FlooF FlooF is offline
Car: Genesis G70 3.3T
Default Map 4 logs - car goes into limp mode at high rpm - 04-02-2021, 01:08 PM
The car is going into limp mode in maps 2 and up. Log is map 4.
Mods:
JB4 map 4 - fuel wires - ewg
E85 and 93 blend for e30
Denso 2 steps colder and gapped .020
Bms intakes
*** back exhaust
Default 04-02-2021, 02:02 PM
Last safety = 3 means your fuel pump isn't keeping up.
You've really got boost cranked up. Drop FF down to 50 to lower it. And if map4 is still too much then map3.
Best way to augment the factory high pressure pump is our CPI kit.
Default Thank you - 04-04-2021, 08:32 PM
Thank you Steve and Terry for all your help. That solved the issue....
What an amazing difference the EWG wires make.
2021 Genesis G70 3.3T - JB4 - Map 5 - E30 Blend 93 - Various Mods - YouTube - Closed Course.
