trims variance, along with difficulty hitting boost target since it would be a boost leak under pressure/ boost. Can also cause a lean condition.
Default 12-05-2021, 03:25 PM
i just replaced the gaskets on oct the 30th, should i check the torque ?
Car: 2008 E93
Default 12-05-2021, 03:46 PM
I would pull the intake and double check the gaskets. Maybe someone else can chime in.
I would pull intake though as a pinched/blown gasket can cause all the issues mentioned.
Default 12-07-2021, 05:51 PM
Anyone else has a different opinion based on the logs. Of trims maxing out.
After researching
It could be one of the following. But I can't read log to know exactly which one of them I can rule out
1-MSD80
2- bank 2 injectors or an injector ( most expensive) I have mix of 9 and one 7
3- bank 2 O2 sensor pre and post
4- intake manifold
5- injectors seal
6- carbon build up
7- spark plugs ( just installed with gap of .019)
There is an oil housing leak btw after I installed the bms oil cooler thermo
Missfire happens normally after 6k rpm
Or post shift (dct)
Default 12-07-2021, 05:52 PM
Forgot to mention car has 45k miles 2009
Default 12-13-2021, 12:15 PM
I'm going to guess you have a boost leak. FF is maxed out and you're still under boosting. You could try raising your DB's by 15 across the board but I think you'll only be compensating for the real issue. This may also be why you see the random spike in trims.
Default 12-15-2021, 02:52 AM
I replaced outlets intercooler and charge pipes and all of the intake manifold gaskets. And vacuum lines. I just order boost solenoids letís hope itís them
Default 12-15-2021, 01:04 PM
Or you could do a pressure test and go straight to the root of the problem.
Question 12-18-2021, 08:08 AM
Did a pressure test. No leaks
One more thing injector 4 sounds louder than M6 full exhaust and ******* ********
RVA_N55_Fan RVA_N55_Fan is offline
Car: 2014 435i
Default 12-18-2021, 04:51 PM
What psi level did you pressure test?
2016 435i M-Sport EWG MPPK Manual 6, BMS Map 6 BEF-PS2-Race, Pure Stage 2 turbo, Spool-FX150 HPFP, Walbro 535 LPFP, BMS Intake, BMS FMIC, BMS BOV, 3.5 TMAP, ER DP, AA CP, FTP Turbo Inlet, H&R Sport Springs, BMW 335is clutch kit, BMS Clutch Stop, BMS Diff Bracket, BMS Wheel Spacers, BMW SSK, BMW Track Package
Default 12-20-2021, 04:31 PM
Pressure tests should be done at the max boost (or more) level that you intend to run.
For that injector...I'd probably replace or at a minimum switch it to another bank 1 to see if the problem follows.
