FlooF FlooF is offline
Car: Genesis G70 3.3T
Default Low boost on WOT - 12-25-2020, 08:12 PM
Iíve noticed recently that on WOT my boost has been way lower then it should be.
Mods:
JB4 map 2/5
BMS intakes
AP intercooler
Velossa Scoops
2 step colder plugs at .0022
Straight pipe exhaust
For map 5 93 with boostane and 3 gallons of e85: 17/18 psi of boost
Map 5 93 and only boostane : 17/18 psi
Map 2 93 only 12-14 PSI
Attached is a map 2 log. Iím not really sure why my boost has dipped so much and any advice is appreciated.
Default 12-25-2020, 08:17 PM
Map 5 log attached
Default 12-25-2020, 10:19 PM
Not sure, maybe a small boost leak? You should run map0 to see how stock tuning boost looks.
Default 12-26-2020, 06:41 AM
I donít have a map 0 log, but I did test it when I did the map 2 log yesterday and got nominal results. 11/12 psi all the way through wot.
Default 12-26-2020, 11:04 AM
OK let's see map0 when you can.
Default 12-26-2020, 04:28 PM
Terry thank you for everything you do for the community.
I spent today doing the cleaning for the valves with sea foam to clean gdi engines. Immediately after the cleaning and procedure, back to normal boost levels. I am not saying that is the cause, but the boost problem that has been plaguing me for months is no more.
I also cleaned the bms cones are reoiled. But the boost dipping was solution was resolved by the sea foam cleaner before I did the cone cleaning.
What is your opinion on that?
