(#3626)
Stung Stung is offline
Car: 2018 Kia Stinger GT2 3.3TT
Default 09-08-2020, 04:52 PM
Originally Posted by sym
Default Wastegate Position.
It's a misnomer in this context because Terry just used the DWP setting box as a place to enter the new setting. Now that you brought it up this parameter does need a proper (cool) name.
Hm. Well, then what does it actually affect? LOL
2018 GT2 AWD
GT2Crew GT2Crew is offline
Car: 2019 Kia Stinger GT2 AWD
Default Misfiring? - 09-08-2020, 06:06 PM
I've had a couple hiccups transitioning to e30. I was running e30 on Map3 and blew a spark plug Denso 5346 a couple months ago. I changed my plugs to Denso 5347 and am having the same issue. It feels like my car is misfiring at high RPMs both on Map2 and Map3 with e30. Any suggestions?
Mods include: FuelIt, ADDW1 OCC, Injen CAI, Ark down *****, MBRP catback
I'm at 5,000 above sea level and highest octane is 91. First log is Map2 and second is Map3.
Default 09-08-2020, 08:09 PM
Not going to share that information yet, makes it harder for Lap3 to copy it like they do every other JB4 innovation.
Would need the CSV for any tuning advice
Default 09-08-2020, 09:16 PM
Thank you
Default 09-09-2020, 06:55 AM
LOL Understood!
2018 GT2 AWD
FlooF FlooF is offline
Car: Genesis G70 3.3T
Talking 09-09-2020, 08:37 AM
Now that's funny... There is no competition to JB4. Y'all are best from constant updates to excellent customer support when their is issues.
LapWho?
Jays_stinger Jays_stinger is offline
Car: Kia Stinger GT
Default 09-09-2020, 09:01 AM
Ok, so i recorded some logs with V21 DWP setting to 90. I will post them in a few.
What i noticed my exhaust would pop when i shifted and when decelerating it would burble more... I have primary ********* (no cats) resonators, and exhaust cutouts before the mufflers. Reverted back to 0 since the car felt as it was running rougher and not as smooth as before.
Terry is this something to expect?
Logs i took were some pulls, but did not want to drive it super hard being unsure on what it would do.
Car: Kia Stinger GT
Default 09-09-2020, 09:25 AM
Here are 2 logs.
Default 09-09-2020, 10:14 AM
Thank you
I see fuel pressure starting to drop a bit, update to v21 firmware and re-log map3 for comparison's sake.
Default 09-09-2020, 06:18 PM
No additional information to provide other than what we posted in the firmware. We've noticed a slight surge especially when cold at higher levels so we'll be correcting that before moving it out of alpha, but looking fro general feedback on how pedal response feels at various DWP settings.
G70 3.3T - E30 Blend - Map 5 V21T1 - Denso 2 Step Colder Gapped - CAI - Ram Air - *** Back Exhaust
I didn't really notice too much difference playing with the DWG Settings. I will say the car feels extremely fast, the throttle is punchy and the exhaust is more burbly. The difference between DWG 0 and any other option seems more placebo to me. If I had to pick one of the values I liked it would be 60. I will say V19 to V21 definitely feels a lot better as well, but that may also seem to be placebo.
One thing that did strike me as positive(ish) was the shifts seemed harsher/faster, but not 100% sure.
Overall, the car feels very racecar like and is quite enjoyable.
Attached is a log 60-130 wide open with DWG at 60.
Default 09-09-2020, 06:38 PM
Done. Here are a couple logs on Map3 with v21 firmware. Thank you.
Car: Kia Stinger GT
Default 09-09-2020, 08:32 PM
First thing I noticed was the difference in my exhaust. It would burble more and get some pops at high rpm shifts. Sounded really nice.
I'm wanting to know how safe this is with adjusting a these settings.
V21
Primary *********, mid *** deletes, resonators, and exhaust cutouts, with mufflers. Map 2 E30 blend. EWG ff50
Default 09-10-2020, 08:37 AM
Log looks clean to me!
The DWP setting won't show up at full throttle or in logs. It's just a pedal feel sort of thing. So run whatever setting feels best or if they all feel the same DWP = 0 to disable is fine too.
Boelli134 Boelli134 is offline
Car: Stinger gt 3.3T
Default 09-10-2020, 10:40 AM
Hello Terry
I have a question.
if the fuel pressure drops with Map 5, won't it drop even further with WMI?
Default 09-10-2020, 12:39 PM
WMI increases fuel volume and solves most fuel pressure issues.
Default 09-10-2020, 12:42 PM
Okay thanks!!!
Default 09-10-2020, 12:44 PM
Okay thanks.
What is the price for a complete Set for a Stinger?
BHR Stinger BHR Stinger is offline
Car: Stinger 3.3T
Default 09-10-2020, 03:23 PM
bit3 - Turn on for slow speed CANbus, useful for some older models.
Hi Terry, when is bit3 useful since I have an older model.
JB4 - Denso 5346 - Mishimoto IC - AEM Intake - VT Snorkels - Snow WMI - NGT Primaries - JUN BL Mid-pipe w/200cell HFCs & EVC c@t-back - Radium OCC x2
Default 09-10-2020, 04:02 PM
We've needed that setting on a couple 2011-2015 models.
Default 09-10-2020, 04:06 PM
Originally Posted by Boelli134
Okay thanks.
From the web store: https://burgertuning.com/collections...-injection-kit
2018 GT2 AWD
danalmsa danalmsa is offline
Car: G80 Sport 2018
Default Tested Firmware 21 - 09-11-2020, 11:58 AM
Can you check out these logs? I had a hard time upgrading this firmware, including having the app stating that there was no firmware on the device after two failed attempts. Unfortunately, I had to move the car 20 feet while it was like this. Finally got it to succeed by placing the phone right on the Jb4.
I only use map 2, so that's what I tested with. And, something feels off. Didn't feel as peppy as it usually does (I had just done some errands before trying this and the car was feeling quicker). The other thing is that when I pressed the pedal, on the first drive after, it felt lagging. And then, about half a second later, I would feel a hit, kind of like the transmission suddenly falling in gear. This happened a few times, so I parked the car, turned everything off and then restarted, and that stopped. Might have been because of the recent upgrade. But the acceleration still felt different. I'll go test again later, as I suspect I need to drive it a bit more with the new map.
Edit - is it possible for the ECU computer, because of the confusion caused by turning on the car without a firmware loaded, to over boost? If I look at all my lgos, and compare to the one at 2:06, the ecu_Boost went up to 17.7 , whereas in all other logs, that was maxed at 14.5. The target boost went up to 22.1, higher than any other log.. just odd.
bosaad bosaad is offline
Car: Kia Stinger
Default 09-11-2020, 12:14 PM
There is minimal tuning benefit on the 1.6L models so for now we only suggest connecting them if you plan to run E85 mixtures or WMI.
Any benefit from fuel wire for stinger 2L with out E85 or WMI?
Car: 2020 Kia Forte GT
Default 09-11-2020, 12:30 PM
Connect the fuel wire on all Kia/Hyundai JB4 connected cars.
It benefits all of the cars since they run rich as RPM increases under boost.
It puts the AFR at around 11.8 which is better than 10.8...
mcdonaldls15 mcdonaldls15 is offline
Car: hyundai elantra sport 1.6T
Default 09-11-2020, 04:32 PM
quick question for any on here and terry haha. any 1.6 guys put th v21 update on and what did everyone set the DWP to that worked best ? im also located in eastern canada if that makes a difference, thanks!!
1.6 elantra sport tech
mods : Intake, strait pipe ( minus stock DP and res ), hks plugs, 5w40 motul oil, pierburg ebcs
