Default BMS F Chassis Diff Brace - 03-08-2020, 07:39 PM
Finally was able to get a batch of these done! Locks down the diff for tighter handling and improved traction!
https://www.burgertuning.com/product...-f-chassis-bmw
Dumaurier7 Dumaurier7 is offline
Car: M235i
Default 03-09-2020, 06:55 AM
Nice!....where would I have to drill to install this?
Default 03-09-2020, 10:41 AM
Rear subframe, two 1/2" holes really easy to do!
Squizza Squizza is offline
Car: 2014 BMW 435i xdrive
Default 03-20-2020, 03:38 PM
Any Torque Specs for the bolts?
Default 03-20-2020, 03:40 PM
Bolts to the diff will be stock tq. Make the ones to the subframe very tight, no real spec on those.
Default 03-22-2020, 10:00 AM
Bolt holes on rear diff are about 1" higher than holes on the bracket.
2014 435ix.
Default 03-23-2020, 10:00 AM
2014 435ix.
Can you email me pictures please.
Payam@burgertuning.com
jpuehl jpuehl is offline
Car: '12 135i
Default 03-26-2020, 08:00 AM
Do you have a video taken from under the car of the diff under hard acceleration and braking using this brace? I have the WhiteLine poly RSF and diff bushings and have been chasing the cause of wheel hop and mounted a camera under the car, focused on the diff. During hard acceleration the diff twists the front upwards quit a bit. It seems like a diff brace would put a lot of strain on an area of the diff that was intended to simply attach the diff cover. How much R&D/real world testing was done on this brace?
Jim
'12 135i DCT N55 : FBO : PS2 : JB4 : MHD BEF
Default 03-26-2020, 09:56 AM
This type of diff brace has been on my 335i for a couple of years now at 750whp with great improvement. So... lots of real world testing.
Car: '12 135i
Default 03-26-2020, 10:18 AM
Do you have a video of the diff with the brace installed? Just interested in seeing how things look.
Jim
