For whatever reason it didn't upload, hopefully this works!
Looks fine to me!
I just updated firmware from v17 to v22.....is DWP settings on JB4 referring to Default Wastegate Pos? I'll try setting to 60 for now, if that's what this is?
Another trip to NoCal for the Forte GT resulted in more 13 second passes.
Unfortunately my first pass I didn't enable Sport Mode. But it still ran 14.007@102.07
Pass right after that = 13.82@103.16 Sport Mode enabled of course.
Again I got my best run after the car cooled down = 13.77@103.47
Compared to my best Map 3, E30 only run was 13.75@101.9 but I did run 102.12 which ironically was the first pass that outing.
The tenth + from WMI is keeping me in the 13's despite slightly slower 60ft times.
Last pass of the night was about as close to a back to back as I got (15-20 mins between runs). I tried a slightly lower launch RPM. The 60ft was better by a tiny bit but less energy into the rotating assembly meant the inertia wasn't there to run 103+ again so it ran 102.35.
13.800@102.35
The main difference between two weeks ago and last night was much warmer ambient temps peaking at 90 degrees at 4 pm when the track opened.
It was still in the 80's when I ran 13.77, only .02 off my best ET but 1.52 mph gain or about 15 whp with WMI and slower 60ft (2.11 vs 2.07)
Same boost levels as Map 3 (Boost Additive 60).
I am going to head back out this weekend. Based on current forecast it looks like Sunday will be best with a peak temp of 83 degrees. With WMI I am not worried about hot weather but traction tends to be worse. That is mainly a problem for vehicles which much more power than I'm making currently. That said I already have a traction problem even with drag radials so we'll just have to see.
2020 Kia Forte GT
6 Speed Manual
JB4+Bluetooth Connect
Whiteline Springs
13.800@102.35
Good stuff! What kind of tire pressures are running?
All the runs but the last two are at 17 psi and I didn't know it. I checked the pressure before I left the house. Burnouts had increased it to 17 psi from 15 psi cold.
I took out a pound each time after the first couple of runs. I was wondering why my 60ft where 2.1x instead of improving as the track rubbered in.
The last run it was 16 psi but I launched at a lower RPM.
Not great, I am working on driving the 60fts down. I expect the prep at Famoso will be better.
2020 Kia Forte GT
6 Speed Manual
Whiteline Springs
So after a primary ******** install with a little bit of throttle it goes into limp mode. CEL came on
Happened on map 0 and 1. Got a code P0049 Turbo overspeed.
Any help would be appreciated, thanks!
Hyundai Elantra N Line 2021 -
05-02-2021, 10:01 PM
Hello I have a question, I currently have a hyundai elantra n line 2021 dct transmission with the new 1.6t smartstream engine I would like to know if a jb4 works on the vehicle, the people at jb4 told me that yes it would work thanks to pleasure
Hopefully this log has more of what you need? v24_T1, map 3. Thanks!
Looks good to me, thanks!
Limp in maps 0,1,2 and 3. No once on map 5
P0049 Overspeed as well. Non foulers are on all 4, still CEL with that P0049
If you're talking about fouler on o2 sensors that is an awful idea. If they are on the primary sensors they need to be removed ASAP. Rear o2 sensors not as big of a deal but not useful usually.
Also to look at logs they need to be set to combine so it's just one file. I opened a couple there and didn't see much. Are JB4 EWG connectors installed? For over speed those are usually used to slow down turbine speed.
If Burger Motorsports told you it would work it will work. This forum is also used for technical support by Burger Motorsports the answer will be the same.
As I understand it the "Smart stream" engine is basically the same but has continuous valve duration and a .5 reduction in static compression ratio.
2020 Kia Forte GT
6 Speed Manual
Whiteline Springs
Why is an awful idea though? Combine as in 1 hour or other hours? No, do not have the EWG connectors. Not having is likely what's putting into limp mode?
People run defoulers because they are trying to trick the powertrain module (engine computer) that you are running no catalyst which is highly illegal, but you think you need that 10-15 hp they provide as proof of a restriction.
Also your contribution to things like clean air and the RPM Act is a small thing in the sea of others modifying cars or so you think. I get a kick out of people that freely admit to wrongdoing.
The JB4 is not a PCM flash that is reprogrammed to ignore error codes from no catalyst that are generated otherwise.
For the JB4 to work properly you need the 02 sensors to behave as normal.
There are better ways to gain a tenth or so of a second which is what 10-15 hp is.
2020 Kia Forte GT
6 Speed Manual
Whiteline Springs
If you have an over boost issue get EWG connectors installed so we can dial in WGDC.
Foulers throw off the o2 sensor readings which the ECU is using to control fuel injection.
I tried to plug in the connector and it does not match together
OK ordering the EWG connectors. Also bought the JB4 in 05/19...Needing that master chip? Drop down menu choose
Kia Stinger master chip?
Yes good idea to have it just in case.
I have had a couple issues the last couple days. Attaching 3 logs looking for answers. Map 2 4th gear pull was great. Tried map 3 with some more timing corrections, but the ecu pulled some boost and the afr basically went to 0 (line 68). Went back to map 2 and today under normal driving conditions went to take off from a stoplight and the car was very sluggish. No engine lights. No codes nothing. Went WOT briefly just to check the log. Ign 1 timing is all messed up. What else happened? Parked the car. Locked it for 5 minutes and took off again and everything seemed fine.
On the channels dropping to 0 either bluetooth or canbus is dropping out there. The parameters are not actually going to 0.
Which log is the problem log?
I mainly was just looking for a reason as to why with the jb4 open and running map 2 why it quit doing it's job under the hood unexpectedly with no signs as to why. Thanks.
Same thing happened today when I tried running map 3 except this time the check engine light came on. Fault code 2587. No description available. Tried the search and nothing came up.
